escortman Posted February 4, 2006 Share Posted February 4, 2006 ok was gona drop it in my ae82 cuz thought the bluetop was rooted but was jus a blockd pressure pipe so now hav a 20v blacktop 4age and thought hey y not drop it in the panelvan, so now jus gotta source i think a T50 gb, im thnking of using the 4.4 diff thats already in there( i only care bout mean acceleration screw top end) or how hard to find and fit a hilux diff, arent they lsd im gona ditch hte injection system so dnt hav to change fuel pump etc and jus gona run some siddies get some race cams for a nice lumpy idle and that shud b all of my money gone Quote Link to comment Share on other sites More sharing options...
lowlancer Posted February 4, 2006 Share Posted February 4, 2006 Sell it to Draizuh and put a 1300 kent in yours Will rule Quote Link to comment Share on other sites More sharing options...
escortman Posted February 4, 2006 Author Share Posted February 4, 2006 well its all ready got a 1600 kent from a mk2 tina sport, but i want the reliability of a newer toyota motor but oldskool looks, and i got the levin running gear for 500 buks, but im selling parts from the donor car so the motor is gona b a freebie basically Quote Link to comment Share on other sites More sharing options...
mk2_escort Posted February 5, 2006 Share Posted February 5, 2006 u must b stupid 2 put sidies on a 4age blacktop! it already has quadthrottle bodies and those engines r simply amazing! dont mess around with carbs on an engine like that becoz u r only gona get less power then u started off with. some race cams will cost u close 2 a grand and with that u NEED double valve springs etc witch is anotha 400. 2 get some decent gains from the cam u should realy give the head a port and polish etc so do ur homework first mate! Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted February 5, 2006 Share Posted February 5, 2006 meh, you'll get same out and out power on sidies, just lose all the driveability, and economy, along with the vvti etc. blacktops run a map efi system. you can run open throttles etc. there's no point going back 10 steps to rancid carbs efi = the new oldschool stz Quote Link to comment Share on other sites More sharing options...
corrupt Posted February 5, 2006 Share Posted February 5, 2006 efi = the new oldschool stz in that case, whats the new newschool?? Quote Link to comment Share on other sites More sharing options...
escortman Posted February 5, 2006 Author Share Posted February 5, 2006 yes i realise they have quad throttle bodies but theres a lot more work involved in converting the esky to run efi my mechainc has called in a few favours and has got cheaper prices than that so do ur homework first mate! umm isnt this wat this forum is for Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted February 5, 2006 Share Posted February 5, 2006 extra work, and extra cost. If you're going to go to the trouble of fitting a 4age to an escort you might as well do it properly. the benefits of efi over DCOEs are awesome. sure for a race car maybe the dcoes would be sweet, but again, you get more tuneability out of the efi stz. link/microtech/motec, even factory, it'll be a far nicer engine. round town driveability would be terrible on side drafts. i know from experience even how much difference there is going from a 32/36dgav to twin 40mm dcoes on a 2litre escort. goodbye fuel. sure, alot more pow3er, but when the engine's been designed around a similar system anyway it's just laze that would be the deciding factor of quad throttle bodies over carbs in that case, whats the new newschool?? cars that look terrible refer: the latest suby wrx Quote Link to comment Share on other sites More sharing options...
Defective Posted February 5, 2006 Share Posted February 5, 2006 the work involved in converting your escort to efi isnt really any more than changing the 20v to carbies... really if your mad keen on sidies you would be better off flicking the 20V and running an older 4age... imo converting a 20v to run on sidies is like buying a 351 clevo and knocking it back to a 302..... my 2c... end of the day its your car bro. Quote Link to comment Share on other sites More sharing options...
escortman Posted February 5, 2006 Author Share Posted February 5, 2006 cheers guys yeh i know the fuel bit is piss easy but its the wiring up of the ecu and other little fiddly bits that are makeing me think sidies Quote Link to comment Share on other sites More sharing options...
Defective Posted February 5, 2006 Share Posted February 5, 2006 i think with a basic link theres only like 8-10 wires to connect up... but yeah i know what ya mean, i hate wiring and would unbolt bolt on shit all day long than try and rewire something in my car. Quote Link to comment Share on other sites More sharing options...
Draizuh Posted February 5, 2006 Share Posted February 5, 2006 To put it in your escort your gonna need a T50 or K50, T50 to A or K50 to A bellhousing, new pedal box, AE86 Crossmember (or mounts welded to yours). Probably have to do something about the dizzy too (sticks into firewall stz).as well as heaps of other fidly shit. and hilux diff would be needed. Blacktop would shit escort diffs. Hilux diff == Shorten up + mount suspension. putting stupid escort hubs+ brakes on it would be a waste of time so youd have to run 5stud mags. it would probably cost you a good 5 to 6 hundy to get the diff shortened for the escort. probably better off with a Capri or a ford 9". i like lowlancers idea tho haha. Quote Link to comment Share on other sites More sharing options...
Gaz Posted February 5, 2006 Share Posted February 5, 2006 I can sell u all the shit for 4age conversion into esky plus the twin 40s, hot cam, redtop engine that needs rings, fuel system etc. Quote Link to comment Share on other sites More sharing options...
RT Posted February 5, 2006 Share Posted February 5, 2006 would you rather a little more work in the beginning to have it run mint forever? or have to work on your twin carbs every coupla months.. it's not hard to covert to efi anyway! one extra fuel line.. a electric pump.. and a bit of wiring. Quote Link to comment Share on other sites More sharing options...
crazy_rich Posted February 7, 2006 Share Posted February 7, 2006 hey man, if you do end out carbing it i'll buy your quad throttles off ya Quote Link to comment Share on other sites More sharing options...
escortman Posted February 7, 2006 Author Share Posted February 7, 2006 hey guys update after takin all the things into consideration, (things i hadnt reliabilty for starters) im gona convert the esky to run the efi Quote Link to comment Share on other sites More sharing options...
davidian Posted February 7, 2006 Share Posted February 7, 2006 LOL to whoever voted for the 4.4 you legend wtf is a 4.4 anyways? Quote Link to comment Share on other sites More sharing options...
escortman Posted February 7, 2006 Author Share Posted February 7, 2006 the 4.4 is jus tha diff ratio it has, thers also 4.1 3.75 and 3.5 that iv heard of Quote Link to comment Share on other sites More sharing options...
Gaz Posted February 8, 2006 Share Posted February 8, 2006 what kinda diff? Quote Link to comment Share on other sites More sharing options...
escortman Posted February 9, 2006 Author Share Posted February 9, 2006 duno think same 1 as anglias hard or soething Quote Link to comment Share on other sites More sharing options...
