Mr Vapour Posted August 14, 2016 Share Posted August 14, 2016 Hi gents I know there is slot if love here for a BA falcons. Hoping to get some help. I have my self an early BA 2003 xr6 Got it with 100km on the clock and it's now got 150km on it. We have had it for 3.5 years. Non traction control. It's making concerning noise/feeling under slow brakes. It has new pads and rotors up front, and I think pads in the back. I have also changed out the nasty black fluid for fresh. I know these all get the shudder and it's not that. I fixed that issue long ago with the new pads and rotors. This issue is felt and heard when at slow speed. It's like a short grunting/high pressure releasing noise, and you can feel a slightly softer pedal at the same time. It's like a sensor is picking up that a wheel is locking and the abs is kicking is pulsing the brakes 2-3 times. But it only happens at under 15kph. It may happen at higher speeds but it's not noticed. The abs light comes on every now and then. It's my car and only gets driven 10ish km per week as I catch the train. But we are going to Wellington later on the year and I will only do not in the falcon of lush long distance. Any one have any ideas? Faulty sensor? Abs module/distribution block? Any help would be good. Quote Link to comment Share on other sites More sharing options...
Muncie Posted August 14, 2016 Share Posted August 14, 2016 I had the pulsing pedal with my commodore and occasional Abs light come up, new rotors fluid and pads cured it. Perhaps your rotors might be worn below the minimum tolerance allowing the pads to travel to far and get skewed in the caliper when braking. Off brand rotors are dirt cheap if it is the cause. Quote Link to comment Share on other sites More sharing options...
cletus Posted August 14, 2016 Share Posted August 14, 2016 Had an intermittent similar fault on mine that caused the light to come on , cleaned the sensors- one had little bits of steel stuck to it. Light hasn't come on again. Quote Link to comment Share on other sites More sharing options...
fletch Posted August 14, 2016 Share Posted August 14, 2016 Yeah what Clint said. Worked on my mates one a while ago. Had similar problems. Lots of shut stuck to the sensors cos they magnet. Quote Link to comment Share on other sites More sharing options...
Mr Vapour Posted August 14, 2016 Author Share Posted August 14, 2016 Cool makes sense. I will give the sensors a good clean next weekend. Quote Link to comment Share on other sites More sharing options...
Rhyscar Posted August 16, 2016 Share Posted August 16, 2016 +1 for start with the wheel speed sensors. See if you can get a scan tool on it to read any faults it's logged regarding the abs. Shuddery brakes will come back eventually. Proper fix is to back the adjustment off the master cylinder at the back of the pedal box. 2-3mm is all it needs so it doesn't give too much play in the pedal. For some reason they all came quite poorly adjusted from the factory. Quote Link to comment Share on other sites More sharing options...
cletus Posted August 16, 2016 Share Posted August 16, 2016 See if you can get a scan tool on it to read any faults it's logged Last time someone plugged a scan tool into my wagon, the first thing they said was ''holy shit" i assumed that was not a good thing 3 Quote Link to comment Share on other sites More sharing options...
chris r Posted August 17, 2016 Share Posted August 17, 2016 Another +1 for checking/cleaning wheel seen sensors. Also check tire sizes/see if one is way more worn than the rest Quote Link to comment Share on other sites More sharing options...
Rhyscar Posted August 17, 2016 Share Posted August 17, 2016 Last time someone plugged a scan tool into my wagon, the first thing they said was ''holy shit" i assumed that was not a good thing Same here... rev limit 37 times in 2min period... whoops must have slipped on loud pedal... in 3rd gear. Dammit. 2 Quote Link to comment Share on other sites More sharing options...
japawagons Posted August 18, 2016 Share Posted August 18, 2016 I'm sure that would've occured frequently whilst you were"mowing" our lawns... 1 Quote Link to comment Share on other sites More sharing options...
