eke_zetec_RWD Posted December 18, 2012 Share Posted December 18, 2012 Hopefully Saturday if dyno is available. Seems to run pretty well with my old map loaded on. Just needed lots of advance at idle and loads of idle valve for it to idle nice. Quote Link to comment Share on other sites More sharing options...
eke_zetec_RWD Posted December 19, 2012 Share Posted December 19, 2012 did a few ks on it tonight. just 12psi and took 5 deg of timing out under boost just to be safe. it really goes mint. all the compressor serge is gone. and pulls hard right the way to the limiter. the down side is all those years with the serge has i think fucked my turbo as its now louder than the motor when on boost Quote Link to comment Share on other sites More sharing options...
Gaz Posted December 20, 2012 Share Posted December 20, 2012 UPGRADE! Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted December 20, 2012 Share Posted December 20, 2012 Just to be safe took it to the limiter . . . Top job! vIDS vIDS vIDS! Quote Link to comment Share on other sites More sharing options...
eke_zetec_RWD Posted December 26, 2012 Share Posted December 26, 2012 I had about a hour on dyno on Monday, was a bit of a fail really. Everything was mint except for a consistant miss at 6500 rpm so I pulled plugs out to check gap and 3 broke! Fuck only found peasant hot as fuck plugs so couldn't really keep tuning it. Problem was a corroded contact in the dizzy cap for main coil lead! Any way power it MILES up on old cam! On 11 psi power was 225 hp atw when miss happened and didn't look like falling over anytime soon. Torque is flat line all the way, will need to start tuning at like 2000 instead if 3000 as torque is already up there. I really think 240 kw atw is possible next tune if turbo can keep up. Quote Link to comment Share on other sites More sharing options...
KKtrips Posted December 26, 2012 Share Posted December 26, 2012 GASP! Quote Link to comment Share on other sites More sharing options...
eke_zetec_RWD Posted December 26, 2012 Share Posted December 26, 2012 Nah it's just a road car 1 Quote Link to comment Share on other sites More sharing options...
eke_zetec_RWD Posted December 27, 2012 Share Posted December 27, 2012 Did you not know pintos are immune to such things. 2 Quote Link to comment Share on other sites More sharing options...
eke_zetec_RWD Posted January 10, 2013 Share Posted January 10, 2013 dyno again. somethings wrong - cant get over 200kw at 20psi but like 180kw at 15psi so i would of expected more than 200 on 20psi but somethings holding it back. although i think the turbo is rooted - sounds mean as. goes hard as tho! prob should give up modifying it. Quote Link to comment Share on other sites More sharing options...
KKtrips Posted January 10, 2013 Share Posted January 10, 2013 Are the inlet and exhaust diameters big enough?? Quote Link to comment Share on other sites More sharing options...
eke_zetec_RWD Posted January 10, 2013 Share Posted January 10, 2013 i took exhaust off and did back to back dyno runs, no real difference. unless the first 1 meter of 2.5inch exhaust is too small. i didnt get a chance to try cam timing but its set perfect to the sheet. has a good filter and 3 inch piping. blah blah. must be turbo but the inlet temps arnt high Quote Link to comment Share on other sites More sharing options...
KKtrips Posted January 10, 2013 Share Posted January 10, 2013 You got 215 with the same exhaust and inlet etc didn't you? Quote Link to comment Share on other sites More sharing options...
eke_zetec_RWD Posted January 10, 2013 Share Posted January 10, 2013 yip Quote Link to comment Share on other sites More sharing options...
KKtrips Posted January 10, 2013 Share Posted January 10, 2013 So in my world that doesn't understand too much in the way of turbos says that if they have flowed 215hp before then it should be able to flow that again right? What else have you changed other than cam? Turbo could be struggling cos it's a bit toasted? Quote Link to comment Share on other sites More sharing options...
eke_zetec_RWD Posted January 10, 2013 Share Posted January 10, 2013 yea it sounds pretty mean tho so wheres the real turbo experts on here? Quote Link to comment Share on other sites More sharing options...
eke_zetec_RWD Posted January 10, 2013 Share Posted January 10, 2013 http://www.ebay.com.au/itm/Kinugawa-3-Anti-Surge-Turbocharger-SUBARU-WRX-STI-Twin-Scroll-TD06SL2-60-1-FMIC-/290831410710?pt=AU_Car_Parts_Accessories&hash=item43b6e72616#ht_2574wt_1271 Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted January 10, 2013 Share Posted January 10, 2013 approve! Quote Link to comment Share on other sites More sharing options...
Truenotch Posted January 10, 2013 Share Posted January 10, 2013 What's your shaft play like Jase? Worth trying another VF to rule it out? What's the torque curve like compared to the old plots? Quote Link to comment Share on other sites More sharing options...
eke_zetec_RWD Posted January 10, 2013 Share Posted January 10, 2013 Yea your right. A cheap second hand vf36 about $600 if you can even find one. Quite rear turbos. Those new ebay ones are $1000 delivered. I know what you mean tho. Quote Link to comment Share on other sites More sharing options...
eke_zetec_RWD Posted January 11, 2013 Share Posted January 11, 2013 any one used a Kinugawa turbo? thoughts? Quote Link to comment Share on other sites More sharing options...
