pies Posted August 6, 2007 Share Posted August 6, 2007 how the hell does one get the timing gear off of the crank shaft? theres not enough room to get the gear pullers round it, tried a screwdriver and wedging it off but again, not enough room. anyone got any ideas? Quote Link to comment Share on other sites More sharing options...
Goat Posted August 6, 2007 Share Posted August 6, 2007 See if you could somehow get one of those reverse hammer things attached to it. Don't know what they're called. Used for pulling out dents etc/ just a thought, probably wont work Quote Link to comment Share on other sites More sharing options...
Mike-e Posted August 6, 2007 Share Posted August 6, 2007 ^slide hammer Quote Link to comment Share on other sites More sharing options...
Goat Posted August 6, 2007 Share Posted August 6, 2007 ^slide hammer Thats the one Quote Link to comment Share on other sites More sharing options...
Hemi Posted August 7, 2007 Share Posted August 7, 2007 if there not enough room for a puller ther wont be for a slide hammer , usually you have to slowly jimmy it off with two prybars or screwdriver like jiggle it etc otherwise itl cock over and jam , i get so frustrated with the ones on trucks at work lol Quote Link to comment Share on other sites More sharing options...
CXGPWR Posted August 7, 2007 Share Posted August 7, 2007 Is there threaded holes in the gear? IF there is find some bolts to screw into the holes & get a gear puller. The bolts go through the puller & the puller will push against the end of the crank & off comes your gear. Here is a pic of a puller. Hope this helps Quote Link to comment Share on other sites More sharing options...
pies Posted August 7, 2007 Author Share Posted August 7, 2007 nah no threaded holes. i guess im just going to have to use pry bar. Quote Link to comment Share on other sites More sharing options...
fuel Posted August 8, 2007 Share Posted August 8, 2007 I had problems getting the crank pulley off my 6A12 V6. It just had the one big nut and once that was off the pulley decided it didn't want to move. I doused it in CRC and got a screwdriver and prybar behind it but all it did was bend and chip off the alloy (oops). I tried tapping around the perimeter of the pulley to work it loose but it didn't seem to help either. In the end I gave up and left it overnight and came back in the morning and was just mucking around with the engine - I gripped the pulley trying to figure out how to take it off, only to find it fell off as soon as I touched it pretty much. If CRC/WD40 + overnight fails, you could always try heating it up with a blowtorch. Quote Link to comment Share on other sites More sharing options...
84_S12 Posted August 10, 2007 Share Posted August 10, 2007 +1 CRC overnight works wonders Your engine will always vibrate if you warp the pulley even the slightest so be very wary of bashing it around. Also, too much shock could crack the crankshaft so be careful there too. Quote Link to comment Share on other sites More sharing options...
