dave123456789 Posted November 21, 2011 Share Posted November 21, 2011 Hey guys, i decided to start a topic here since my buy thread is turning into a tech thread. I have removed the 4 bolts that attach the drive shaft to the diff but no matter how high or low i jack the rear end i cant seem to be able to remove it as the bolts still stick through to the diff. There must be an easier way, ive been trying shit for the last hour or so. Thanks Quote Link to comment Share on other sites More sharing options...
Unclejake Posted November 21, 2011 Share Posted November 21, 2011 Photo? Are you jacking from the body or the diff housing? Quote Link to comment Share on other sites More sharing options...
JoKer Posted November 21, 2011 Share Posted November 21, 2011 slide it into/towards the gearbox a tad? should be a half inch or so of room to moove, get drip pan read as oil wil come out the back of the box etc if your removing whole drive shaft from there back etc Quote Link to comment Share on other sites More sharing options...
Beaver Posted November 21, 2011 Share Posted November 21, 2011 you should be able to take out the bolts no? (sorry for silly statement, but yeh, you should be abel to remove the bolts and it will drop off) Quote Link to comment Share on other sites More sharing options...
dave123456789 Posted November 21, 2011 Author Share Posted November 21, 2011 I dont see how the bolts can come out, I tried that first but they dont budge even when hitting with a hammer. Have tried to slide towards gearbox also but it wont move that way either. I originally jacked from body then once that didnt work chucked the jack under the diff and raise it and all it did was get a little more lose Quote Link to comment Share on other sites More sharing options...
Beaver Posted November 21, 2011 Share Posted November 21, 2011 interesting. I suspect a photo or two would help if possible Quote Link to comment Share on other sites More sharing options...
dave123456789 Posted November 21, 2011 Author Share Posted November 21, 2011 Ill MS paint something up, 1 sec Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted November 21, 2011 Share Posted November 21, 2011 does it have u bolts that clamp the universal?? Though i dont think they do on these Quote Link to comment Share on other sites More sharing options...
dave123456789 Posted November 21, 2011 Author Share Posted November 21, 2011 does it have u bolts that clamp the universal??Though i dont think they do on these No u bolts that I can see. Heres a paint of all thats there. Quote Link to comment Share on other sites More sharing options...
Borgweiser Posted November 21, 2011 Share Posted November 21, 2011 Large hammer ( take your biggest hammer and double it ) start smashing towards gearbox Quote Link to comment Share on other sites More sharing options...
dave123456789 Posted November 21, 2011 Author Share Posted November 21, 2011 Large hammer ( take your biggest hammer and double it ) start smashing towards gearbox Im guessing hit that shroud part I pictured? Quote Link to comment Share on other sites More sharing options...
Borgweiser Posted November 21, 2011 Share Posted November 21, 2011 yes, just hit all of it repeatedly, jack diff so you can rotate it whilst smashing.. or get a chisel in there Quote Link to comment Share on other sites More sharing options...
Hemi Posted November 21, 2011 Share Posted November 21, 2011 yes, just hit all of it repeatedly, jack diff so you can rotate it whilst smashing..or get a chisel in there this , just make sure you are not under it when doing so , taking a diff to the nose/face / elbowskin is not pleasant Quote Link to comment Share on other sites More sharing options...
dave123456789 Posted November 21, 2011 Author Share Posted November 21, 2011 Such a cunty job to do when all I want is a working speedo I think ive moved it a bit, was way too hard to swing a hammer properly but sticking a couple of flat heads seems to be slowly working. Got a sore back from lying on gravel so will try again in a bit. Quote Link to comment Share on other sites More sharing options...
Unclejake Posted November 21, 2011 Share Posted November 21, 2011 Have you tried running the speedo cable with an electric drill and watching the dial? You will be well slutted if your problem does not require the tailshaft housing to be removed. Quote Link to comment Share on other sites More sharing options...
