What is this gunk and why is it spewing in to my air cleaner
DangerousPerson
I replaced the air filter on my car the other day and noticed this shit coming up through the oil breather hole in to my air cleaner which in turn gets sucked in to my carb and makes the car stall and go mental.
What is causing it and how can I stop it? I have temporarily removed the hose that connects it and stuffed it with a rag but I'm wanting to know why it's happening.
Chur
I would just say its condensation mixed with blow by then
Stop revving your poor little k series so hard haha
I would imagine the sinde of your oil cap would look the same.
i would recommend running your oil breather to a coke bottle or something, to prevent that going through the carb as it could cause problems later on
another fix is to do full load stationary cooling tests, this will clear out the cobwebs and let you know for sure if you have the dreaded herpesgasket.
more then likely it just a case of build due to lack of proper use .
we call this rocker cheddar in the industry
