10Speed Posted October 28, 2014 Share Posted October 28, 2014 So I need a fuel pump... ideally around around 20PSI, could get away with 15PSI but will restrict options in the future... The current quote I have is for an Aeromotive A1000 plus rising rate regulator at about $1000... looks like super nice gear, but the price tag is way up there... Surely there's some cheaper options? Quote Link to comment Share on other sites More sharing options...
Testament Posted October 29, 2014 Share Posted October 29, 2014 certainly there are much cheaper options i would think most of the efi pumps would work, walbro, bosch, china bosch knockoff etc. what flowrate do you need at 20psi? Quote Link to comment Share on other sites More sharing options...
10Speed Posted October 29, 2014 Author Share Posted October 29, 2014 I'm unsure how to calculate the required flow rate... Quote Link to comment Share on other sites More sharing options...
Testament Posted October 29, 2014 Share Posted October 29, 2014 what is the maximum horsepower the engine will possibly make (roughly)? you can work out the fuel requirement from that Quote Link to comment Share on other sites More sharing options...
10Speed Posted October 29, 2014 Author Share Posted October 29, 2014 300hp Quote Link to comment Share on other sites More sharing options...
Testament Posted October 29, 2014 Share Posted October 29, 2014 walbro 255lph or deatschwerks DW200 or bosch 910 or bosch 044 or and 044 china copy, or almost any bosch roller cell type pump should do the bussiness. 1 Quote Link to comment Share on other sites More sharing options...
Rookie Posted October 29, 2014 Share Posted October 29, 2014 Is this for a carby Turbo setup? Quote Link to comment Share on other sites More sharing options...
10Speed Posted October 29, 2014 Author Share Posted October 29, 2014 this is for a carby turbo Quote Link to comment Share on other sites More sharing options...
Testament Posted October 29, 2014 Share Posted October 29, 2014 get a big/hiflow regulator, as you will need to bypass alot of flow when not under boost 1 Quote Link to comment Share on other sites More sharing options...
Rookie Posted October 29, 2014 Share Posted October 29, 2014 Also, I'm not sure you want a rising rate regulator, rather a boost referenced one. Quote Link to comment Share on other sites More sharing options...
Testament Posted October 29, 2014 Share Posted October 29, 2014 thats presuming you need 1-4psi typical carby fuel pressure when not under boost and 20psi when under boost. this will probably dictate your choice of regulator anyway. Also not those pumps cannot suck UP they need to be sucking from a bottom tank outlet. otherwise a good option is probably an intank setup, which will be tidier and required the least mods to the tank probably. e.g. jam it through the sender opening somehow if you can. Quote Link to comment Share on other sites More sharing options...
10Speed Posted October 29, 2014 Author Share Posted October 29, 2014 thoughts on what reg to use then? Quote Link to comment Share on other sites More sharing options...
Testament Posted October 29, 2014 Share Posted October 29, 2014 what blow through carb setup are you actually using? carb type? is it pressurized or is it boxed? max boost? Quote Link to comment Share on other sites More sharing options...
10Speed Posted October 29, 2014 Author Share Posted October 29, 2014 like that Justin Timberlake song, it's a carb in a box 1 Quote Link to comment Share on other sites More sharing options...
Testament Posted October 29, 2014 Share Posted October 29, 2014 what type of carb? what pressure does it want at the float needle? Quote Link to comment Share on other sites More sharing options...
mjrstar Posted October 29, 2014 Share Posted October 29, 2014 As far as pump selection goes the Walbro is possibly a better proposition than an 044 given your power target. packaging and noise of the 044 are the downfalls, just make sure the walbro is genuine (steel gears) (Yes I do have both in running cars so can comment) Regs - probably something like this which comes with a low and high pressure spring and is not an outrageous price.. http://www.summitracing.com/int/parts/aei-13301/overview/ Plus you are ready for EFi when you come to the conclusion that turbo plus carb = bonfire. 1 Quote Link to comment Share on other sites More sharing options...
Rookie Posted October 29, 2014 Share Posted October 29, 2014 China 044s sure are cheap though hahaha Quote Link to comment Share on other sites More sharing options...
10Speed Posted October 29, 2014 Author Share Posted October 29, 2014 what type of carb? what pressure does it want at the float needle? webber 44 idf's, and the internet says 3psi... Quote Link to comment Share on other sites More sharing options...
Rookie Posted October 29, 2014 Share Posted October 29, 2014 It might even be worth running 2 regulators, you will find out soon enough hahaha Quote Link to comment Share on other sites More sharing options...
cletus Posted October 30, 2014 Share Posted October 30, 2014 i run an aeromotive boost referenced reg and a single 044 bosch pump. it works just fine and dandy. it is pretty loud, especially when the fuel level is getting low it heats up a bit. if i did it again i would go efi from the start i think. theres a lot more parts and knowledge around. http://www.summitracing.com/int/parts/aei-13202/overview/ 1 Quote Link to comment Share on other sites More sharing options...
