d.p.n.s Posted March 26, 2009 Share Posted March 26, 2009 morning all i was wondering af anyone has heared of any jap pistons being used in a 2.0 pinto turbo. i read somwhere about ej20 pistons being used but cant for the life of me find it. any ideas ? dan Quote Link to comment Share on other sites More sharing options...
kyteler Posted March 26, 2009 Share Posted March 26, 2009 You after things that won't leak? The only Japanese -> Ford stuff that's popping into me noggin at the moment is the use of L16/18 Datsun cranks in the Kent blocks? Maybe it's Pinto blocks.. I forget. I imagine though it is highly likely there is a piston equivalent. Quote Link to comment Share on other sites More sharing options...
fuel Posted March 26, 2009 Share Posted March 26, 2009 what's the bore size of a pinto? find that out and go through the ACL piston catalogue finding pistons with the same or slightly larger bore size and then put together a list of 'maybes' and then look at each of them individually regarding piston pin size and crown height from the pin etc etc. Quote Link to comment Share on other sites More sharing options...
eke_zetec_RWD Posted March 27, 2009 Share Posted March 27, 2009 ej20 are 92mm so slight over bore needed. could measure them up ect tho re pin height n dia.... why tho? good range available for them..... Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted March 27, 2009 Author Share Posted March 27, 2009 a cheap alternitive to cossy pistons Quote Link to comment Share on other sites More sharing options...
QCADTA Posted March 27, 2009 Share Posted March 27, 2009 alot of people use mark 2 transit pistons apparently. give a compression ratio of 8.2-1. how much boost ya gonna be running? Quote Link to comment Share on other sites More sharing options...
corrupt Posted March 27, 2009 Share Posted March 27, 2009 I know of a dude using some sort of subaru pistons in his turbo pinto, he was also saying hes getting custom rods made up to suit though, ill ask him next time i see him. Quote Link to comment Share on other sites More sharing options...
forced Posted March 28, 2009 Share Posted March 28, 2009 Mitsi 6G72 are 91.1mm, got lots in my garage. Only mine are for a 4 valve head. Pajero 3.0, V3000 etc are a 2 valve head and same size but don't have any. Do you want the compression height measuring? Steve Quote Link to comment Share on other sites More sharing options...
eke_zetec_RWD Posted March 28, 2009 Share Posted March 28, 2009 cossie pistons are lush. just find some. usually cheap. Quote Link to comment Share on other sites More sharing options...
Gaz Posted March 30, 2009 Share Posted March 30, 2009 Mitsi 6G72 are 91.1mm, got lots in my garage. Only mine are for a 4 valve head. Pajero 3.0, V3000 etc are a 2 valve head and same size but don't have any. Do you want the compression height measuring?Steve Have heard of 4g63 ones being used. That size sounds good. Gaz Quote Link to comment Share on other sites More sharing options...
eke_zetec_RWD Posted March 30, 2009 Share Posted March 30, 2009 Mitsi 6G72 are 91.1mm, got lots in my garage. Only mine are for a 4 valve head. Pajero 3.0, V3000 etc are a 2 valve head and same size but don't have any. Do you want the compression height measuring?Steve Have heard of 4g63 ones being used. That size sounds good. Gaz hmmm 4g63 are like 85mm i think. was lookn at them for my zetec 84.8mm Quote Link to comment Share on other sites More sharing options...
fuel Posted March 30, 2009 Share Posted March 30, 2009 yeah 4G63 are 85mm bore, same as L18 I think and 2T/2T-G. Quote Link to comment Share on other sites More sharing options...
sholdowa Posted March 30, 2009 Share Posted March 30, 2009 does that mean you've got those v6 ones spare??? (: Quote Link to comment Share on other sites More sharing options...
fuel Posted March 30, 2009 Share Posted March 30, 2009 I will have the GTO twin turbo pistons spare, yes. Quote Link to comment Share on other sites More sharing options...
