Firebrand Posted May 10, 2017 Share Posted May 10, 2017 I'm looking to buy a small length of 35mm OD aluminium tube to join 2 radiator hoses together - I only need about 6 inches length, but I'll buy more if I need to. Where's the best place to get it from in wellington area? I can't tell if any of the metal suppliers will do such small quantities. I could probably order it from aliexpress but I need it this weekend ideally. Any ideas where to start, or should I just ring around and see? cheers Quote Link to comment Share on other sites More sharing options...
Transom Posted May 10, 2017 Share Posted May 10, 2017 I have been looking for the same size does it need the bead rolled onto it to hold rad hose properly ? Bunnings do alloy tubes and angles in 1m or 3m sticks not sure if they do tube up to 35mm? yes Aliex has the joiners cheap as Quote Link to comment Share on other sites More sharing options...
Firebrand Posted May 10, 2017 Author Share Posted May 10, 2017 Ideally it would be bead rolled..maybe I'm better off waiting for ali to send it to me - something like this I guess, but I'm sure there's cheaper ones: https://www.aliexpress.com/item/35mm-1-3-8-inch-Aluminum-Turbo-Intercooler-Pipe-Piping-Tube-Tubing-Straight-L-150/1444885458.html?ws_ab_test=searchweb0_0,searchweb201602_2_10152_10065_10151_10068_436_10136_10137_10157_10060_10138_10155_10062_10156_10154_10056_10055_10054_10059_10099_10103_10102_10096_10147_10052_10053_10142_10107_10050_10051_10084_10083_10080_10082_10081_10110_10175_10111_10112_10113_10114_10181_10037_10183_10182_10185_10078_10079_10077_10073_10070_10123,searchweb201603_4,ppcSwitch_2&btsid=681d8af4-8839-4d1e-837d-bb8d7ad61a31&algo_expid=9e3e3c67-de49-4093-ba0e-206bf47f028a-34&algo_pvid=9e3e3c67-de49-4093-ba0e-206bf47f028a I tried Mitre 10 & Bunnings and the biggest diameter they do was 25mm or possibly 30mm... Quote Link to comment Share on other sites More sharing options...
KKtrips Posted May 10, 2017 Share Posted May 10, 2017 Try Mico Metals in the Hutt. They have all kinds of non ferrous metals and sell offcuts. 1 Quote Link to comment Share on other sites More sharing options...
Firebrand Posted May 10, 2017 Author Share Posted May 10, 2017 That might be a goer, I'll pop in on friday morning and see what they have. cheers! Quote Link to comment Share on other sites More sharing options...
kicker Posted May 10, 2017 Share Posted May 10, 2017 I have bought ally offcuts from Ulrich before 1 Quote Link to comment Share on other sites More sharing options...
JoKer Posted May 10, 2017 Share Posted May 10, 2017 Saw a sweet home-made bead roller made out of a set of vice grips once in a Shed Magazine, piece or rod welded to one side (or both?) & ya work your way around crimping it etc 1 Quote Link to comment Share on other sites More sharing options...
igor Posted May 10, 2017 Share Posted May 10, 2017 Would a plumber's croxing tool work the same? It should if you could find a big enough size. 1 Quote Link to comment Share on other sites More sharing options...
mjrstar Posted May 10, 2017 Share Posted May 10, 2017 for thick wall on radiator pipe (like 2.6-3mm just 3 decent hits (evenly spaced ) of TIG to provide a bit of a bead on, if it's thin stuff then yeah a rolled lip will improve rigidity. Quote Link to comment Share on other sites More sharing options...
Firebrand Posted May 11, 2017 Author Share Posted May 11, 2017 Cheers all of you guys, Joker, I'm going to Google that DIY bead roller when I get home, I've got some spare old vice grips looking for a use... 1 Quote Link to comment Share on other sites More sharing options...
JoKer Posted May 11, 2017 Share Posted May 11, 2017 one step further / LMGTFY https://www.theturboforums.com/threads/vise-grip-tube-bead-roller-tool-for-only-7-83.350500/ GIS link (if it works) https://www.google.co.nz/search?q=diy+bead+roller+poly+grips&tbm=isch&imgil=ZIPwQs4oAfxaFM%3A%3BMWLUizxIwhIasM%3Bhttp%253A%252F%252Fwww.d-series.org%252Fforums%252Fdiy-forum%252F163148-diy-%252525245-charge-pipe-bead-roller.html&source=iu&pf=m&fir=ZIPwQs4oAfxaFM%3A%2CMWLUizxIwhIasM%2C_&usg=__JR2vA5FGQb2i0bybB_mQPWYsf5U%3D&biw=1280&bih=882&ved=0ahUKEwi1hPb7jufTAhXLy7wKHcw0BkUQyjcIMA&ei=xvcTWbWJEsuX8wXM6ZioBA#q=diy+bead+roller+poly+grips&tbm=isch&tbs=rimg:CWSD8ELOKAH8IjjZgbzk-pgusKlIQEeXIVp-MFkpu59Gxhn3GX5mXzo26AX8Kh9t-hQDwJibS4SJyUkpPZ6reNASUCoSCdmBvOT6mC6wEQ0OXxrQRJOqKhIJqUhAR5chWn4RkU1k4jQCGYQqEgkwWSm7n0bGGREacptyjNathyoSCfcZfmZfOjboEc33okCb9HUtKhIJBfwqH236FAMRw7eYmIGllZkqEgnAmJtLhInJSRHdg6WnPZhlBCoSCSk9nqt40BJQEYLe4it-6Gcr or : http://www.offroadexpress.kiwi/Forums/viewtopic.php?t=43349 which is closer to the original thing I think I saw once 10 years ago 2 Quote Link to comment Share on other sites More sharing options...
Firebrand Posted May 11, 2017 Author Share Posted May 11, 2017 OK that's awesome! 1 Quote Link to comment Share on other sites More sharing options...
Firebrand Posted May 16, 2017 Author Share Posted May 16, 2017 Ullrich came through as they are open Saturday morning, I ran out of time on Friday and couldn't get down to Mico. Ended up buying 2.5 metres of tube as it was way cheaper than I though it would be, so I've got some spare for future projects Will update my project thread soon 1 Quote Link to comment Share on other sites More sharing options...
