Muncie Posted April 1 Author Share Posted April 1 Had to re engineer the throttle cable bracket so it clears the inlet pipe made that work with the grinder that's been in naughty corner after bumper support....... Spritz of paint it bolted on and the cables even work in their new position although very long I think I can hide this by sending them under manifold. 1 Quote Link to comment Share on other sites More sharing options...
Muncie Posted April 1 Author Share Posted April 1 Look at all this space! 1 Quote Link to comment Share on other sites More sharing options...
Muncie Posted April 1 Author Share Posted April 1 Now the exciting part bolting on shiny cool new stuff! 3 Quote Link to comment Share on other sites More sharing options...
Muncie Posted April 1 Author Share Posted April 1 The size of the hotside assembly off the engine is quite considerable and looks mental when you pick it up and turn it around to check things out. I'm very happy with my driveway cobbling together on this occasion 4 Quote Link to comment Share on other sites More sharing options...
Muncie Posted April 5 Author Share Posted April 5 Well first cock-up found.... up pipe from cross over doesn't fit needs a zig zag easy fix I just didn't account for the depth of engine bay when making on dummy block Zach stripped the exhaust manifold off for me and made a start on wiring for too surprisingly once unwrapped all but a few wires reached the drivers side where airflow meter and throttle body is. Quote Link to comment Share on other sites More sharing options...
Muncie Posted April 6 Author Share Posted April 6 Back on track again everything that needs to go back in engine bay is there wiring has been started everything accounted for. A v6 engine bay is normally quite empty looking this one's bloody packed! Bonnet shuts exhaust now misses the air-conditioning components phew taken long enough. Hotside needs to come out again for some welding after re jigging the up pipe but that's a 5 minute job now. 4 Quote Link to comment Share on other sites More sharing options...
shrike Posted April 6 Share Posted April 6 Any plans for heatwrap or ceramic coating? Looks the goods, what does the slushbox take powerwise? Quote Link to comment Share on other sites More sharing options...
Muncie Posted April 6 Author Share Posted April 6 4 hours ago, shrike said: Any plans for heatwrap or ceramic coating? Looks the goods, what does the slushbox take powerwise? Yeah I'll go nuts with heat wrap and make some shields. I'll build a box myself later on they cope ok at 400hp will stick a shift kit in asap ive already bumped line pressure up in ecu. 2 Quote Link to comment Share on other sites More sharing options...
Muncie Posted April 7 Author Share Posted April 7 Have decided to do rocker cover gaskets while I have access and flip covers drivers to passengers side vice versa as the drivers side now has a throttle body on top and passengers has ample room between the downpipe and wastegate to get a funnel in. Bloody repackaging can see why they never did as a factory option. 1 Quote Link to comment Share on other sites More sharing options...
Muncie Posted April 22 Author Share Posted April 22 Not much to see but have flipped rocker covers over so i can access the oil cap wouldn't want to top up hot but you get idea. New gaskets too billet cap so it doesn't melt.... Have started on wiring not ultra complex but coil packs need to move. 8 Quote Link to comment Share on other sites More sharing options...
Muncie Posted April 22 Author Share Posted April 22 My crossover pipe ended up clashing with chassis rail has ended up becoming a stupid complicated thing only really so it fits the existing pipework locations..... I may end up chopping it off and have it enter just under the turbo instead of the collector, as I think it may end up been a restriction. Also time to fit the wideband sensor I bought ages ago off @Honda Ass Dragger and it integrating into the pcm. 2 Quote Link to comment Share on other sites More sharing options...
shrike Posted April 22 Share Posted April 22 Can you fill from the other head if you had an oil cap on the other cover? Quote Link to comment Share on other sites More sharing options...
Muncie Posted April 22 Author Share Posted April 22 1 hour ago, shrike said: Can you fill from the other head if you had an oil cap on the other cover? Nah the throttle body and airflow meter sit right on top of it where filler cap was now. The cable bracket was 1-2mm away from it so had to move. Other side is actually fine just needs a funnel I suck at pouring anyway. 2 Quote Link to comment Share on other sites More sharing options...
Muncie Posted April 25 Author Share Posted April 25 Started some wiring fitted looks mint pity you can't see it for throttle body..... suppose that is the idea. More to do just a bit of soldering to finish off and put in braided sleeve so it can shed heat. Discovered the ignition coils could flip 180 degrees bolt straight back on and wiring is basically perfect once unwrapped reaches dead easy and won't melt on wastegate, heat shield will be a good idea though. Airflow meter new location on right side of engine bay set up in photo. 5 Quote Link to comment Share on other sites More sharing options...
Muncie Posted April 25 Author Share Posted April 25 Can see a wideband sensor fitted in downpipe in above photo started installing the unit for that under dash too. 3 Quote Link to comment Share on other sites More sharing options...
Muncie Posted April 27 Author Share Posted April 27 More shit done today. Turbo drain welded on.......... in place on the car by someone who can't really weld alloy amazing, it's bloody on there took fucking ages and tools were thrown! But it's on. Tick! 1 Quote Link to comment Share on other sites More sharing options...
Muncie Posted April 27 Author Share Posted April 27 Crossover pipe in and ready to go actually fits well gave me nightmares almost as much as the damn turbo drain. Feed and return oil lines to turbo also done. 4 Quote Link to comment Share on other sites More sharing options...
Muncie Posted April 27 Author Share Posted April 27 What im stoked with at this stage nothing is a pig to fit it bolts on like factory misses everything it needs too and is serviceable. Spark plugs won't be fun but also not terrible as most things are vband 20 seconds and the hotside is on the floor. 5 Quote Link to comment Share on other sites More sharing options...
Muncie Posted Sunday at 00:49 Author Share Posted Sunday at 00:49 Well that's everything in the bay I need to make intercooler pipes now leaning towards stainless as I haven't really loved working with alloy so far. 6 wires to be soldered in to finish wiring ran out of steam (Fucks) to do that today. Looking like the battery needs to go somewhere else as the Intercooler pipe needs to occupy that space. I could go under it if i get creative. Blue silicone 90 off throttle body is gross! 3 Quote Link to comment Share on other sites More sharing options...
Muncie Posted Sunday at 06:13 Author Share Posted Sunday at 06:13 Wrapped up 90% of wiring today surprisingly there was loops bundled up in factory loom to allow most things to reach new locations. Only thing left to do is solder in the sub loom I made up to send the TPS and idle control wiring around back of engine. Have done my best to have no wiring near hotside of turbo you can see a small loom heading to radiator that feeds some air-conditioning and body stuff. Spark plug leads will need addressing later drivers went straight back on passengers fitted ass about eg plug end to coil not pretty but will work for a fire up I'll order some new ones later it'll do for now. 90 degree ends on turbo side and straight on drivers needed. I need to see if Wideband can output a simulated narrow band signal for ecu to run closed loop, stock ECU Has been flashed to add a datastream from wideband so it can be logged and see live data. Hopefully it can then I don't need my narrowband sensors anymore. Aftermarket ecu would be nice but the stocker is well and truly cracked and quite the community that shares info. 3 Quote Link to comment Share on other sites More sharing options...
