Unclejake Posted January 17, 2011 Share Posted January 17, 2011 I am trying to find some material to make a cam lobe out of. This will just be a single cam lobe operating like a bellcrank on a moving rope (like found in a rock climbing ascender) to act as a rope brake for a charity project I am building. The lobe needs to be 20-25mm thick but I need to be able to weld to it which makes cast steel less attractive and alloy no good. Does anyone have any ideas as to what I could rob to either: 1) Find a preformed cam lobe 20mm thick or greater 2) Find some 25mm thick stainless (about the same size as the palm of your hand) that I could fabricate a cam out of? Thanks ever so much etc. XXXOOOXXXanal Quote Link to comment Share on other sites More sharing options...
peteretep Posted January 17, 2011 Share Posted January 17, 2011 Have you talked to a laser cutter? 20-25mm is getting toward the high end of thickness but as it's small it still wouldn't cost too much, less than 3 digits I would think, plus they can cut it almost to your exact shape. They can also do mild or stainless Quote Link to comment Share on other sites More sharing options...
Unclejake Posted January 17, 2011 Author Share Posted January 17, 2011 I haven't talked to a laser cutter. Finding the materials has been what I was concentrating on I reckon I could make this cam lobe out of a stainless steel towball if anyone has one Quote Link to comment Share on other sites More sharing options...
jakesae101 Posted January 17, 2011 Share Posted January 17, 2011 ill have a look around my workshop there's all sorts of random stuff Quote Link to comment Share on other sites More sharing options...
Unclejake Posted January 17, 2011 Author Share Posted January 17, 2011 ^ that would be awesome. Good luck! Quote Link to comment Share on other sites More sharing options...
jakesae101 Posted January 17, 2011 Share Posted January 17, 2011 I know for sure I can get a piece that's 10-15 mm thick may or may not be s/steel but would be 2 times the size your after Quote Link to comment Share on other sites More sharing options...
V8Pete Posted January 17, 2011 Share Posted January 17, 2011 Stink. About 2 months ago I had a huge 25 mm plate cut and the offcut would've been ideal. 25 mm's like twice the price of 20 mm too. Quote Link to comment Share on other sites More sharing options...
Jif Posted January 17, 2011 Share Posted January 17, 2011 I have a cam lobe that was smashed out of an engine thats about 25ish Quote Link to comment Share on other sites More sharing options...
bubblegoose Posted January 17, 2011 Share Posted January 17, 2011 weld together 5 x 5mm plates? maggoos mufflers etc will sell you circular scrap bits from cutting flanges (i payed a buck each there about 6mm) Quote Link to comment Share on other sites More sharing options...
eke_zetec_RWD Posted January 17, 2011 Share Posted January 17, 2011 u goin port rd sprints? i could bring some dwn. i have steel up to 40mm thick, just cut rind it urself? Quote Link to comment Share on other sites More sharing options...
Unclejake Posted January 17, 2011 Author Share Posted January 17, 2011 ^ I am not able to but friends will be there (racing) and they could grab a bit from you??? That would be so cool. Let my try and confirm the ideal thickness tomorrow. I should be able to work it out BubbleG - I thought about that, but would much rather a solid lump. Thanks though. Jif - that lobe would be cast wouldn't it? Quote Link to comment Share on other sites More sharing options...
KKtrips Posted January 17, 2011 Share Posted January 17, 2011 Tried metal works? Quote Link to comment Share on other sites More sharing options...
Testament Posted January 17, 2011 Share Posted January 17, 2011 stubby piece of 40 or 50mm round bar? machine to suit? Quote Link to comment Share on other sites More sharing options...
Unclejake Posted January 17, 2011 Author Share Posted January 17, 2011 ^ that would work if I could find a bit of stainless like that - but so far I haven't Quote Link to comment Share on other sites More sharing options...
jakesae101 Posted January 18, 2011 Share Posted January 18, 2011 the thickest peice i could find was 15mm thick and mesures 160mm long and 60mm wide and has 1 hole in the middle of it Quote Link to comment Share on other sites More sharing options...
Unclejake Posted January 18, 2011 Author Share Posted January 18, 2011 Thanks for all the help team. I still can't work out the exact requirements so at risk of offending those who are trying to supply me stuff, I will do some harder thinking tomorrow. This project is getting complicated! Quote Link to comment Share on other sites More sharing options...
Testament Posted January 18, 2011 Share Posted January 18, 2011 is there a steel and tube stainless in wellinton? or sandvik? Quote Link to comment Share on other sites More sharing options...
QCADTA Posted January 18, 2011 Share Posted January 18, 2011 you cant machine it out of a solid piece of billet aluminium? i have an end cut off an ingot from tiwai bout the size of a dinner plate. Quote Link to comment Share on other sites More sharing options...
Unclejake Posted January 19, 2011 Author Share Posted January 19, 2011 Thanks for everything gents. I was guilty of over complicating this brake. I think I am sorted now and I already have the materials I need . Photos up in a week or so. Quote Link to comment Share on other sites More sharing options...
