mikey Posted April 6, 2012 Share Posted April 6, 2012 I'm quickly running out of ideas, maybe one of you clever chaps has an idea. There's a knock coming from the rear when I load or unload the suspension in the 240z. Easily reproducable buy taking my foot off the gas whilst in gear. There'll be a loud thunk. Then another when I'm on the gas again. Doesn't seem to happen going over bumps. I've checked all bolts on control arms, tightened strut gland nuts, checked diff mount and bolts. All bushes look good. Swaybar looks to have been fouling on control arm due to mis adjustment, fixed that. There's some play in 2 unit's so will replace those but doubt it's the cause. Strut top nuts are tight. I sectioned my struts so its possible one of the welds on a tube has cracked, doesn't seem likely but. Any other ideas? Quote Link to comment Share on other sites More sharing options...
JoKer Posted April 6, 2012 Share Posted April 6, 2012 U joint Quote Link to comment Share on other sites More sharing options...
sheepers Posted April 6, 2012 Share Posted April 6, 2012 yea it sounds like it might be drive line. like drive shaft unis having a spazz. go and see Aiden at drive in services in new lynn, he is a proper top dude. Quote Link to comment Share on other sites More sharing options...
kyteler Posted April 6, 2012 Share Posted April 6, 2012 The S30Z is notorious for rear end knock. My brother's did it, we replaced the diff mount and then it developed again and again, it was the mount. You're likely to find the mount whilst it may seem OK, is poked. I did a quick search for you (because it's common it's fairly easy to find) here are some opinions; 1. the most common source of rear end "clunks" are either the front differential isolator, or your moustache bar bushings. 2. Check the front differential mount !!... lay under the car, put your strong arm/hand under the nose of the differential -PUSH UP AS HARD AS YOU CAN. If you can push the front of the differential up - the front mount is broken - replace it. Secondly - there is a "strap" that runs over the top of the nose of the differential - make sure that is in place and stoping the upward movement of the nose of the differential - that strap is there to help prevent breaking the front differential mount - by limiting the upward movement of the nose of the differential under acceleration from rest. 3. As a data point, my Z has very high miles. To get rid of my clunks, had to replace 4 out of 6 UJoints, all 4 of the stub axle bearings, differential mount, transmission mount, and the mustache bar bushings. Plus I had a chattering clutch. It was so multi symptomatic that I couldn't figure out what the hell was going on until I started replacing each part. Every repair made things better. Also, http://www.z-car.com/240zdiff.htm Quote Link to comment Share on other sites More sharing options...
mikey Posted April 6, 2012 Author Share Posted April 6, 2012 Ok, I'll start by replacing the suspect uni's in the morrow, and if I still have issues replace the diff mount. I think I just wanted to rant more than anything. Dem cars can be tricky little beggers. Cheers fellas. Quote Link to comment Share on other sites More sharing options...
kyteler Posted April 6, 2012 Share Posted April 6, 2012 Yeah, it's a concerning noise too. Definitely worth a vent and also something that you'll want to get well and truly sorted before you have twice the power Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted April 6, 2012 Share Posted April 6, 2012 Unfamiliar with setup but can you solid mount it? replace the bush with something turned up? Quote Link to comment Share on other sites More sharing options...
mikey Posted April 7, 2012 Author Share Posted April 7, 2012 Went to replace the suspect uni's and I think I've found the issue. There appears to be masses of play in the diff, if you spin the input flange back and forward it'll give quite the clunk. All this started after a track day. I'll pull it out when I do the engine swap but I think I might as well upgrade it then since its just a vlsd Quote Link to comment Share on other sites More sharing options...
kyteler Posted April 9, 2012 Share Posted April 9, 2012 Are you still running an R180? Because if you are then you might as well put an R200 in it instead. It's a much better option to cater for what you'll be throwing at it. Quote Link to comment Share on other sites More sharing options...
Hemi Posted April 9, 2012 Share Posted April 9, 2012 this^^^ 4 spider diffs pwn Quote Link to comment Share on other sites More sharing options...
mikey Posted April 9, 2012 Author Share Posted April 9, 2012 Yep. Roger that. R200 swap is probably the way I'll go. Cheers guys Quote Link to comment Share on other sites More sharing options...
