Newguys 2nd Dolly Sprint
NewGuy
  • Replies 48
i vote the sodomoite to be at the next os trackday with its 16 valves of sodom
Im hoping to be there....
What do you mean by what u said, Be honest.
He wants to sodomize you, is what he meant.
I don't want to be rear ended
After this whole weekend working on the car, bogging the welds up
Hung 3 of the doors i still felt like i was not getting anywhere.
My aim is to get a Wof
Not Panel And paint etc etc
I Keep Saying im going to make a list and i have and i havent in a sense.
So this is what i think i have to do before going for a wof
1.Sort My Doors out so that the open and close nicely and line up etc
2. Attach Bonnet
3. Attach Number Plates Half done one i carn't find my front one at the moment!!!! Founded them
4. Sort SteeringdONE
5. Get Front Left parking Light and indicator going. doNE
6. Position Driving Lights
7. Bleed the brakes to make sure they all workin mint
8. Patch Driver Door A pillar Rust hole Done
9. Patch Engine Bay Rust hole by Speedo cable. Done
10. Patch Rust hole on either side of engine were bonet stops go. Done
11. Patch the gearbox cover. Done
12. Decide on the Rear Number plate light arrangement. Decide
13. Primer Doors, Boot, Bonet.
14. Install Turbo.
15. Install some horns. Done got some Shitty Airhorns FTW
16. Tightened up Oil Pump Bolts to stop it leaking. Done
Car now has no oil leaks
What i can think of over like a hour tonight.
Having the night off the car to gather my thoughts.
Im going to print this off tomorrow and decide on which tasks to do, Work threw them that way so i feel and know im getting somewhere.
Want to sit a warrent late next week
ummm long time watcher - first time typer here.... :mrgreen:
Loving this build. What colour will it be?
A guy I worked with in Christchurch did a ground up rebuild on his Sodo and its really mint!
Would love to get me a rag-top Herald one day and repower it with Toyota gear or perhaps a Holden V6!! :shock:
On ya!
I thpught you said you were gonna lower it? :shock:
Haha, you need to get OS low?
No point in going much lower, we have fuck loads of speed humps in tga.
I carn't fit a can under my chassis, lol.
When i had the old rubber on i could get the jack under it sweet, then when i went to jack it up tonight to swap sprints i could only just get the jack under the car by lifting the car up a bit.
Then wehn i dropped it back down it was sitting on the jack lol.
Had to put her back up and sit it on blocks lol
Will wait try got see smiths engineering about making some 2inch lowering springs up for me.
Just want to make sure the car is gunna be all good mechanically etc.
What's that bottle meant to achieve or whatever?
Ahhh well my plastic one leaks, as the seal at the top, Some Steel Pressed ring is all rusted and eaten away.
And also is a old fashion way of a header tank.
There is only one in and out for fluid and air. As you know cooling systems do not like airlocks.
On this car when you get a airlock the cooling works pretty crappy, water flow disappears and helps overheating.
This way when the system needs water it is sucked from the bottom of the tank, and is replenished pushed out easily.
The top hose will then be working as a swirl pot to bleed air out of the system if there is ever any in it.
The guy that first started using the idea found it so good he no longer had to run a mech, or electric fan at all.
Im hoping for it to help out with the load that the summer has put on the cooling system, and to hold the pressure it should be holding.
Also i do not like the Brass alloy tanks as they did not have a level on them or anything.
Also i can hook a sensor up to the tank to let me know if the water is low in the header tank, i have also used a oil pressure gauge and tapped the thermostat cover out so i know that the pressure is right, if it changes its head gasket etc.
Car looks good as man. Not the colour I would have chosen but it doesnt look half bad at all! What ya paint it in? You do it or someone else?
Gaz
Color was supposed to be alot darker
I preped the car myself after for for 4 days then spent Saturday doing all the minor imperfections, and masked it up primed it with a gun, rubbed it down, then sunday i put the lights back on, drove it to down to our workshop and masked it all back up.
Rolled it into the booth at 7:00am masked up the inside of the doors took the boot off ordered the paint at 8:00am.
Paint turned up at 10am ish, painter rubbed it down with some cleaners, laid down a sealer coat, then shot it with some paint.
I had to go do jobs and i picked it up out of the booth at 11:30, sat in the sun all day going off.
After work i put the lights all back on fixed some wiring and drove home.
So to answer your questions it was painted in a booth with 2K, by a professional painter.
Cost for the booth painter and paint............................................. $500
I will post some pics with the bumper and front lights on, will look mean on the track.
