zedmotorsport Posted May 6, 2014 Posted May 6, 2014 does anyone know a hub that is compatible with the mk2 escort that has a 4x114.3 stud pattern? im unsatisfied with 4x108 haha! or does anyone have any other ideas? i cant seem to find 4x108 to 4x114.3 adapters. cheers. Quote
ae85 fiend Posted May 6, 2014 Posted May 6, 2014 Redrill the hub? Get new studs? An engineer should be able to do it for you easily enough? I don't know if its legal? Nor how safe it would be lol. Quote
beachlander Posted May 6, 2014 Posted May 6, 2014 You could get some custom adaptors made up if you can't find any Quote
Beaver Posted May 6, 2014 Posted May 6, 2014 http://drivenperformance.co.nz/products-page/spacers-and-adapters/dpr-wheel-adaptor-4x108-to-4x114-3-15mm-1-5p/ here are some adapters in NZ. To be legal you will need a cert. Quote
Rookie Posted May 6, 2014 Posted May 6, 2014 Just get some new hubs spun up, pretty easy for an engineer to do. Quote
eke_zetec_RWD Posted May 6, 2014 Posted May 6, 2014 I have re drilled my hubs and axles to 4x114.3. You will need to remove axles from the diff. A good machine shop can do this for you. Where are you located? Quote
Gaz Posted May 7, 2014 Posted May 7, 2014 I had some 4x114.3 remachined hubs I couldnt get rid of a year ago. Ill see if I stashed em somewhere or if I scraped. Gaz Quote
