kyteler Posted May 15, 2007 Share Posted May 15, 2007 what carbs? Run some SU's then all you'll need to do is plumb a turbo in, ftw. Quote Link to comment Share on other sites More sharing options...
blakamin Posted May 15, 2007 Author Share Posted May 15, 2007 currently running two two-barrel zenith 35/40 INAT the holes are the size of holleys on top has this air filter as it is the only one that fits under the bonnet (it used to have an oil-bath filter) anyone got any photos of NA turbo setups? Quote Link to comment Share on other sites More sharing options...
Spencer Posted May 15, 2007 Share Posted May 15, 2007 Add a new head gasket and head studs to your build up aswell. Carb setup will work but I still dont think you have enough control (well not enough for my liking) on a highish comp ratio. I'd want to use a wide band O2 sensor when the carbs being tuned. plumbing is just the same as any turbo setup really except things get gay for you because its non cross flow, go have a look at some 4k turbo carb setups and add a few cylinders on in your imagination Quote Link to comment Share on other sites More sharing options...
nismo.capri Posted May 15, 2007 Share Posted May 15, 2007 T2 doesn't really have enough puff for an inty (Or much more than about 10psi lol) True but he's going to be running 2 of them with 9.1:1 CR on a 2.5L. Personally, I'd prefer to use a larger unit running low pressure at good low temps, instead of having a little t2 whistling away puffing hot air into your engine... That's what will cause detonation + kill your motah Why will they be blowing hot air? They are designed to be effiecent at 8-10psi. Quote Link to comment Share on other sites More sharing options...
nismo.capri Posted May 15, 2007 Share Posted May 15, 2007 all ill say is ask leon. him = the man on carb turbos.you would probably need a single carb too dont think twins would work... Lotus would disagree that twin carbs and turbos don't work, they did a decent job on the Esprit Quote Link to comment Share on other sites More sharing options...
nismo.capri Posted May 15, 2007 Share Posted May 15, 2007 what carbs? Run some SU's then all you'll need to do is plumb a turbo in, ftw. yeah I wouldn't call an SU a carb either Here's my version of that Quote Link to comment Share on other sites More sharing options...
nismo.capri Posted May 15, 2007 Share Posted May 15, 2007 currently running two two-barrel zenith 35/40 INATthe holes are the size of holleys on top. Should be fine with a few mods. You need to find out what the float(s) is made of. If you are lucky it will be plastic as the metal ones can colapse under boost if you are running a blow through setup. Quote Link to comment Share on other sites More sharing options...
Draizuh Posted May 15, 2007 Share Posted May 15, 2007 all ill say is ask leon. him = the man on carb turbos.you would probably need a single carb too dont think twins would work... Lotus would disagree that twin carbs and turbos don't work, they did a decent job on the Esprit Unfortunatly the blanketman isnt/doesnt own the world famous car tuning company lotus so i think he could be a bit up shit creek in that aspect Quote Link to comment Share on other sites More sharing options...
Mike-e Posted May 16, 2007 Share Posted May 16, 2007 aws Quote Link to comment Share on other sites More sharing options...
blakamin Posted May 16, 2007 Author Share Posted May 16, 2007 Should be fine with a few mods. You need to find out what the float(s) is made of. If you are lucky it will be plastic as the metal ones can colapse under boost if you are running a blow through setup. Plastic... and is blow through better than sucking? at this rate I might just supercharge the cunt! thanks for the photos people, I have a vision now! Quote Link to comment Share on other sites More sharing options...
blakamin Posted May 16, 2007 Author Share Posted May 16, 2007 what carbs? Run some SU's then all you'll need to do is plumb a turbo in, ftw. yeah I wouldn't call an SU a carb either Here's my version of that you got any higher res photos of the engine you could email me? Quote Link to comment Share on other sites More sharing options...
Mike-e Posted May 16, 2007 Share Posted May 16, 2007 Plastic... and is blow through better than sucking? yep, because with suck through you cant run a intercooler because its kills fuel atomisation, whereas your fine with a blow through because carb is after the cooler just blow through is a little cuntier to setup. I used to have a diahatsu charade with a VL pump with a malpassi FPR keeping fuel bowl pressurised, it also ran a seperate external injector with a thin copper line running into the carb that opened at a set pressure value, worked well. edit dont forget to vent sump and re route pcv/breather also Quote Link to comment Share on other sites More sharing options...
durty Posted May 16, 2007 Share Posted May 16, 2007 aws ROFL at guy in mirror Quote Link to comment Share on other sites More sharing options...
RT Posted May 16, 2007 Share Posted May 16, 2007 ROFL at the BoshGT coil.. Quote Link to comment Share on other sites More sharing options...
nismo.capri Posted May 17, 2007 Share Posted May 17, 2007 yep, because with suck through you cant run a intercooler because its kills fuel atomisation, whereas your fine with a blow through because carb is after the cooler ...and they make a nice bomb if you get an intake back fire Quote Link to comment Share on other sites More sharing options...
nismo.capri Posted May 17, 2007 Share Posted May 17, 2007 at this rate I might just supercharge the cunt! Wont make any difference to the carb/intercooler setup issues. Personally I perfer a blower to turbos for the daily driver Quote Link to comment Share on other sites More sharing options...
nismo.capri Posted May 17, 2007 Share Posted May 17, 2007 you got any higher res photos of the engine you could email me? Sorry nope..... that was hi res when they were taken Quote Link to comment Share on other sites More sharing options...
RT Posted May 17, 2007 Share Posted May 17, 2007 you got any higher res photos of the engine you could email me? Sorry nope..... that was hi res when they were taken classic Quote Link to comment Share on other sites More sharing options...
blakamin Posted May 17, 2007 Author Share Posted May 17, 2007 at this rate I might just supercharge the cunt! Wont make any difference to the carb/intercooler setup issues. Personally I perfer a blower to turbos for the daily driver yeah, but I already have belt clearance issues.... blow-through turbo looks like the go for space at the mo... and spewin on the photos... I wanted to see some detail... any individual shots not made as a big jpeg? Quote Link to comment Share on other sites More sharing options...
Unclejake Posted May 17, 2007 Share Posted May 17, 2007 The carbs you have on the M114 are a dog - terrible things and almost impossible to get parts for. FTW I would be crafting some side draft Webers on a custom manifold. Also make a vernier cam drive as the camshafts on those motors are quite advanced in their timing. A cam from a carbed 280 has more lift I believe........... and they are well cheap Quote Link to comment Share on other sites More sharing options...
