mad_max Posted January 9, 2012 Share Posted January 9, 2012 Got a 4k dx wagon as a daily and a bit of fun every now and then and its all of a sudden gained some issues It started making a noise which i assumed was tappets which happened after a skid attempt from my sober driver one night. It wasnt too bad but then all of a sudden it started a loud tappet like noise when reving and wont idle properly (sounds like a rota) its like its down a cylinder or something. Anyone find this familiar? or know what it could be? I dont know alot about them and dont want to rip it all apart unless i know what im looking for. Could just be easier to get new motor... Cheers Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted January 9, 2012 Share Posted January 9, 2012 Sounds like maybe a rocker or something has come totally loose and is not working at all. Pull off rocker cover and inspect / set all your tappets. Quote Link to comment Share on other sites More sharing options...
Mitch.W Posted January 9, 2012 Share Posted January 9, 2012 that tapping noise could be your intake/exhaust gasket onto the head has broken thats a pretty common problem with them. takes like 15 mins and like 30bux to do so its not a major. Quote Link to comment Share on other sites More sharing options...
mad_max Posted January 10, 2012 Author Share Posted January 10, 2012 Yea, my mate told me it could be that, so just chuck a new gasket on it you reckin? Might as well give it a go, easier than transplant Quote Link to comment Share on other sites More sharing options...
mad_max Posted January 10, 2012 Author Share Posted January 10, 2012 Is there a way i can check if thats what it is? would that be a reason for it not idling and having next to no power? Quote Link to comment Share on other sites More sharing options...
Steelies Posted January 11, 2012 Share Posted January 11, 2012 have you checked stuff under the rocker cover? Quote Link to comment Share on other sites More sharing options...
Mr Revhead Posted January 11, 2012 Share Posted January 11, 2012 Is there a way i can check if thats what it is? would that be a reason for it not idling and having next to no power? Possibly if it's the intake. But if it is the intake I wouldn't think the noise would be as described. Yank that cover off and have a look. Is easy. Bonus you will get your hands dirty and get to use tools. Quote Link to comment Share on other sites More sharing options...
Mr Revhead Posted January 11, 2012 Share Posted January 11, 2012 Oh, easy to check the exhaust, will be leaving carbon deposits. And to check if its intake, while it's running spray some crc/brakekleen etc around the manifold. revs will increase if it's sucking in there Quote Link to comment Share on other sites More sharing options...
b1600v8 Posted January 11, 2012 Share Posted January 11, 2012 You need to get that rocker cover off, real easy. Could be a collapsed lifter if no obvious damage under rocker cover? Edit: if you still can't find problem be worth doing a compression test. Quote Link to comment Share on other sites More sharing options...
Dell'orto Posted January 11, 2012 Share Posted January 11, 2012 Probably a manifold gasket leak, does it have extractors? How high did they rev it when doing skids? Wont be a collapsed lifter, ought to be solid in that Quote Link to comment Share on other sites More sharing options...
mad_max Posted January 11, 2012 Author Share Posted January 11, 2012 Been under cover, looks algood, Sussed a replacement 5k but would rather find the problem with this to keep as spare. Sounds like something loose in there or something, if i keep at steady rpm theres a rattle every now and then but if accelerating it overpowers every other sound, can still hear after trying to drown out with music (figured if i cant hear it its not happening.lol) sounds normal at idle (with choke as wont idle untill hot (used to idle str8 away) Quote Link to comment Share on other sites More sharing options...
KKtrips Posted January 11, 2012 Share Posted January 11, 2012 Its super hard to diagnose audible faults over the net - most probably pay to have someone who knows a thing or two to take a gander at it. Quote Link to comment Share on other sites More sharing options...
