d.p.n.s Posted October 26, 2009 Share Posted October 26, 2009 hi all while im doing my engine bay i wanted to make up a strut brace but i cant go from strut to strut as there is no room between the motor and bonnet any ideas boys and girls? like going fron strut top to the rear of the fire wall ect ect ect cheers dan Quote Link to comment Share on other sites More sharing options...
Leebo3 Posted October 26, 2009 Share Posted October 26, 2009 Might be able to do one similar to this, still be pretty tight room wise though Thats a mustang stz one. Sure there is no room under bonnet? Grab some play dough and use that to check if need be. Quote Link to comment Share on other sites More sharing options...
bubblegoose Posted October 26, 2009 Share Posted October 26, 2009 or bonnet lifters? full engine bay brace? forgot the ones going back to the firewall Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted October 26, 2009 Share Posted October 26, 2009 Have seen speedway escorts do the above Just tested my 4doors one on my FE3 last night, looks like it fits wonder of the CA is taller. Do they go under tension or compression? or both? if tension could you squeeze some strap across? just throwing the silly idea out there. Is there defiantly no space over top? can be deceptive. lower engine? Quote Link to comment Share on other sites More sharing options...
Raizer Posted October 26, 2009 Share Posted October 26, 2009 I would think your firewall would need to be beefed up a bit if your wanting to brace to it Do they go under tension or compression? Neither Quote Link to comment Share on other sites More sharing options...
bubblegoose Posted October 26, 2009 Share Posted October 26, 2009 compression Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted October 26, 2009 Author Share Posted October 26, 2009 thanks guys Joe would it still work the same if i changed in a wee bit? the yellow would be welded around the engine bay using maybe 25x5mm flat plate or bigger and the red made removable using 25mm tube or bigger dan Quote Link to comment Share on other sites More sharing options...
Testament Posted October 26, 2009 Share Posted October 26, 2009 I would be wary about stiffening infront of the strut towers before talking to someone from MSNZ im sure ther is some rule about not stiffening impact zones - it might not matter for old cars but im not sure yet as i might do something like this on my car if it is legal Quote Link to comment Share on other sites More sharing options...
bubblegoose Posted October 26, 2009 Share Posted October 26, 2009 thanks guysJoe would it still work the same if i changed in a wee bit? the yellow would be welded around the engine bay using maybe 25x5mm flat plate or bigger and the red made removable using 25mm tube or bigger dan either way would be a compromise compared to a straight bar how about not using a strut brace? maybe just double skin the towers seam weld the engine bay and slam on some fender braces Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted October 26, 2009 Author Share Posted October 26, 2009 thanks guysJoe would it still work the same if i changed in a wee bit? the yellow would be welded around the engine bay using maybe 25x5mm flat plate or bigger and the red made removable using 25mm tube or bigger dan either way would be a compromise compared to a straight bar how about not using a strut brace? maybe just double skin the towers seam weld the engine bay and slam on some fender braces im planing on seam welding the engine bay and gusseting the rails to the firewall Quote Link to comment Share on other sites More sharing options...
RT Posted October 27, 2009 Share Posted October 27, 2009 Dan have you checked out my capri one? I'm pretty sure the same design would work for your escort. can't see it too well in this shot but you get the idea. Quote Link to comment Share on other sites More sharing options...
bubblegoose Posted October 27, 2009 Share Posted October 27, 2009 shit, just remembered there is a bubble arch mk1 and a wide body Capri down at one of the body shops and im 99% sure one of the has some form of strut tower bracing on the outside. i will get some pics next time im down there Quote Link to comment Share on other sites More sharing options...
Gaz Posted October 27, 2009 Share Posted October 27, 2009 How about dropping engine down? Will need to make new sump but get the bonus of lower center of gravity. That is how I have mounted my CA. Mine is also further bacak however. Gaz Quote Link to comment Share on other sites More sharing options...
bubblegoose Posted October 27, 2009 Share Posted October 27, 2009 do you have room for one like that? Quote Link to comment Share on other sites More sharing options...
