Beaver Posted May 3, 2010 Share Posted May 3, 2010 how much/if any play should there be in the rotor/dizzy shaft. the cortina has been pre-igniting after i turn if off, and if i put my foot down it just farts, and have bene told that its the timing (causing the pre-igniting atleast) ive noticed that there is quite a bit of play in one direction in the dizzy shaft, ie if can rotate one way quite a bit, but not the other. it was suggested that this is throwing out my timing at random times, as it doesnt always pre-ignite and on that note, can anyone tell me what else i can use a dizzy from? its a 1600 crossflow (1969 cortina) cheers Quote Link to comment Share on other sites More sharing options...
isnowi Posted May 4, 2010 Share Posted May 4, 2010 You should be able to turn it one way, but there should be some spring resistance (assuming there is a mechanical advance mechanism) could be that the springs that stop the little weights from flying too far out are broken. Quote Link to comment Share on other sites More sharing options...
Beaver Posted May 4, 2010 Author Share Posted May 4, 2010 yeh there is spring resistance. could just be my timing is way out to start with. ill check that and then see if it still packs a sad. Quote Link to comment Share on other sites More sharing options...
Unclejake Posted May 4, 2010 Share Posted May 4, 2010 Your running on issue will be caused by heat in the combustion chamber somewhere. Dizzy play is unlikely to be the fault. Timing too far advanced Combustion chamber fouled with carbon Running too lean Quote Link to comment Share on other sites More sharing options...
mjrstar Posted May 4, 2010 Share Posted May 4, 2010 Is it still running Vacuum advance? if so disconnect it and see if it helps. Quote Link to comment Share on other sites More sharing options...
Beaver Posted May 4, 2010 Author Share Posted May 4, 2010 Your running on issue will be caused by heat in the combustion chamber somewhere. Dizzy play is unlikely to be the fault.Timing too far advanced Combustion chamber fouled with carbon Running too lean i was at a mechanics/motorsport shop in town today picking up some stuff and the dude there herd the car do its thing as i turned it off and he straight away walked out and siad that my timing was out, and then confirmed this when i had trouble starting it. i told him that it doesnt always over run and often starts on the first crank, and he suggested play in the dizzy which would be throwing out my timing at some times and not others. Quote Link to comment Share on other sites More sharing options...
Horse25 Posted May 4, 2010 Share Posted May 4, 2010 i have a timing light if you dont have one, we could check when you bring that diff head around, also have checked your points gap? Quote Link to comment Share on other sites More sharing options...
David Posted May 4, 2010 Share Posted May 4, 2010 Have you changed any other parts on the ignition or intake side of things lately? Like new sparkplugs changed the plug gapping (has the electrodes burnt away)? Different type of plugs new air cleaner Different carb or manifold Vacuum advance pickup on different part of manifold Vacuum leak at intake gasket Fuel bowl level too low or blocked fuel filter Due to the 1600 combustion chamber design it tends to run on from concentrated heat very easily. If the timing was always running too advanced you should be able to make the motor PINK when throwing it into a too higher gear and putting the load on. (not good for the motor if so). Can be hard to hear in the 1600 if the exhaust is loud. I would guess the Cortina runs the likes of a Lucas 25D4 dizzy with a thumb adjuster on the vacuum advance Instead of the FoMoCo type in the escort 1600cc cross flow? Quote Link to comment Share on other sites More sharing options...
Beaver Posted May 4, 2010 Author Share Posted May 4, 2010 i have a timing light if you dont have one, we could check when you bring that diff head around, also have checked your points gap? yeh thatd be mint. nah i havent yet, havnt got any feelers. whens a good time to come around? im free most afternoons/eveings Quote Link to comment Share on other sites More sharing options...
Mr.Mk1 Posted May 4, 2010 Share Posted May 4, 2010 Dizzy was the culprit in my old Cortina w/1600. I tried everything else and it was the shaft bearing which was work, throwing the spark around all mad-like. I dropped in a spare one I had, timed it and it was mint! Quote Link to comment Share on other sites More sharing options...
Beaver Posted May 4, 2010 Author Share Posted May 4, 2010 Have you changed any other parts on the ignition or intake side of things lately? Like new sparkplugs changed the plug gapping (has the electrodes burnt away)? Different type of plugs new air cleaner Different carb or manifold Vacuum advance pickup on different part of manifold Vacuum leak at intake gasket Fuel bowl level too low or blocked fuel filter Due to the 1600 combustion chamber design it tends to run on from concentrated heat very easily. If the timing was always running too advanced you should be able to make the motor PINK when throwing it into a too higher gear and putting the load on. (not good for the motor if so). Can be hard to hear in the 1600 if the exhaust is loud. I would guess the Cortina runs the likes of a Lucas 25D4 dizzy with a thumb adjuster on the vacuum advance Instead of the FoMoCo type in the escort 1600cc cross flow? i didnt change anything before it started happening. since then i have tried another carb, and have put in new spark plugs, but no change. it makes a funny noise when you put the load on, have never experienced a pinking motor so not sure if thats the noise or not. but it doesnt sound right whatever it is..... ill check the timing asap and see if that shows anything up Quote Link to comment Share on other sites More sharing options...
Unclejake Posted May 4, 2010 Share Posted May 4, 2010 Dizzy was the culprit in my old Cortina w/1600. I tried everything else and it was the shaft bearing which was work, throwing the spark around all mad-like. I dropped in a spare one I had, timed it and it was mint! Yaeh. Good point and you should be able to see the spark jumping around with the timing light Quote Link to comment Share on other sites More sharing options...
Beaver Posted May 4, 2010 Author Share Posted May 4, 2010 got it sorted... points gap was wrong/non-existant. timing was fine cheers dave haha Quote Link to comment Share on other sites More sharing options...
