Sunbeam Posted October 9, 2022 Share Posted October 9, 2022 Is that a momo prototipo you’re running? Do you know the diameter? Quote Link to comment Share on other sites More sharing options...
Banga Posted October 12, 2022 Author Share Posted October 12, 2022 On 09/10/2022 at 18:50, Sunbeam said: Is that a momo prototipo you’re running? Do you know the diameter? It’s a Momo California, 360mm diameter. Really nice wheel. 1 Quote Link to comment Share on other sites More sharing options...
cletus Posted October 20, 2022 Share Posted October 20, 2022 Congrats! Good work, nice to see it legal and on the road 1 Quote Link to comment Share on other sites More sharing options...
Banga Posted October 21, 2022 Author Share Posted October 21, 2022 13 hours ago, cletus said: Congrats! Good work, nice to see it legal and on the road Thanks! Appreciate your help along the way in the cert thread! 1 Quote Link to comment Share on other sites More sharing options...
cletus Posted June 4, 2023 Share Posted June 4, 2023 Sometimes putting a slight rounded edge on the pads where they contact the disc can help with squeals 3 Quote Link to comment Share on other sites More sharing options...
Unclejake Posted June 6, 2023 Share Posted June 6, 2023 Agreed you should change clutch to a higher HP rated unit, but I'd also be checking both the clutch master-cylinder rod and slave cylinder rod to ensure they both had a little clearance as it's possible your clutch fluid is heating up, expanding slightly, and putting a little pressure onto the release bearing 1 Quote Link to comment Share on other sites More sharing options...
Banga Posted June 6, 2023 Author Share Posted June 6, 2023 3 hours ago, Unclejake said: Agreed you should change clutch to a higher HP rated unit, but I'd also be checking both the clutch master-cylinder rod and slave cylinder rod to ensure they both had a little clearance as it's possible your clutch fluid is heating up, expanding slightly, and putting a little pressure onto the release bearing Will double check when I throw it back together, running a hydraulic release bearing so no slave cylinder rod to check. Thanks! Quote Link to comment Share on other sites More sharing options...
Unclejake Posted June 6, 2023 Share Posted June 6, 2023 A hydraulic release bearing over the output shaft nose (such as a Quartermaster?). If so I ran one on my Mk1 Cortina racecar and IIRC the shimming was critical to keep the correct distance from the pressure plate. You're looking at it in real life and I'm not.... so treat my advice with a sack of salt. Nice project. Well done sir. Quote Link to comment Share on other sites More sharing options...
Banga Posted June 6, 2023 Author Share Posted June 6, 2023 It’s a bolt in place job specifically for this set up- no room to shim and it’s been fine for about 3000kms, I think you might be onto something with the master cylinder though - I swapped over a brake master in my pedal box and might not have have set the clutch master back to exactly where it was in the clevis when I put it all back together. It was only slipping in 3rd under high load/torque when hot so fluid expanding could be right on the money. 1 Quote Link to comment Share on other sites More sharing options...
mjrstar Posted June 6, 2023 Share Posted June 6, 2023 I had similar in my Honda whilst trying to optimise pedal height, back the pedal off so you have a bit more freeplay at the top end of the pedal movement, should be golden. 1 Quote Link to comment Share on other sites More sharing options...
TBS Posted June 22, 2023 Share Posted June 22, 2023 Hi, did you sell the original motor that came out of your car? Cheers Quote Link to comment Share on other sites More sharing options...
Alfashark Posted August 14, 2023 Share Posted August 14, 2023 Loving the presentation on this mate! I was sitting at The Cabbage Tree having a coffee in Tirau when you parked up on Saturday - I was going to wander over and ask if you were an Oldschooler, but the Barry brigade had wandered over to you and started yarning so I left you to it. 1 Quote Link to comment Share on other sites More sharing options...
Tiger Tamer Posted August 15, 2023 Share Posted August 15, 2023 I didn't see your car in Napier on the weekend, but I did see a very nice Red Mk1 Cortina down in the Esk valley on Sunday morning. A rare sight indeed now. 1 Quote Link to comment Share on other sites More sharing options...
Banga Posted August 15, 2023 Author Share Posted August 15, 2023 13 hours ago, Alfashark said: Loving the presentation on this mate! I was sitting at The Cabbage Tree having a coffee in Tirau when you parked up on Saturday - I was going to wander over and ask if you were an Oldschooler, but the Barry brigade had wandered over to you and started yarning so I left you to it. Thanks! Yeah seems to attract a few yarns - it’s a 50/50 split as to whether modern engine etc is cool or sacrilege. Quote Link to comment Share on other sites More sharing options...
Banga Posted August 15, 2023 Author Share Posted August 15, 2023 4 hours ago, Tiger Tamer said: I didn't see your car in Napier on the weekend, but I did see a very nice Red Mk1 Cortina down in the Esk valley on Sunday morning. A rare sight indeed now. Quite possible he was with the Cortina club, a red Mk1 left a bit earlier than the rest of us. This was on the way to Napier on Saturday morning, the other green mk2 has a 2.3 duratec in it and the white mk1 has a super charged 302-. 8 Quote Link to comment Share on other sites More sharing options...
Alfashark Posted August 15, 2023 Share Posted August 15, 2023 23 minutes ago, Banga said: Thanks! Yeah seems to attract a few yarns - it’s a 50/50 split as to whether modern engine etc is cool or sacrilege. Not knowing about what was under the bonnet, I wouldn't have picked such a modern transplant - When you spun around to catch up with that gaggle of Mk1s, it sounded just like a healthy, period-modded engine. 1 Quote Link to comment Share on other sites More sharing options...
rossnzwpi Posted April 1 Share Posted April 1 How's that magnesium cam cover holding up to scuffing and repainting? I have an older engine with magnesium castings and was told they would continue corroding even after painting unless re-passivated. Quote Link to comment Share on other sites More sharing options...
Banga Posted April 2 Author Share Posted April 2 On 01/04/2024 at 13:00, rossnzwpi said: How's that magnesium cam cover holding up to scuffing and repainting? I have an older engine with magnesium castings and was told they would continue corroding even after painting unless re-passivated. So far so good, the cam covers on ST170s are notorious for the paint falling off. Suspect I’ll need to redo it in the future. Quote Link to comment Share on other sites More sharing options...
