MACKAZ Posted August 1, 2011 Share Posted August 1, 2011 Question. KE70 Diff, will a E20 or E30 head go in?? Thanks.. Quote Link to comment Share on other sites More sharing options...
phatt20 Posted August 1, 2011 Share Posted August 1, 2011 yep. , only starlets have the smaller axle size. might just have to change the pinion flange, so be careful with regards to preload. Quote Link to comment Share on other sites More sharing options...
MACKAZ Posted August 1, 2011 Author Share Posted August 1, 2011 Thank you muchly... Makes life that much easier ... Quote Link to comment Share on other sites More sharing options...
Toucan Posted August 1, 2011 Share Posted August 1, 2011 I believe that to be slightly misleading advice. KE20 is small as B code diff. Starlets can be X or larger U code. KE30 is U code. KE70 is U code. With work most can fit each other. But for a straight bolt on fix, stick to the same series of diff Quote Link to comment Share on other sites More sharing options...
phatt20 Posted August 1, 2011 Share Posted August 1, 2011 i dont think it was misleading? he asked if they would go in, they do. sometimes you have to mix and match models to get the correct ratio for your intended use so the same series diff isnt always the best option. Quote Link to comment Share on other sites More sharing options...
Dell'orto Posted August 1, 2011 Share Posted August 1, 2011 Late KE20's have U code diffs also Quote Link to comment Share on other sites More sharing options...
Roman Posted August 1, 2011 Share Posted August 1, 2011 i dont think it was misleading? he asked if they would go in, they do. sometimes you have to mix and match models to get the correct ratio for your intended use so the same series diff isnt always the best option. From the question I'd guess he's talking about swapping the diff heads between diff housings. In which case, you'd need U code diff head into U code housing etc? Quote Link to comment Share on other sites More sharing options...
MACKAZ Posted August 1, 2011 Author Share Posted August 1, 2011 Spot on there bro. Im pretty sure its dropped the carrier pin, he wants me to lock it up but Im not a fan of locked diffs on the road. Just wanna get something and throw it in. Its a KE70 slant front if that makes any difference. Quote Link to comment Share on other sites More sharing options...
phatt20 Posted August 1, 2011 Share Posted August 1, 2011 i dont think it was misleading? he asked if they would go in, they do. sometimes you have to mix and match models to get the correct ratio for your intended use so the same series diff isnt always the best option. From the question I'd guess he's talking about swapping the diff heads between diff housings. In which case, you'd need U code diff head into U code housing etc? indeed, but he asked if ke20 and 30 diff heads will fit straight in to his ke70 housing, which they ALL will, as even if they are b code, they still use the same size axles. i saw no need to confuse the issue for him. Quote Link to comment Share on other sites More sharing options...
kpr Posted August 2, 2011 Share Posted August 2, 2011 hmm actually, dude at work might still have a locked U-code center. will ask him. forgot about it when you asked other day. would get him rolling at least Quote Link to comment Share on other sites More sharing options...
