Chris.QCR Posted January 11, 2014 Share Posted January 11, 2014 You have done a great job on this Josh ! Really impressed Quote Link to comment Share on other sites More sharing options...
BlownCorona Posted January 11, 2014 Author Share Posted January 11, 2014 Cheers everyone I am very pleased with the result! Quote Link to comment Share on other sites More sharing options...
BlownCorona Posted September 23, 2014 Author Share Posted September 23, 2014 So as many of you may know, i completly rebuilt this bike as per the previos posts, and it looked excellent, however the first ride, i had major engine faults, and for the last year or so i have been trying to fix this, but general lack of parts availible, and a massive underlieing design flaw in the head has seen me waste way too much money on it. so ive pulled the pin on the honda cb50 as we see it above. now i have an 80s suzuki ax100, which has a frame almost identicle to the cb50, which i will be swapping all of the custom parts onto. this will give me more overall power, a higher top speed and acceleration, keep the same dimensions as the cb, and parts are plentiful seeing as they still actually make them. the cb tank will fit right on with minor adjustments to the mounting points (its sitting back a bit in the pic). i am also looking at fitting the cb50s disk front end, and its 17" rims and tires, (the ax is 18") and the tires are fucked. it started pretty good, but started to run away and generally ran really weird, shut it off quickley, and took a look at the carby, it has no needle lol. can get a full rebuild kit with everything except the carb body for like $14 which is refreshing after the cb fiasco, 1 Quote Link to comment Share on other sites More sharing options...
BlownCorona Posted October 27, 2014 Author Share Posted October 27, 2014 got the carb kit and this runs pretty well, however havnt riden it yet cause the rear sproket resembles a circular saw blade and the chain is the wrong pitch (presume these two issues are closely related) however all of my nice parts are finding there way onto the ax frame and not putting up much of a fight so far. what ive done so far is; fit the honda cb50 front shocks (that ive only just put a seal kit in) cb50 forks suit my disk brake front end, so ive upgraded to that, this also means going from an 18" front wheel to a 17" decided i quite like the stagard look of 18" on the rear and 17" on the front, and this will save the headache of trying to change the cb50 rear wheel to 428 pitch chain and fit it to the ax frame. fit the custom painted cb50 fuel tank fit the custom brat seat (almost) got the engine running with the carb rebuilt kit. to do in the near future; fit the drag bars, will trim them to be more narrow like i wanted to do for the cb fit the much smaller (2") cb50 speedo, to suit the cb front wheel. fit new sprocket and chains detab and paint this frame red as per original build. 3 Quote Link to comment Share on other sites More sharing options...
BlownCorona Posted November 2, 2014 Author Share Posted November 2, 2014 made alot of progress today. in the process of pulling an 80cc engine out of the garage for z181200, i discovered a 420 pitch sproket that fits the ax100 engine and allows me to run the CB rear wheel and chain which had had new bearings/sprokets/chain etc etc fitted. so cheers Andy for essentially saving me ~$140 on a new sproket kit and 18" rear tire! this made the bike ride able, and i took it around the block and its really rather quick! so i decided i really needed to fit up the seat and front break etc before riding it any more. ive also fitted and chopped down the drag bars and im loving the look. it needs the front headlight to look right but thats probably happening tomorrow. 6 Quote Link to comment Share on other sites More sharing options...
Chris.QCR Posted November 2, 2014 Share Posted November 2, 2014 Cool dude ! I've got red side covers for one of these if your keen Quote Link to comment Share on other sites More sharing options...
BlownCorona Posted November 2, 2014 Author Share Posted November 2, 2014 i have some damged side covers so i can mock up, i think im gonna run without covers, but il see what it looks like. good to know! Quote Link to comment Share on other sites More sharing options...
BlownCorona Posted November 23, 2014 Author Share Posted November 23, 2014 headlight mounted, (might change to slimline brackets) seat mounted, engine running well (needs a good hard run to clear out i think) front brake hooked up started making the bracket for the speedo aswell. will see how it turns out, but im liking it so far, will also serve as a place to mount a couple idiot lights. an overall image 1 Quote Link to comment Share on other sites More sharing options...
BlownCorona Posted December 24, 2014 Author Share Posted December 24, 2014 For those not following the tech thread i had about this, took in for a ride totalling about 250kms all up. made the trip all good, but had a weird spluttering issue, turns out a part of the carb rebuild kit was to blame. thats now all fixed and its running very well now. took it for a blat up the port hills this evening. so much fun also could a mod please edit the title of this thread to read 'flibois CB50 turn AX100 brat' when you get a chance, cheers 4 Quote Link to comment Share on other sites More sharing options...
anglia4 Posted December 24, 2014 Share Posted December 24, 2014 I think if you go back to the first post and edit it there you can change the title yourself Quote Link to comment Share on other sites More sharing options...
BlownCorona Posted December 24, 2014 Author Share Posted December 24, 2014 Not sure if it's just me, but I can't edit posts around a week old Quote Link to comment Share on other sites More sharing options...
TMC Posted December 24, 2014 Share Posted December 24, 2014 Will look good and hopefully go even better once i make your expansion chamber 1 Quote Link to comment Share on other sites More sharing options...
anglia4 Posted December 24, 2014 Share Posted December 24, 2014 Never mind, turns out I can do it for you haha 1 Quote Link to comment Share on other sites More sharing options...
BlownCorona Posted December 24, 2014 Author Share Posted December 24, 2014 Can't wait for that pipe! Quote Link to comment Share on other sites More sharing options...
BlownCorona Posted December 24, 2014 Author Share Posted December 24, 2014 And cheers anglia haha Quote Link to comment Share on other sites More sharing options...
TMC Posted December 29, 2014 Share Posted December 29, 2014 Pipe all tacked up. Tig it up tomorrow 5 Quote Link to comment Share on other sites More sharing options...
Chris.QCR Posted December 29, 2014 Share Posted December 29, 2014 Metal master ! This is gonna make some good noise ! 2 Quote Link to comment Share on other sites More sharing options...
BlownCorona Posted December 29, 2014 Author Share Posted December 29, 2014 That's so wild! Quote Link to comment Share on other sites More sharing options...
BlownCorona Posted December 30, 2014 Author Share Posted December 30, 2014 over the last couple days i did a quick respray of the frame and a few other parts. it now resembles my original vision that the CB was built to. i made up some basic headlight mounts, they are much lower profile than the factory ones, pretty happy with the result. just need to find somewhere nice to mount the key now pretty excited with that crazy tuned pipe that TMC has made. its going to complete the look of the bike and it will look and sound like a classic race bike Quote Link to comment Share on other sites More sharing options...
BlownCorona Posted December 30, 2014 Author Share Posted December 30, 2014 i would also like to find a metal oil tank, and a way to hide the battery away, but all in due course Quote Link to comment Share on other sites More sharing options...
