Gaz Posted September 14, 2009 Share Posted September 14, 2009 Take the cover off the coilpacks and see if it makes any difference. Gaz Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted September 14, 2009 Author Share Posted September 14, 2009 ok so its had plenty of time to cool down. went out side started it up....sounded mint let it heat up till it started running on 3 with the coil pack cover off. i started to pull the plugs on the coils got to coil pack 2 pulled the plug no change. so i need another coil pack to try. cheers dan Quote Link to comment Share on other sites More sharing options...
Gaz Posted September 14, 2009 Share Posted September 14, 2009 Hold 5. Garage check. Gaz Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted September 14, 2009 Author Share Posted September 14, 2009 are they the same as the rb? Quote Link to comment Share on other sites More sharing options...
Burntrubber Posted September 14, 2009 Share Posted September 14, 2009 Your issue probably is the coil pack but my megasquirt running wasted spark had the same problem it was bad 12v feed to the coils. Been wasted it would only fire 1 of the 2 cylinders connected to that coil pack had me stumped for ages. Quote Link to comment Share on other sites More sharing options...
Gaz Posted September 14, 2009 Share Posted September 14, 2009 Im positive I have spares but I cant find em. Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted September 14, 2009 Author Share Posted September 14, 2009 Your issue probably is the coil pack but my megasquirt running wasted spark had the same problem it was bad 12v feed to the coils. Been wasted it would only fire 1 of the 2 cylinders connected to that coil pack had me stumped for ages. i did think that mate but i ran to good for agers while cold and just fucked out when it was hot. cheers dan Quote Link to comment Share on other sites More sharing options...
Burntrubber Posted September 14, 2009 Share Posted September 14, 2009 Yeah same here get 30min round town and if I took it on the open road and cained it about 10min before it would start. Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted September 14, 2009 Author Share Posted September 14, 2009 Yeah same here get 30min round town and if I took it on the open road and cained it about 10min before it would start. ture!!! ill try the coil pack 1st then go from there. cheers dan Quote Link to comment Share on other sites More sharing options...
Hemi Posted September 14, 2009 Share Posted September 14, 2009 Yeah same here get 30min round town and if I took it on the open road and cained it about 10min before it would start. ture!!! ill try the coil pack 1st then go from there. cheers dan can just about garuntee its the coilpack they are the most annoying fucktards things out / they are 20+ years old now so no surprised .. the last one that happened was at the palmy swapmeet i drove all the way there on 3 cylinders pretty much . you can find the fucked one by letting it idle on three cylinders and pull the plug for the coils out individually , a change in tone indicates a rooted one . i vote to chnage it to wasted spark as mine are constantly failing and at the most inconvienient times too Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted September 14, 2009 Author Share Posted September 14, 2009 Yeah same here get 30min round town and if I took it on the open road and cained it about 10min before it would start. ture!!! ill try the coil pack 1st then go from there. cheers dan can just about garuntee its the coilpack they are the most annoying fucktards things out / they are 20+ years old now so no surprised .. the last one that happened was at the palmy swapmeet i drove all the way there on 3 cylinders pretty much . you can find the fucked one by letting it idle on three cylinders and pull the plug for the coils out individually , a change in tone indicates a rooted one . i vote to chnage it to wasted spark as mine are constantly failing and at the most inconvienient times too yip #2 coil pack just borrowed one from my mates rb20 and it ran like a dream. will rd test tomorrow to make sure. as for wasted spark.....already looking in to it man seems the way to go. cheers dan Quote Link to comment Share on other sites More sharing options...
BobbyBreeze Posted September 14, 2009 Share Posted September 14, 2009 I have a spare set of coilpacks if you want to have them? I also owe you $50 EDIT: this is dave/brock-lee Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted September 14, 2009 Author Share Posted September 14, 2009 I have a spare set of coilpacks if you want to have them? I also owe you $50 EDIT: this is dave/brock-lee sounds good to me dave. cheers dan Quote Link to comment Share on other sites More sharing options...
Gaz Posted September 14, 2009 Share Posted September 14, 2009 Im prob going to go with this http://www.trademe.co.nz/Trade-Me-Motor ... 068421.htm Cheap as. Gaz Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted September 14, 2009 Author Share Posted September 14, 2009 Im prob going to go with thishttp://www.trademe.co.nz/Trade-Me-Motor ... 068421.htm Cheap as. Gaz thats the same one i was looking at mate. seems like a good price. dan Quote Link to comment Share on other sites More sharing options...
Requiemk Posted September 14, 2009 Share Posted September 14, 2009 Its quiet a straight forward process converting some commy or similar wasted spark setup to work and alot cheaper. Quote Link to comment Share on other sites More sharing options...
ProZac Posted September 15, 2009 Share Posted September 15, 2009 Can help out with converting to wasted spark if you like man, have some twin post coils you can have to free if ya want. Or can do new ones pretty cheap through work. Quote Link to comment Share on other sites More sharing options...
Hemi Posted September 15, 2009 Share Posted September 15, 2009 i thought you had to reset the ignition curve if you were going to convert with the gm coils?? http://www.nicoclub.com/articles.php?id=251827 *EDIT* , just realised that walkthrough eliminates the ignitor pack too Quote Link to comment Share on other sites More sharing options...
Gaz Posted September 15, 2009 Share Posted September 15, 2009 Its quiet a straight forward process converting some commy or similar wasted spark setup to work and alot cheaper. But the trademe one includes NEW packs. Quote Link to comment Share on other sites More sharing options...
ProZac Posted September 16, 2009 Share Posted September 16, 2009 Isnt all you need to do to convert to wasted spark is get a couple of twin post coils (mitsy diamante v6 or similar), connect the output trigger from the ignitor for cyl's 1 and 4 to one coil, and cyl's 2 and 3 to the other? Quote Link to comment Share on other sites More sharing options...
