SOHC Posted July 26, 2013 Share Posted July 26, 2013 Where would one obtain a non detergent monograde engine oil now days for old sidevalve engines in cars that have have no oil filtration systems, and have a sludge build up? someone recommended briggs and stratton oil but I think thats more for air coold lawnmoer motors, Quote Link to comment Share on other sites More sharing options...
Raizer Posted July 26, 2013 Share Posted July 26, 2013 Brigs and Stratton oil is a non detergent SAE30 oil. 1 Quote Link to comment Share on other sites More sharing options...
tortron Posted July 26, 2013 Share Posted July 26, 2013 Supercheap sell monograde its often on special as well i use 30sae in the truck make sure to drop the sump and clean it out twice as often as you would change the filter Quote Link to comment Share on other sites More sharing options...
tortron Posted July 26, 2013 Share Posted July 26, 2013 Edit. Supercheap sells penrite in 1 & 2.5l or go to repco, if they look at you funny ask for running in oil. They carry a different brand in 4l jugs Quote Link to comment Share on other sites More sharing options...
SOHC Posted July 27, 2013 Author Share Posted July 27, 2013 I have droped the sump and scooped all the thick black shit out, I have an oil filter on this car but its not a full flow filter, it just bleeds off a very small amount of oil and that goes thrugh the filter and back to the sump. Would B&S oil be ok to use in a car? its a side vlave v8 Quote Link to comment Share on other sites More sharing options...
Raizer Posted July 27, 2013 Share Posted July 27, 2013 Would B&S oil be ok to use in a car? its a side vlave v8 Will be fine if it needs non detergent 30 weight. Quote Link to comment Share on other sites More sharing options...
SOHC Posted July 27, 2013 Author Share Posted July 27, 2013 I hope it had ZDDP aswell Quote Link to comment Share on other sites More sharing options...
tortron Posted July 27, 2013 Share Posted July 27, 2013 I hope it had ZDDP aswell it soaks into the engine components after 60 years i would say theb&s oil is fine, perhaps more expensive than an oil brand brand... Also there is no real reason you cant run a modern oil, technology has come a long way since the 40s Quote Link to comment Share on other sites More sharing options...
SOHC Posted July 27, 2013 Author Share Posted July 27, 2013 it soaks into the engine components after 60 years i would say theb&s oil is fine, perhaps more expensive than an oil brand brand... Also there is no real reason you cant run a modern oil, technology has come a long way since the 40s The problem this engine has a bit of crap in it, I was worryed about it all coming loose, I did clean as much out as possable. fuchs do an oil for lawnmowers witch is about $19 for 4 leters. The 2nd motor I am putting togeather I will run modern oil as it will have a full flow filter and everything in new and clean, Quote Link to comment Share on other sites More sharing options...
gibbon Posted August 9, 2013 Share Posted August 9, 2013 grade 65 aviation engine oil (MIL spec 1065) is an SAE 30 weight non detergent oil. Quote Link to comment Share on other sites More sharing options...
V8Pete Posted August 9, 2013 Share Posted August 9, 2013 You could probably get it from this guy //oldschool.co.nz/index.php?/user/5960-shandawg/ 1 Quote Link to comment Share on other sites More sharing options...
KIRK Posted August 9, 2013 Share Posted August 9, 2013 yeh go lawnmower shop. ghp or whatever is the same as fuchs but cheaper. Fuchs is all g. aviation oil is ashless dispersant spec. Its cleans like fancy detergent but without the embers/ash left behind. Duno if that's what you want. I don't think so cos its made to be used with a filter. It takes the ash and shit away from combustion chamber so no preignition which is bad for planes. Dunno if you want that shit floating around in the oil if you have no filter Quote Link to comment Share on other sites More sharing options...
gibbon Posted August 10, 2013 Share Posted August 10, 2013 a lot of aircraft engines only have screens rather than spin on filters (although most are converted to them now)... in saying that, we also change the oil every 25 hours Quote Link to comment Share on other sites More sharing options...
shandawg Posted August 11, 2013 Share Posted August 11, 2013 You could probably get it from this guy //oldschool.co.nz/index.php?/user/5960-shandawg/ Yep I have Total Rubia S 30 SAE 30 monograde in 5L and 20L packs, OS deals as always Quote Link to comment Share on other sites More sharing options...
