Rookie Posted February 13, 2013 Share Posted February 13, 2013 Let hipsters be hipsters KK, don't hate. 1 Quote Link to comment Share on other sites More sharing options...
flyingbrick Posted February 13, 2013 Share Posted February 13, 2013 May have to get creative with rear sprocket. I had to weld/ machine up a custom single speed sprocket to suit my compagnolo as shits not on the shelf. Quote Link to comment Share on other sites More sharing options...
lowlancer Posted February 13, 2013 Author Share Posted February 13, 2013 Although I don't really understand the allure of fixed gear, I don't have an issue with it. It's just something different. Meh. Thinking I just get a cog and get it machined out with a thread to suit chucked on. Brock Lee is having a look for me though so I hope he can suss me out something. Quote Link to comment Share on other sites More sharing options...
Llama Posted February 14, 2013 Share Posted February 14, 2013 When I was in wellington, there were people on little push scooters going along in the traffic... WTF /spam Quote Link to comment Share on other sites More sharing options...
lowlancer Posted February 15, 2013 Author Share Posted February 15, 2013 Swapped 40 tooth chain ring to out side of 52 tooth chain ring. Chain now runs straight as a gate, aka is lined up with rear cog. Not ideal but rideable. Chur Quote Link to comment Share on other sites More sharing options...
KIRK Posted February 15, 2013 Share Posted February 15, 2013 what the heck kinda hub is that anyway? Quote Link to comment Share on other sites More sharing options...
lowlancer Posted February 15, 2013 Author Share Posted February 15, 2013 Exactly. Mysterious little cunt of a thing. Has "Suzue" on the outside, but "Suntour" stamped where axle goes. I think Suzue made Suntour hubs for a spell. In any case, has a larger than standard thread diameter (right term?) so it's a cunt. Quote Link to comment Share on other sites More sharing options...
KIRK Posted February 15, 2013 Share Posted February 15, 2013 so is it a feehub but instead of slide on splined sprockets they screw on? before when you were explaining it I thought it was a screw on freewheel like bmx. My 80s spec araya alloy 27 inch rims have suzue hub but it had a screw on suntour 5 speed free wheel that I took off and replacing with bmx single sprocket freewheel Quote Link to comment Share on other sites More sharing options...
KIRK Posted February 15, 2013 Share Posted February 15, 2013 u sure the whole thing that carries the sprockets doesn't unscrew off the hub? Quote Link to comment Share on other sites More sharing options...
lowlancer Posted February 16, 2013 Author Share Posted February 16, 2013 Yeah is exactly that - no spline, just thread. My bad if I explained it wrong. Sheldon has a comparison page of the two styles, I just used what was there as frame of reference. It probably does come off, unsure how though as I don't have the tool. It adjusts play in the bearings too though, so dunno if I can just lose it and replace it in any case? I wonder whether I can just take it off somehow and do as you did. Quote Link to comment Share on other sites More sharing options...
lowlancer Posted February 16, 2013 Author Share Posted February 16, 2013 Is same as one on left except freewheel is on there. I was hoping to just get cogs to fit that freewheel so I could have like 3 on there for different stz. Need freewheel removal tool? Edit: see how the skewer/axle comes a mile out past the bearing? Seems like that would put huge load on it... thinking that's why mine has bent? 1 Quote Link to comment Share on other sites More sharing options...
KIRK Posted February 16, 2013 Share Posted February 16, 2013 i thought that might be the case. the thread is the same as all bmx freewheel so don't worry about that. take to bike shop they will remove it fo free unless they're dick faces. or used a punch and hammer. The thread on it is same as the bottom bracket thread. use a thread on ring nut thing off bb non drive side as spacer Quote Link to comment Share on other sites More sharing options...
KIRK Posted February 16, 2013 Share Posted February 16, 2013 this thing: http://www.samcycling.com/images/miche%20lockring.jpg Quote Link to comment Share on other sites More sharing options...
lowlancer Posted February 16, 2013 Author Share Posted February 16, 2013 Bottom bracket thread? Last sentence made no sense to me either. Will take to bike shop and say holla take this cunt off and gizz new freewheel kit for this slut Quote Link to comment Share on other sites More sharing options...
KIRK Posted February 16, 2013 Share Posted February 16, 2013 click the link to that picture and you will understand. edit: you wind that thing on then tighten the freewheel onto it. usualy without a spacer it wont be inline with your drive sprocket. assuming the rear wheel is asymmetrical to suit a multispeed bike Quote Link to comment Share on other sites More sharing options...
KIRK Posted February 16, 2013 Share Posted February 16, 2013 I can take a pic of my bikes setup if you still don't understand what im talkn bowt edit: obviously the correct way to do it is to rebuild the wheel and change the hub spacing to suit(ie make it symmetrical) but this way I invented means you don't have to buy 36 new spokes and nipples etc etc. rot808 Stephen used a massive brass plumbing nut to space out his freewheel lol Quote Link to comment Share on other sites More sharing options...
lowlancer Posted February 16, 2013 Author Share Posted February 16, 2013 Yeah I get it, all g. But chuck ap ic up just in case I'm barking up le wrong tree. Stuck it all back together and went for a hoon before. Fuck single chain line with no shit attached is efficient as balls, cranks up hills easy as. Was a bit rattly though and chain dropped off going over rough stz. Quote Link to comment Share on other sites More sharing options...
lowlancer Posted February 16, 2013 Author Share Posted February 16, 2013 Here is other side Here is chainage arrangement which works okay And I took all the fucked, ripped vinyl shit off my seat and it looked cool as balls and doesn't hurt my balls so it's staying 1 Quote Link to comment Share on other sites More sharing options...
lowlancer Posted May 7, 2013 Author Share Posted May 7, 2013 Got a bmx hub on, is like a 42/18 ratio. Lets me get up the many hills whilst still ruining my virgin legs. Pretty much done for the time being Quote Link to comment Share on other sites More sharing options...
alfalfa Posted May 8, 2013 Share Posted May 8, 2013 Nice work, looking pretty good! Get some toe straps for more efficient pedalling and then it will be done Quote Link to comment Share on other sites More sharing options...
