4x4 body lift
shizzl
  • Replies 68
had a play with the truck after work.
took me 5mins to wind it up 25mm...its got 10mm left till it hits the max lift bump stops..
no point going higher without better shocks and ball joint flip..
the tyres measure up at 28"s, so if i went with 31"s id get another 37mm or so in lift, 62mm lift is ok...
plus the ground clearance isnt too bad either....\/ before 31"s....
oh the rear is standard as....stoked its leaf over axle too :queen:
and heres something id like to do to it, but i think the ecu wont take it, might lean out....unless theres a way of making it richer..
who wants to make me a manifold and sump drain??? :tongue:
yeah
lots of stuff out there to choose from so if you're not in a mega hurry you'll find something sweet
get a landrover :D
This.
Disco's are pretty good value and plenty of wrecked ones for parts as they aren't worth so much. not sure on strength of drivetrain, but I would guess probably ok although not cruiser/patrol size.
i seem to have purchased a engine for my zook. hopefully it will be ready for 4wd exploration by christmas or earlier. :D
i brought a 16valve mpi vitara motor. good thing i wanted to be a auto electrician for a while and know my way around.
So. OS 4wd trips? when, where, how stuck do you want me to get. :twisted:
