twosmoke
WITHOUT A REGULATOR YOU'LL LIKELY POP THE FLOAT VALVES OUT. IT'LL FLOOD THE BEJESUS OUT OF THE, ANYWHO.
YOU CAN RUN A RUTURN LINE, PETE. MAKE IT MORE CONSISTANT. RETURN LINE WOULD COME FROM THE BLEED OFF OF THE REGULATOR. FROM WHAT I'VE SEEN REGULATORS JUST CONSTANTLY LET PRESSURE BUILD WITHOUT BEING HOOKED TO A RETURN
I would run an electric pump + regulator, it's not like they are expensive. if your real skint there are tons at pick a part for $20, check the '80s euros they have the roller cell bosch pumps pretty often which are way more grunty than you would need, some are good for 200-300kW.
it will work fine regulated, but when your fucking around trying to get it running sweet at some point youl have some suspision about the pump which will later turn out to be not a problem but you will have allready put an electric one in.
so seeing as you will swap it out anyway, do it now, and then your fuel bowels will be filled for you the first time you goto start it too.
fuck in the half an hour it took to type that 50 other cunts replyed.
