Everything posted by 98cc
A couple of weeks ago it had its big debut at the the Vintage Revival event at the very historic Monthlery banked circuit in France. A couple of the other GN specials from the U.K. went over, GN Parker, GN thunder bug and the most legendary of them all GN Spider These pics were taken when we had the body off Spider to do some adjustment to the clutch, it shows the standard position of the chains on the axle. Spider was built by a hillclimbing legend called Basil Davenport and held many records in period and would routinely beat far more advanced works cars like the ERAs, Maseratis and Bugatti’s of the time. The engine is a derivative of the lightly tuned 90 degree v twins that the road going GN came out with standard. Constantly developed by Basil turning it into the 1500cc methanol burning chain driven over head camshaft monster that it is now
- 53 replies
- 36
Having now been in the U.K. for 3 years my ideas and inspirations have changed slightly from the wooden chassis cyclecar I had originally intended. I’ve been very lucky to get quite involved in the vintage racing scene over here and have made some very good friends because of it. A GN cycle car was always the dream although with none available in NZ to look at and the closest example being in Aus it was quite hard to fathom coming up with one. Since being over here I’ve managed to collect enough GN parts to put together this which is my take on the Hillclimb special concept of the 20s-30s. Going to all the swap meets in the calendar i managed to get hold of all the other groovy bits and pieces that I needed for the build. The defining feature of a GN is its chain drive transmission and solid back axle. 4 different ratios with dog selection. An incredibly simple but extremely effective system with large scope for easily changing ratios. Normally on a GN these chains are on the back axle but on this car I’ve moved them forwards so they are under your legs, this means you can have a low down far back seating position that you can’t get with the chains on the axle. Of course It needed a name to get the poms scratching their heads....
- 53 replies
- 31
- 53 replies
- 32
Over to the mill to drill through stud holes. Dividing head to do stud clearance cutouts Repeat x 2 Will need a final hone when the time comes otherwise finished
- 53 replies
- 34
First cuts on the casting. This was a serious brown undie moment holding the rough casting on some very narrow jaws boring out a rough casting at the other end. Bored out and head spigot machined. 3.5 inch bore Flipped over and cyl base machined
Yep I imagine this will be the case. We did, 3 GP Bugatti’s and was going to do the Mille Miglia the weekend before. Was pretty guttered when that was all cancelled. You just about could of. Chain driven blower might have to be in this cars future. Cyl time. The crowd I got the crankcases of had just done a run of cylinders and heads so I managed to get a set. It was far easier getting them sent a couple of hours down the road instead of to New Zealand that’s for sure. First issue to sort, the only boring bar big enough was a bit large for the toolpost. Couple bits machined up and welded together Should do the trick
One year later...... So shortly after my post I packed my bags (including a JAP crankcase) and hopped on a plane to the Uk on the big OE. I’m working in the vintage car world over here and have had some pretty amazing experiences. After spending so many hours looking at pics of cyclecars and the like it’s pretty neat to be at the events where they are running and get a real feel for them. One of the coolest trips I have been on was in Mark Walkers GN Thunderbug. A 4.2 litre Vtwin in a light weight chain drive chassis is definitely a good formula.... Some pics from the last year... Have many more to put up. With so many good vintage car events over here i need to get a car built so have been working flat out on the engine after hours and have made a fair bit of progress Cases bolted together and set up on the rotary table with a mandrel through the drive side bearing boss. Using the boring head to fly cut the decks Drilling and boring the cyl stud and follower holes prior to tapping 3/4“ 20 tpi cycle thread, mmmm lovely..... After all holes drilled and tapped and cyl base spigots bored Next up barrels
- 53 replies
- 23
98cc's Resurrection Of The "Smith Spider" 2 stroke race car--Now with SOUND
98cc replied to 98cc's topic in Other Projects
Cheers Mate, yeah was bloody good to meet up. Dennis had an amazing time at Leadfoot, it was the first proper car event he'd been to in over 15 years and he yarned to heaps of people about the Spider which was really neat. He does still drive so it would be awesome to get him back in it, will hopefully be able to sort something out. Really looking forward to getting into this when i get back home, pulling the engine out and replacing the seals should be pretty straight forward and then it will be time to have a third driving session! -
Cheers mate, na I think I will be doing some flicking through the Wiseco piston catalogue when it gets to that stage... Wow awesome, would of been great working at Mcintosh. I think I saw that engine run a few years ago when I was visiting Ken. Were the Hemmings heads original upgrade parts for sidevalve engines? I take it the guy with KTOR on the floor would never part with it? I’ll be making my own flywheels with press fits throughout, will get a 1.5” dia drive mainshaft with the bearings in have. A bit better that the original..... Have got the timing side case machined to the same stage now. Facing the timing cover mating surface as first reference. Flipped over and same stuff done as first half Internal features finished on both half’s. And with a couple of bolts holding it together. Next job get the timing cover bolted on
- 53 replies
- 18
Did you ever see the engine run SOHC? A bit of info on this engine. It’s a 1930 JAP JTOR long stroke racing model of 1000cc. They were used in racing 3 wheel Morgan’s and Brough Superior motorcycles. These v twins are very rare these days and are worth a large amount of money. Lucky a place in the UK has reproduced some accurate castings for anyone mad enough to try make their own. I will be changing a few things with this one to try and get a bit more capacity and power out of it. Made a start on machining the drive side crankcase half. Bearing boss faced off to become the first reference surface Flipped over, mating surface faced and holes drilled. Now clamped down with spacer blocks to machine inner surface and bearing bore Inner features finished Next up timing side
- 53 replies
- 26
Nice cardboard box arrived from the UK. JAP V twin engine kit set, some assembly required..... Should keep me busy for a bit.
- 53 replies
- 18
Good progress on the front axle this weekend. I'm doing a tubular GN style front axle the same as Bloody Mary had. Axle end blanks. 4140 Outer profile milled and kingpin hole bored Ready to go in the axle tube The axle tube. 1 1/2'' 4130 3/16 wall, should be strong enough..... Axle end in. These will get brazed into the tube Complete axle And mock up, made a couple of temporary axle clamps to hang it off the springs. Bloody Marys front axle showing the Austin 7 front stubs and wheels
- 53 replies
- 21
Yeah will definitely have to do a couple of early morning runs.... Have been working on getting a front axle put together. I’m using Austin 7 front drums and stubs. These needed a bit of a rebuild Reamed out the kingpin bushes with an adjustable reamer Set up the stubs in the mill, indicated the king pin to get them square. The dividing head was very good for this job The worn bottom surface that needs remachining And after Then needed to make a couple of new kingpins to fit. 4140 bar stock Finished
- 53 replies
- 22
Yep all of the tiny weight savings Dennis did seemed to of added up. The body alone only weighs 30kgs. For sure, it did fell like it was a lean issue. Will pull the motor out and chuck a new set in. -
No but a mate has one and wants to chuck it in a Austin 7 chassis. Its a pretty cool rotary hoe when its powered by a v twin! luckily someone has already made JAP casting patterns...... Made a start on the chassis brackets. Did them in two half's so could clamp them to chassis rail and get a nice tight fit before welding. Have also thinned down the rails from 2" to 1 1/2''. Looked a bit bulky and heavy before. Much better now Drilled a hole through it all and mounted the springs. Will need some form of U bolt to hold them down at the front.
Cheers Truenotch. Had a great time at Leadfoot, so good to get the car to a motorsport event again. A few teething issues including the problem that i thought i fixed with the new diaphragms. I think the crankcase seals are toast and its lacking in crankcase compression. There was a lot of oily mess around the engine and i think the seals are the only place it could be coming from. Also missed one run after i failed to make it out to the start. Fired up the motor on the dummy grid ready to drive out to the start line, selected first gear let the clutch out and oh shit i'm going backwards........ Bit odd as it has no reverse gear. It was making some bad noises in the gearbox and i thought it had done some major damage somehow. Pushed it back to the pits, had a think about it and started it up again. Turns out it somehow backfired on startup and started running backwards, all of the noises from the gearbox was just the gear set spinning in reverse..... 2 strokes eh, Dennis had never had that happen to him. Yeah a few people made that comment about it not being as loud as they though it would of been. One of the theory's is that it was quite loud but nowhere near the level of some of the other cars going up the hill. A couple of those rotary's were extremely loud. Cheers man, Yeah i brought Dennis along for the event. He had an amazing time and was awesome for him to see it going up the hill, was probably the first motorsport event hes been to in 20 years. Yeah its miniature, all done to keep the weight down. Oh yeah got it on the scales, only 330kgs!!!!! I see a camera on the fire wall, you better post some videos young man! Also, where did you get that hat? I must have one. Unfortunately the camera didn't work VG so no hill vids. I was yarning to this young american dude at the event about the car and he was wearing the hat. Turns out hes super into 2 stroke dirt bikes in the states. Asked him where i could get myself of those epic hats and he took it off and gave it to me. Complete GC, said he had got it at a motorcross event somewhere along the line. Wise words to live by.- 85 replies
- 27
Made a start on the springs today. GNs used 1 1/4'' wide 1/4 elliptic springs on the front and rear. A mate had some Morris 8 springs spare which are the correct width and a good start. Pile of springs The setup for resetting them Before and after. i have left one leaf out for now, might still need to take another out yet. And where it will sit on the chassis rail. Need to make up some brackets to bolt it to.
300rpm lister spec
Yep that's the plan. The JAPs John Bolster used were out of Brough Superior motorcycles, unfortunately they are very rare and expensive these days as Brough's often sell for over 200,000 pounds. I have something underway that should do the trick though.
No, It was the way the Grandad did it. I will only be using the finest selection of Whitworth and British Standard Fine hardware to......
- 53 replies
- 15
We have had a big plank of ash leaning up against the workshop wall for as long as I can remember, got it down and put it through the table saw and thicknesser. Should do the trick for a couple of chassis rails, section is 2x3 1/2” First mock up, front wheels are 19” Austin’s seven and rears are 19” Rude MG
- 53 replies
I have been foaming over cyclecars for a few years now and have been gathering a pile of suitable parts together. They are pretty much my ultimate vehicle with the simplicity, performance and character they have. My favorite of them all is John Bolsters 'Bloddy Mary' Based of GN cyclecar parts and powered by twin 1000cc JAP v twins with a solid back axle it was a weapon and held many hill climb records from the 20s-40s in various states of tune. It had a wooden ash chassis that John Bolster and his brother nailed together when they were teenagers and still survives to this day. I am going to be using this for inspiration for my car as well as Duncan Pittaways 'Hornet special' and a few others. Bloddy Mary GN Hornet special
- 53 replies
- 16
Looking forward to this, will prob come for sat morning and try find some swapmeet gems
Ahh yeah this is what it sounds like- 85 replies
- 31
So I had this at Hampton downs a couple of months ago for a race car track day. It went very well and is awesome to drive. Really good to get it on the open track and stretch its legs a bit, The sound it makes opened up in 4th gear is amazing. Towards the end of the day it started not running right, very much like it was lean so we packed up and went home. I pulled the fuel injection unit off to learn about it and try figure out what the problem was. It’s quite a neat unit that Dennis has come up with. It’s very simple in operation, with all the workings of a mechanical injection unit but the fuel doesn’t actually get injected in under pressure, it is sucked through the fuel nozzles by crankcase vacuum. The problem with it was with the diaphragms in fuel regulator units that are part of the injection system. After replacing those and putting it all back together it ran perfectly again. I’m driving this at Leadfoot next month, have a few more final jobs to do and then it’s good to go.- 85 replies
- 23
