d.p.n.s Posted December 29, 2007 Share Posted December 29, 2007 hi all im in the process of changing over the drums on my mk1 2 discs from a mk2 the problem i have is that the mk2 strut hats are smaller in bolt pattern to the mk1 . so i thought i would just change the mk1 hats on to the mk2 but the shaft of the shocks in the mk2 are thinker then the mk1 so the hats wont fit on. i cant for the life of me remeber if this has happend befor and if so what i did but any ideas guy? cheers dan Quote Link to comment Share on other sites More sharing options...
Raizer Posted December 29, 2007 Share Posted December 29, 2007 Sounds like a early mk1 strut. Drop the mk1 insert into the mk2 strut so you can run the old tops Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted December 29, 2007 Author Share Posted December 29, 2007 Sounds like a early mk1 strut.Drop the mk1 insert into the mk2 strut so you can run the old tops i would mate but the shocks are fuked. Quote Link to comment Share on other sites More sharing options...
crazy_rich Posted December 29, 2007 Share Posted December 29, 2007 theres no way you could ram a drill down the old strut tops is there? Quote Link to comment Share on other sites More sharing options...
QCADTA Posted December 29, 2007 Share Posted December 29, 2007 Sounds like you might have to get some new shocks mate. Youll also need a mk2 steering rack as the tie rod ends are different size, plus mk 2 are metric where as mk 1 is imperial so cant just buy new tie rod ends and put them on ya mk 1 rack. Quote Link to comment Share on other sites More sharing options...
eke_zetec_RWD Posted December 29, 2007 Share Posted December 29, 2007 and ya need to make a new brake line from ya strut to the caliper with your 3/8th unf on strut end and i think m10x1.0 tube nut other end.... Quote Link to comment Share on other sites More sharing options...
Fordy19 Posted May 7, 2008 Share Posted May 7, 2008 Sounds like you might have to get some new shocks mate. Youll also need a mk2 steering rack as the tie rod ends are different size, plus mk 2 are metric where as mk 1 is imperial so cant just buy new tie rod ends and put them on ya mk 1 rack. Lol, all ya need is a die grinder to make a mk2 rack fit a mk1. Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted May 7, 2008 Author Share Posted May 7, 2008 Sounds like you might have to get some new shocks mate. Youll also need a mk2 steering rack as the tie rod ends are different size, plus mk 2 are metric where as mk 1 is imperial so cant just buy new tie rod ends and put them on ya mk 1 rack. Lol, all ya need is a die grinder to make a mk2 rack fit a mk1. yeh it was around the other way i had a mk1 rack and mk2 struts. did you buy a set of bubble archs of me. cheers dan Quote Link to comment Share on other sites More sharing options...
Gaz Posted May 7, 2008 Share Posted May 7, 2008 Sounds like you might have to get some new shocks mate. Youll also need a mk2 steering rack as the tie rod ends are different size, plus mk 2 are metric where as mk 1 is imperial so cant just buy new tie rod ends and put them on ya mk 1 rack. Lol, all ya need is a die grinder to make a mk2 rack fit a mk1. A mk2 rack should bolt into a mk1 without and grinding of anysort. Its only 4 bolts and they are in the same place lol. Also, from memory ya can drill the tophats but best answer is new shoocks Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted May 7, 2008 Author Share Posted May 7, 2008 this is a old topic gaz it all go sorted a wee while ago. dan Quote Link to comment Share on other sites More sharing options...
QCADTA Posted May 7, 2008 Share Posted May 7, 2008 Sounds like you might have to get some new shocks mate. Youll also need a mk2 steering rack as the tie rod ends are different size, plus mk 2 are metric where as mk 1 is imperial so cant just buy new tie rod ends and put them on ya mk 1 rack. Lol, all ya need is a die grinder to make a mk2 rack fit a mk1. A mk2 rack should bolt into a mk1 without and grinding of anysort. Its only 4 bolts and they are in the same place lol. Also, from memory ya can drill the tophats but best answer is new shoocks Its the balljoints at the end of the rack that are different, and you cant just swap them as mk1 imperial, mk2 metric. And i just drilled my top hats out to Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted May 7, 2008 Author Share Posted May 7, 2008 well in the end i used a mk2 steering rack with mk2 sport struts i had bought new shocks and had them machened down to keep the lowered spings captive and i got them to make the tops thinner to fit the mk1 hats. dan Quote Link to comment Share on other sites More sharing options...
shizzl Posted May 7, 2008 Share Posted May 7, 2008 did royce clive shorten your shocks?what did it cost ya? Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted May 7, 2008 Author Share Posted May 7, 2008 did royce clive shorten your shocks?what did it cost ya? no i got them done at the shockshop 2 new shocks and all shortened and made to fit the top hats $350. Quote Link to comment Share on other sites More sharing options...
