My name is Russell Posted January 25, 2011 Share Posted January 25, 2011 Want to get turrets fitted before cage goes in so cage can go to them and the front strut towers, planning on chopping out the parcel tray etc to fit them. Anyways, anyone got the dimmensions for folding one up? otherwise have to choose between these two which seem a bit pricy for a box. http://www.burtonpower.com/rd218a.html http://www.palmside.co.nz/product_pcid_15278.html Over n out Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted January 25, 2011 Author Share Posted January 25, 2011 I guess the measurement really depends on how long the shocks are that I'm going to use and ideally needs to be taken with the car at rideheight and should be when the shock's half way through it's stroke. So mab require them first. Quote Link to comment Share on other sites More sharing options...
Gaz Posted January 25, 2011 Share Posted January 25, 2011 I guess the measurement really depends on how long the shocks are that I'm going to use and ideally needs to be taken with the car at rideheight and should be when the shock's half way through it's stroke. So mab require them first. Spot on. I would make sure whatever you put in is large enough to fit a coilover in incase you choose to go that direction at a later date. Gaz Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted January 25, 2011 Author Share Posted January 25, 2011 They only reason im doing it is for coilover, my leaves are two soft as have been reset to much. Get these you recon? http://www.burtonpower.com/gzgp6-2069.html Quote Link to comment Share on other sites More sharing options...
drtdvl Posted January 25, 2011 Share Posted January 25, 2011 GAZ have a decent name in the UK - a lot of the 205 and 306 guys use them in their fast road /occasional track day cars. Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted January 25, 2011 Author Share Posted January 25, 2011 Yeah GAZ is good, tis whats is in the front and back of escort at the moment rear leaves just require aditional support. cracked the 10mm low profile bump stops in half from the leaves being to soft. Quote Link to comment Share on other sites More sharing options...
drtdvl Posted January 25, 2011 Share Posted January 25, 2011 funky... Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted January 25, 2011 Author Share Posted January 25, 2011 the escort not being lowered 5 inches would probably help also but meh. Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted January 25, 2011 Author Share Posted January 25, 2011 Guess the next question is what LB springs to run Quote Link to comment Share on other sites More sharing options...
peteretep Posted January 25, 2011 Share Posted January 25, 2011 You can get extra leaves added to your leaf springs to make them stiffer you know Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted January 25, 2011 Author Share Posted January 25, 2011 yeah you would have to add a truckload of leaves as they are inverted at the mo, would rather do turrets for weight, adjustability, performance? and have them tied into cage while at it. Never even crossed my mind to do it untill i raced it and realised they were smidge to soft. dont get any axle tramp however so happy with that Quote Link to comment Share on other sites More sharing options...
Gaz Posted January 25, 2011 Share Posted January 25, 2011 Buy them direct from GAZ as its WAY cheaper. Cant member where but they give a 10% discount to someone here, Hit up Zep, he put me onto it. For escort they have two types listed also, will see if I can dig up old emails to Gaz. So I take it this means your going 4/5 link? Gaz Quote Link to comment Share on other sites More sharing options...
mkcortina Posted January 25, 2011 Share Posted January 25, 2011 For that sort of stuff i find rally design to be cheaper and the same thing. I think RD supply Burton with a few items http://www.rallydesign.co.uk/product_info.php?cPath=609_681_684&products_id=4315 Quote Link to comment Share on other sites More sharing options...
kpr Posted January 25, 2011 Share Posted January 25, 2011 make your own? i just used 4" exhaust tube in kp, and 5" in my trueno. hole saw,weld, done. get coil overs then make turret length to suit them Quote Link to comment Share on other sites More sharing options...
Bling Posted January 25, 2011 Share Posted January 25, 2011 Genius what thickness is the exhaust tubing? Quote Link to comment Share on other sites More sharing options...
kpr Posted January 25, 2011 Share Posted January 25, 2011 not sure, just standard size. 1.6mm? is thicker than what the car is made from anyway. cut to similar shape as the ones in link, so have large area to weld to. used 3mm for top plate. kp i run a spherical bearing in the top plate. ae85 just normal bolt in s13 coilover should be pics in project threads VVVV Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted March 14, 2011 Author Share Posted March 14, 2011 Anyone got any idea how long and dia spring this requires? Quote Link to comment Share on other sites More sharing options...
Valiant Posted March 14, 2011 Share Posted March 14, 2011 Just been buying springs for my Anglia. 65mm id seems the most common diameter, lengthes 200,250,300, may be 350 and 400 mm too. Check with your supplier first as some rates/sizes are harder to find. Yes exhaust tube makes mint turrets. Quote Link to comment Share on other sites More sharing options...
kpr Posted March 14, 2011 Share Posted March 14, 2011 easyest way, is to buy your suspension of choice first. then make turrets to fit it. need to buy spring length to suit your shock length. and yeh 65mm id seems to be most common. Quote Link to comment Share on other sites More sharing options...
Gaz Posted March 14, 2011 Share Posted March 14, 2011 I have seen one some race cars people mounting the top of the shock/strut onto the rollcage itself. Have you thought about this as it would be strong as. Plus then strength of turret is irrelevant. Gaz Quote Link to comment Share on other sites More sharing options...
