OSM Garage Posted June 7, 2009 Share Posted June 7, 2009 you can put them in a bit misaaligned quite easily and it makes a sound like yours does Yeah it does sound a bit nasty. Cool ill give that a try. Otherwise you must be fucken stoked! Off my face! Quote Link to comment Share on other sites More sharing options...
mixmasterlex Posted January 8, 2010 Share Posted January 8, 2010 Sweet vid. Sounds bad-boy! Quote Link to comment Share on other sites More sharing options...
OSM Garage Posted January 8, 2010 Share Posted January 8, 2010 it was a sigh of relief to drive it. After that vid i took it up to 16psi. HOLY SHIT BALLS! Lost traction in 1st, 2nd and 3rd gear. 155/80/13's dont help tho Quote Link to comment Share on other sites More sharing options...
QCADTA Posted January 9, 2010 Share Posted January 9, 2010 been following this with interest. persistance has lead to great reward for you, well done. how long before new tread on the rears? Quote Link to comment Share on other sites More sharing options...
mikuni Posted January 9, 2010 Share Posted January 9, 2010 Dude, i couldnt stop smiling all day! Might take it for a cruise next weekend. Awesome! jap meet next weekend, you should get it along for that if you aren't planning too already. Quote Link to comment Share on other sites More sharing options...
OSM Garage Posted January 9, 2010 Share Posted January 9, 2010 Its far from road worthy now unfortunately. probably turn up in my V3000! Quote Link to comment Share on other sites More sharing options...
infinite Posted March 22, 2010 Share Posted March 22, 2010 can we have some pics of the modifyed gearbox? as i have a l200 box im going to have todo something with? but was thinking of geting the evo flywheel machined down to look like a l200 and run the l200 clutch and pressure plate? Quote Link to comment Share on other sites More sharing options...
fuel Posted March 22, 2010 Share Posted March 22, 2010 hey infinite the evo flywheel is bigger diameter than the L200/L300/Sigma flywheel too, and also the RWD flywheel has space for a spigot bearing while the VR-4/Evo flywheels don't. You could perhaps use a flywheel from a 2.4 16V L300 van or L200/Triton ute 1994 onwards as they are 7 bolt flywheel and RWD, but may too be too big diameter, but they aren't stepped like the Evo flywheel. This is the main reason why you don't use an Evo block, best to use a VR-4 or Starion block with Evo head. Quote Link to comment Share on other sites More sharing options...
infinite Posted March 22, 2010 Share Posted March 22, 2010 yeah i know that now lol whats to stop me geting a 6 bolt welded machined flat then redrilled to 7 bolt? can u weld up the old holes or what? Quote Link to comment Share on other sites More sharing options...
fuel Posted March 22, 2010 Share Posted March 22, 2010 if you are going to go through that effort why not just get a custom flywheel made up from scratch? I would trust a flywheel which has been welded and drilled back into.. that's just asking for it to explode at high rpm and launch through your bonnet/feet. Quote Link to comment Share on other sites More sharing options...
infinite Posted March 23, 2010 Share Posted March 23, 2010 if you are going to go through that effort why not just get a custom flywheel made up from scratch? I would trust a flywheel which has been welded and drilled back into.. that's just asking for it to explode at high rpm and launch through your bonnet/feet. Yeah i figured thats the affect u would get!. ive talked to motor preps in oto today and he is going to machine the flywheel and then it will be the size of l200 figure this is the best way, i could get one of the guys todo it at work but its going to be a bit of pissing arround and ill have todo it on a sat/sun and i want this now!! lol going to cost about 300 - 400 all up balanced... Quote Link to comment Share on other sites More sharing options...
fuel Posted March 23, 2010 Share Posted March 23, 2010 so what are you going to do about fitting a spigot bearing? Quote Link to comment Share on other sites More sharing options...
infinite Posted March 23, 2010 Share Posted March 23, 2010 that gets machined in to... Quote Link to comment Share on other sites More sharing options...
OSM Garage Posted March 23, 2010 Share Posted March 23, 2010 Here are some snaps of my gearbox Hope it helps Quote Link to comment Share on other sites More sharing options...
infinite Posted March 23, 2010 Share Posted March 23, 2010 So u havent actuley had to CUT the bellhousing to make the clutch turn that just needs a bit of a grind? and then to make the starter work u have to just slightly move it closer? there is a guy on trademe who has said are u sure? as 7 bolt flywheel is larger and rubs on bellhousings on l200/sigma boxes what are these? subaru_gt (26 ) 9:35 pm, Tue 23 Mar ive done it mate.you need to change the ring gear on the flywheel other wise the starter wont line up .i can do that to for 300 10:14 pm, Tue 23 Mar http://www.trademe.co.nz/Browse/Listing.aspx?id=278630483 I was thinking hes all crap? i will be geting my l200 flywheel tonight so will see if the ring gear is the same size or not! i was to beleave its a differnt size... Cause if this works all i need todo is grind the bellhousing and put the ring gear on and im done? Quote Link to comment Share on other sites More sharing options...
infinite Posted March 27, 2010 Share Posted March 27, 2010 hey what sorta clutch plate u using a l200 one? im guessing i have to run evo 3 pressure plate l200 clutch plate and will the l200 release bearing work? Quote Link to comment Share on other sites More sharing options...
wiserkid Posted July 7, 2010 Share Posted July 7, 2010 Hey mate I have just joined this site.But was wandering who did your wiring from the ex lancer to the evo.Im in the process of doing one myself.It's a 82 ex lancer would you have any wiring diagrams etc....would be great cheers. Quote Link to comment Share on other sites More sharing options...
OSM Garage Posted July 11, 2010 Share Posted July 11, 2010 Its running a Microtech computer os the wiring diagram is for Microtech. I have a wiring diagram for stock EX Lancer though Quote Link to comment Share on other sites More sharing options...
DJZ Posted October 4, 2010 Share Posted October 4, 2010 Do a skid Quote Link to comment Share on other sites More sharing options...
cute wee gem Posted October 25, 2010 Share Posted October 25, 2010 Looks like you're doing a good job Certainly better than my first try Quote Link to comment Share on other sites More sharing options...
