4AGE into escort??
mk2_escort
Im no toymotor champ but why would it make it easier? You would still need custom mounts wouldnt you. Might be able to buy them but expensive.
Might be easier if you could keep the standard brake booster.
+ in an escort its a differant car.
But 4ages do go good in dxs. chick I know had one. Loose as
  • Replies 59
starlets are a tad more involved, custom mounts etc.
plus the engine bay is a tad shorter so some things are a little tight depending how you do them.
awesome conversion on them though,. mate usaed to have one, side out exhaust and shiz, was mean as. went gravel bashin in that thing almost daily
you can get away using your stock fuel tank/lines etc by mounting the surge tank in the engine bay so u only need to have a short return line not the full length of the car. with only a facet or similar pump filling the surge tank
Not a very good idea, frontal impact with a container of fuel is a bad thing. Much safer to do it properly.
Callum
fuck mate there aint much fuel in a surge tank only about a litre or so mounted right back on the fire wall it would be safe as houses. its no different than a crash with a carbed car with fuel pump lines and carb etc
it wasnt really meant to start a debate. just an example of ways to stop everything costing a fortune and having done a retro conversion [holden 3.8 v6 -lc torrie i know what a cunt and expence it is if ya dont have all the gear to do it yaself
this is what im doin also, got 20v blacktop motor ecu etc and stickin in escky panelvan, and im using silvertop rods and some 4agze pistons so can go turbo
Why are you putting silvertop rods in it? Black top and Silvertop rods should be the same...
If you wanna put a 4age in an eskie it doesnt matter how much work it takes coz youd want a 4age eskie. If you just want a 4age, buy a car with one standard :)
All RWD 4age parts are out of AE86's. With the exception of a few things...
And as mentioned earlier, thanks to intial d they are all insanely expensive.
Thinking of selling me AE85 coz i cant be fucked paying 750 bucks for a freaking T50 or 500 for a goddamn FWD bluetop.
the blacktop rods are weaker than slivertop and the others 4ages
yeh i already have a factory 4age AE82 fxgt and im puttin the blacktop in cuz it came from my other ae82
I meant for the other guy, not you. should have made it clearer :)
not true. there's rwd carinas, celicas, coronas and corollas etc etc etc in 4age RWD config. ae86 wasnt the only rwd 4age that ran the same shit. quite a broad range, can't be bothered thinking of more.
anywho,
blacktop rods are hugely different to silvertop. silvertop and 4agze are the same. don't think the 20v got the steel crank that the gze got though, nor the coated (not forged, nor 'semi forged' - impossible, as most n00bs say)
no point putting it all in an escort methinks. without going whole hog. its a big job, then you're left with something oddball really. best to do it to a dx as stated previous, at least all parts are off the shelf, essentially.
anywho,
As far as im aware the only corolla to come with the 4age in RWD was the AE86 Chasis. Never seen 4age carina's. Celicas yes but they arent very common... Ditto for Coronas.
