cute wee gem Posted August 25, 2007 Share Posted August 25, 2007 Would a random condenser not work properly if its in the wrong car? Put a points setup back in the gem cause the elec ign is fucked but it still ain't going properly. has random bursts of power but lots of missing etc Points are the right ones for it, might do the gap a bit better aswell Quote Link to comment Share on other sites More sharing options...
cute wee gem Posted August 25, 2007 Author Share Posted August 25, 2007 Also still has a resistor? that connects to the coil if that makes any difference? Quote Link to comment Share on other sites More sharing options...
lowlancer Posted August 25, 2007 Share Posted August 25, 2007 Rightio All a condensor does is ensure spark is meke as. Shouldn't make TOO much of a diff what it's from I would think. Didn't even have one on Celeste with either engine and they were mint Can draw you epic paint stz pic of how to hook resistor up if you want? Quote Link to comment Share on other sites More sharing options...
davidian Posted August 25, 2007 Share Posted August 25, 2007 must be as you can get many different ones last time i was after one they had 2-3 different ones for the same engine depending on dizzy, fuck knows Quote Link to comment Share on other sites More sharing options...
cute wee gem Posted August 28, 2007 Author Share Posted August 28, 2007 Pretty sure I've wired it up right, just sits on the outside and connected to that strap/wire from the points through the side of dizzy yeh? Quote Link to comment Share on other sites More sharing options...
cubastreet Posted August 28, 2007 Share Posted August 28, 2007 Check all the electrical connections on the coil and distributor, plug wires and the one from coil to dizzy. Could also be a bad coil or plug wires. Quote Link to comment Share on other sites More sharing options...
lowlancer Posted August 28, 2007 Share Posted August 28, 2007 Resistor goes between "Run" wire from ignition barrel, to + of coil, to reduce voltage. This is due to coil being designed to run on like 11volts or something, as that's all it gets during "Crank" There should be a relay in there to switch between "Crank" and "run" Quote Link to comment Share on other sites More sharing options...
thminiman Posted August 29, 2007 Share Posted August 29, 2007 the engines fucked bro take it out and get onto it as a project Quote Link to comment Share on other sites More sharing options...
peteretep Posted August 29, 2007 Share Posted August 29, 2007 ...dizzy doesnt work so engines fucked? wow Quote Link to comment Share on other sites More sharing options...
treggo Posted August 29, 2007 Share Posted August 29, 2007 ...dizzy doesnt work so engines fucked? wow Yes Quote Link to comment Share on other sites More sharing options...
cute wee gem Posted August 29, 2007 Author Share Posted August 29, 2007 the engines fucked brotake it out and get onto it as a project True story, I just had to get it running to move it, which I did and took it for a fang/miss fired down the road Just wanted to get it going good so I can take it for a decent fang, long term project and all so new engine's a fair way away yet Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted August 29, 2007 Share Posted August 29, 2007 did the module in theelectronic dizzy fuck ou? perhaps chuck some good leads on there etc. potental reason why it's missing/the module fucked out Quote Link to comment Share on other sites More sharing options...
EarthwurmJurm Posted September 3, 2007 Share Posted September 3, 2007 burnt points will generally point at a faulty condenser afaik. what sort of nick are they in? Quote Link to comment Share on other sites More sharing options...
Mike-e Posted September 3, 2007 Share Posted September 3, 2007 ^ earthwurm = right All a condensor does is ensure spark is meke as. so doesnt, a condensor stops electricity for arcing across your points as they open. fucked condensor = burnt out points condensors are pretty generic, when i got pissed off with my hilux one fucking out i grabbed a 1 farad out of a microwave Quote Link to comment Share on other sites More sharing options...
cute wee gem Posted September 4, 2007 Author Share Posted September 4, 2007 Got it sorted in the end, I figured it was ignition cause the tach spiked hardcore, went to brand new points and no better. Fanged it up a hill and it came right (why couldn't it do that over the last 700ks?) Back to electronic stz now, epic victory fang took place Quote Link to comment Share on other sites More sharing options...
