2nd Chance Posted November 10, 2014 Share Posted November 10, 2014 Hey guys, Just got my hands on an old smiths tacho for my mk2 cortina. Thing is I'm planning of changing out the points for an electronic unit, maybe an optic switch. Anyone able to tell me if the tacho will still read (accurately) if I go down this route? Also what brand should I go for/ stay away from? Thanks Quote Link to comment Share on other sites More sharing options...
ajg193 Posted November 10, 2014 Share Posted November 10, 2014 Should do, (older) tachos run off the coil. My tacho kept working when I put an electronic distributor in. Quote Link to comment Share on other sites More sharing options...
Ned Posted November 10, 2014 Share Posted November 10, 2014 This man speaks the truth Quote Link to comment Share on other sites More sharing options...
Flash Posted November 10, 2014 Share Posted November 10, 2014 I've got a HEI distributor in my ride and my old bullet style tacho still works perfectly. Quote Link to comment Share on other sites More sharing options...
Testament Posted November 10, 2014 Share Posted November 10, 2014 provided you are still running a conventional coil and can take the tacho signal from the same place as it is now (coil negative or coil positive, depening what type of tacho it is) then it should work the same as the electronics are only chaning the switch that is firing the coil. if you change to an msd or multiple coil ignition system - then things change. Quote Link to comment Share on other sites More sharing options...
2nd Chance Posted November 11, 2014 Author Share Posted November 11, 2014 Awesome, thanks guys. Yep it runs from the coil so all good. Quote Link to comment Share on other sites More sharing options...
cubastreet Posted November 11, 2014 Share Posted November 11, 2014 There are two types of smiths tacho. If the tacho says rvi on it (induction loop), it won't work with an electronic dizzy. If it days rvc, it will. Quote Link to comment Share on other sites More sharing options...
Banga Posted November 11, 2014 Share Posted November 11, 2014 The Smiths tacho out of a gt cortina I have didn't work as its rvi, just purchased a kit off ebay to convert it to rcv to allow it to work. It's on its way from the UK now. Quote Link to comment Share on other sites More sharing options...
2nd Chance Posted November 11, 2014 Author Share Posted November 11, 2014 Ahh nuts, it says RVI. Oh well, guess the points stay for now. Quote Link to comment Share on other sites More sharing options...
srf Posted November 11, 2014 Share Posted November 11, 2014 I am running a inductive loop type tach with full electronic ignition at the moment and lumenition before that. So long as the basic wiring stays the same it should work. Unless I am missing something. Quote Link to comment Share on other sites More sharing options...
