mikey Posted October 14, 2012 Share Posted October 14, 2012 Now that I've finished punching myself in the cock... Is it possible to helicoil the brake line input on aluminium brake calipers? Suggestions on where to go to fix my epic blowout? Or DIY the go (preferred)? Quote Link to comment Share on other sites More sharing options...
KKtrips Posted October 14, 2012 Share Posted October 14, 2012 Repco are a supplier of these guys.. http://www.afsrecoil...ad_Inserts.html They do NPT.. (I guess you meant NPT and not NTP) Go to the "find your product" button.. Quote Link to comment Share on other sites More sharing options...
beachlander Posted October 14, 2012 Share Posted October 14, 2012 We should have the size at work you need if you get stuck Quote Link to comment Share on other sites More sharing options...
DJZ Posted October 14, 2012 Share Posted October 14, 2012 Chances of them being tapered and not a metric thread are pretty slim, what calipers are you using again? Quote Link to comment Share on other sites More sharing options...
Testament Posted October 14, 2012 Share Posted October 14, 2012 only the male thread is tapered on NPT threadforms 1 Quote Link to comment Share on other sites More sharing options...
bubblegoose Posted October 14, 2012 Share Posted October 14, 2012 it choose a solid insert (ie time-sert) over a wire coil for any fluid fitting just me being pedantic but hey i like to throw my 2c about occasionally Quote Link to comment Share on other sites More sharing options...
mikey Posted October 14, 2012 Author Share Posted October 14, 2012 Repco are a supplier of these guys.. http://www.afsrecoil...ad_Inserts.html They do NPT.. (I guess you meant NPT and not NTP) Go to the "find your product" button.. Oh easy. Will go and pay them a visit. Chances of them being tapered and not a metric thread are pretty slim, what calipers are you using again? Oh, I just guessed NPT. I just checked them with a gauge and they seem just slightly bigger than 1mm pitch. But way smaller than 1.25. So I'm a bit unsure... They're r32 GTR 4 pot Sumitomo calipers. Quote Link to comment Share on other sites More sharing options...
DJZ Posted October 14, 2012 Share Posted October 14, 2012 Should be M10x1, all of the Nissan 4 pots are I think. What did you do to them? Quote Link to comment Share on other sites More sharing options...
mikey Posted October 14, 2012 Author Share Posted October 14, 2012 I think you're probably right. I pulled the threads on one of them by being a spaz and not really watching what I was doing. Quote Link to comment Share on other sites More sharing options...
Unclejake Posted October 14, 2012 Share Posted October 14, 2012 only the male thread is tapered on NPT threadforms This I did not know Quote Link to comment Share on other sites More sharing options...
mikey Posted October 14, 2012 Author Share Posted October 14, 2012 So I think the reason i managed to dick this up so badly is because I have an NPT flare nut in there. So managed to hand tighten it a couple of turns, thought it was OK but it was cross threaded. So will track down some helicoils and some non NPT flare nuts. It'll be interesting tapping the hole without hitting the flare seat... Quote Link to comment Share on other sites More sharing options...
KKtrips Posted October 14, 2012 Share Posted October 14, 2012 Most recoil kits come with a bottoming tap and you won't have to go the whole way down anyway as flare nuts don't have thread on the bottom 5mm(ish)... Quote Link to comment Share on other sites More sharing options...
