beachlander Posted June 8, 2014 Share Posted June 8, 2014 So yesterday I went to go out in my carina. Turned it on, let it glow as usual, then went to start it and got nothing but a whole lot of noise from the relay. Took it apart, gave the contacts a clean and tried again. The relay is switching really quickly, then slows down and stops like all together. The inside of the relay looks OK, doesn't smell like it's burnt out, but haven't checked it yet. Would it be the relay? Or a short sone where else? Proving to be very difficult to find a replacement Quote Link to comment Share on other sites More sharing options...
johnnyfive Posted June 9, 2014 Share Posted June 9, 2014 So it doesn't crank over? Whats your battery voltage like? 1 Quote Link to comment Share on other sites More sharing options...
beachlander Posted June 9, 2014 Author Share Posted June 9, 2014 Nah doesn't crank/do anything. Relay just has a spaz then stops. Haven't checked voltage, didn't have a multimeter Quote Link to comment Share on other sites More sharing options...
johnnyfive Posted June 9, 2014 Share Posted June 9, 2014 Not just a really flat battery? Don't wanna tell you how to suck eggs etc, just always check the basics. Quote Link to comment Share on other sites More sharing options...
thegreatestben Posted June 9, 2014 Share Posted June 9, 2014 Yeah that sounds flat battery as. It would still crank even with bad plugs. My neighbours surf is proof of that for over a year now Quote Link to comment Share on other sites More sharing options...
Yowzer Posted June 9, 2014 Share Posted June 9, 2014 A "TIKTIKTIKTIKTIKTIK" sound when attempting to crank is usually the starter solenoid not getting enough juice to fully engage, meaning either flat / stuffed battery or crappy electrical connection from batt to starter or crappy earth. 1 Quote Link to comment Share on other sites More sharing options...
Yowzer Posted June 9, 2014 Share Posted June 9, 2014 Could also be a stuffed starter solenoid too, but generally when they fail they just make a single 'thunk' noise and nothing else (or sometimes no noise at all) Quote Link to comment Share on other sites More sharing options...
UTERUS Posted June 9, 2014 Share Posted June 9, 2014 Sounds like you got a bad case of winterbatteryitis 3 Quote Link to comment Share on other sites More sharing options...
DriveBy Posted June 9, 2014 Share Posted June 9, 2014 This happened to me once, had taken battery out, put back in and didn't tighten battery terminal connectors. Fixed by tightening connectors. Felt a bit dumb but oh well. Quote Link to comment Share on other sites More sharing options...
