Yowzer Posted June 27, 2008 Share Posted June 27, 2008 Yeah, so I just stuck an electric pump on the crown as the mechanical wasn't working. The pump works sweet, but it pumps too much fuel which then floods the carbie as there's no fuel return line. What do I need to do to solve this? Cheers Quote Link to comment Share on other sites More sharing options...
peteretep Posted June 27, 2008 Share Posted June 27, 2008 you'll need a fuel regulator and a return fuel line Quote Link to comment Share on other sites More sharing options...
MACKAZ Posted June 27, 2008 Share Posted June 27, 2008 What stz pump you throw on dude? One of those little square buggers? Quote Link to comment Share on other sites More sharing options...
Yowzer Posted June 27, 2008 Author Share Posted June 27, 2008 Nah its a round cylinder sorta thing. 1.5Ltr/Min Quote Link to comment Share on other sites More sharing options...
MACKAZ Posted June 27, 2008 Share Posted June 27, 2008 Airtek brand? Checked float level? those pumps(if Airtek) are internally regulated. Had one on my 4.0l in stockcar with weber carb on it. That had no return line, but did similar thing due to needle valve being stuck. Quote Link to comment Share on other sites More sharing options...
Yowzer Posted June 27, 2008 Author Share Posted June 27, 2008 Turns out it was the carb that was the prob, but it sorted itself out. Cheers for the help though Quote Link to comment Share on other sites More sharing options...
Yowzer Posted June 27, 2008 Author Share Posted June 27, 2008 Airtek brand? Checked float level? those pumps(if Airtek) are internally regulated. Had one on my 4.0l in stockcar with weber carb on it. That had no return line, but did similar thing due to needle valve being stuck. Yeah, seems to be the same problem Quote Link to comment Share on other sites More sharing options...
NewGuy Posted June 28, 2008 Share Posted June 28, 2008 Airtek brand? Checked float level? those pumps(if Airtek) are internally regulated. Had one on my 4.0l in stockcar with weber carb on it. That had no return line, but did similar thing due to needle valve being stuck. Yeah, seems to be the same problem Airtek ftw Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted June 28, 2008 Share Posted June 28, 2008 you need to hook up the return. I had same problem with mine so added electrical pump as I couldn't find a good 3 pipe mechanical pump. I toyed with a regulator as well but the carbs don't like ANY pressure so it just dropped the needle valve all the time. you'll potentially have to take the top off the carb to pop the valvce back in properly so it doesn't continue to flood... I got a fitting off this dude who had an m series with a 2 pipe pump on it. it's got the return built into the banjo fitting that goes on the supply. has a small ball vlave with a spring or soemthing. either way it works fine. you might be able to get one off an 18r as they sometimes run the same system. will take a pic soonish and post up so you see what I mean Quote Link to comment Share on other sites More sharing options...
Rusted Posted June 29, 2008 Share Posted June 29, 2008 Just rev it more to use up your 1.5l per minute flow. Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted June 29, 2008 Share Posted June 29, 2008 ^ cone. alas, pic-chur anywho it shows teh fitting. you need one of these coz aisin carbs don't have returns and prolapse at the mere thought of pressure I had an adjustable carb style (0-4psi) reg for mine but it didn't work at all so I gave it back to the girl at appco with a 'big diff'. Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted June 29, 2008 Share Posted June 29, 2008 also lowl at my choke not being hooked up. never run without a choke with one of these carbs, its intensely gay. and don't hook the secondary up mechanical - it's too abrupt without a secondary accelerator pump Quote Link to comment Share on other sites More sharing options...
Yowzer Posted June 29, 2008 Author Share Posted June 29, 2008 I was running without the choke for awhile coz it stopped working. Looks like someone had been messing around with it so it was a bit wacked out. And yeah, mechanical secondary didn't work very well. Haven't had a problem with the carb flooding anymore though, it seemed to solve the problem itself. Bit random but atleast it saves me a bit of time till it fucks out again Quote Link to comment Share on other sites More sharing options...
Yowzer Posted June 29, 2008 Author Share Posted June 29, 2008 How does the choke work? Its some sort of auto jobbie that runs of the exhaust heat isnt it? Seems mine broke sometime in the past so its been converted to manual. Which is gayish Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted June 29, 2008 Share Posted June 29, 2008 yeah runs off exhaust heat/ shit as idea. I'm used to no choke now, usually they don't work properly anyway. the one on original carb sure as hell didn't, but it made it easier to drive than this one. lol. just gotta make sure battery is decent in case you fuck it up toomuch Quote Link to comment Share on other sites More sharing options...
fuel Posted June 30, 2008 Share Posted June 30, 2008 I just recently put an electric fuel pump on the Viva as the original one was leaking and it seems to be running fine. It's one of those square facet pumps and it must have an internal regulator or something as it stops pumping so much when the carb bowl is full. Quote Link to comment Share on other sites More sharing options...
MACKAZ Posted June 30, 2008 Share Posted June 30, 2008 Called an "interruptor pump" serious Quote Link to comment Share on other sites More sharing options...
lowlancer Posted June 30, 2008 Share Posted June 30, 2008 Might be a dumb question, but is it a high pressure-low flow or other way round? Why don't you just get one with low pressure, hi flow and slam a wee reg on it? Quote Link to comment Share on other sites More sharing options...
MACKAZ Posted June 30, 2008 Share Posted June 30, 2008 Most of them have a 2-6psi rating, internally regulated and AFAIK are medium flow. Quote Link to comment Share on other sites More sharing options...
