phtmbl Posted November 16, 2012 Share Posted November 16, 2012 i know you want an all in one system, this is exactly what i have at home if you can not find what you are looking for http://www.trademe.co.nz/motors/car-parts-accessories/mitsubishi/interior/auction-532140317.htm Quote Link to comment Share on other sites More sharing options...
KKtrips Posted November 16, 2012 Share Posted November 16, 2012 Can you get sandwich plate to go between oil filter and block? Thats where I have my oil temp and pressure senders. Have had oil temp up to 140degrees on the track so seems to be a decent place to tell you oil is getting hot From memory VW aircooleds have the oil filter in the sump pan - so there is no where you can slot it between...edit - like this Quote Link to comment Share on other sites More sharing options...
KIRK Posted November 16, 2012 Share Posted November 16, 2012 from experience of planes with big vw engines lol. cht is best and fastest indicator. pressure and temp = meh. they will follow suit. maybe just retain the low oil pressure light. Quote Link to comment Share on other sites More sharing options...
cletus Posted November 17, 2012 Share Posted November 17, 2012 did you figure out why it overheated? i thought vws were pretty much impossible to cook unless the fan stops working or the shrouds arent fitted properly Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted November 18, 2012 Author Share Posted November 18, 2012 haha, my fan broke not sure how long i was driving till i noticed the generator light was on. maybe only a couple of mins, but was enough to get hot, only keen to get one now as i have a very un kown spec engine, so i guess will see and yeah, i have seen the snadwitch plates around, but i lack this thing you call a filter. Quote Link to comment Share on other sites More sharing options...
Llama Posted November 18, 2012 Share Posted November 18, 2012 0-120 degrees & 0-160 psi Smiths dual gauge - supposed to be for oil and water almost at bottom of page http://www.gaugeguys...ths/classic.htm These gauges would probably do, but do be warned the bulbs are a pain in the arse. Wiring them is slightly a pain, and if they break you might as well get a new one. (I've heard it is possible to repair, but looks rather tricky and might not work the same) Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted November 18, 2012 Author Share Posted November 18, 2012 dont worry about that, i wont be jumping in to get a smiths I did 8 years of work on Classic cars I know all about smith gauges haha VDO would be my first choice Screw it, might just try get a sender for te gauge I have No idea where from tho. Quote Link to comment Share on other sites More sharing options...
10Speed Posted November 18, 2012 Share Posted November 18, 2012 i lack this thing you call a filter. a strainer is all a real man needs Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted November 18, 2012 Author Share Posted November 18, 2012 I should probabaly clean mine out... Quote Link to comment Share on other sites More sharing options...
10Speed Posted November 18, 2012 Share Posted November 18, 2012 one word "5 ft lbs" (which I am sure I didn't need to say) - someone had 'glued' two studs in on my current engine... am now using 8 to 6mm step studs )-: Quote Link to comment Share on other sites More sharing options...
KIRK Posted November 18, 2012 Share Posted November 18, 2012 I saw this house with like 10 buses and 50 bugs on the way back from dromagedon when I bypassed Hamilton, nearly at tirau I think. u should go there when u come up tmrw? Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted November 19, 2012 Author Share Posted November 19, 2012 that would be Vee Dub Shoppee Quote Link to comment Share on other sites More sharing options...
