Guest tinaboi Posted November 7, 2005 Share Posted November 7, 2005 hey i have a 1200 mk1 cortina and I just put a k&n filter on and some ngk plugs lookn for sum extra performance ,as ya do!(even on a 1200!!) and its actually lost power now when I put my foot down, do i need to re jet my carb or sumthing else or do i need a new carb all together? any help on this and some other ways of getting some performance out of a tiny 1.2 wuld be apreciated, thanks Quote Link to comment Share on other sites More sharing options...
lowlancer Posted November 7, 2005 Share Posted November 7, 2005 1200? Didn't realise there was a 1200 engine, 1100, 1300 1500 yes, but 1200? Don't bother man, just get the 1500 and put a 32/36 or something similar on it Quote Link to comment Share on other sites More sharing options...
Gaz Posted November 7, 2005 Share Posted November 7, 2005 as above. or put a 2l cortina mk3+ engine in. wouldnt think k&N would have lost power. if so then yeah maybe upgrade carby jets and cam. Quote Link to comment Share on other sites More sharing options...
zep Posted November 7, 2005 Share Posted November 7, 2005 Had you connected all the vacuum hoses back up (or blocked off the ones you don't need anymore)? Quote Link to comment Share on other sites More sharing options...
Guest tinaboi Posted November 7, 2005 Share Posted November 7, 2005 yea they make 1200,there isnt many of them around though. I assumed it would have been the lack of gas as when i drive with the choke on abit it goes back to normal, I tuned the air/fuel but didnt solve the problem. how much does it cost to get a carb re jetted? or shouldi ust do it myself? Quote Link to comment Share on other sites More sharing options...
lowlancer Posted November 8, 2005 Share Posted November 8, 2005 Just get it tuned properly at a mechanics Quote Link to comment Share on other sites More sharing options...
Guest WESTCORT Posted November 8, 2005 Share Posted November 8, 2005 i dought u need to get it rejetted, it will more than likely be running lean after u added the new filter. play around with the mixture screw some more, you want to screw it in untill it gains the most revs, then when it reaches this point unscrew it as much as possible (probly not alot) without the revs dropping. so you got it running lean best Quote Link to comment Share on other sites More sharing options...
v3k Posted November 8, 2005 Share Posted November 8, 2005 or... get a vacuum guage, look up vacuum guage tuning on google (I can be bothered explaining everything here) and tune it that way. Quote Link to comment Share on other sites More sharing options...
drftnmaz Posted November 8, 2005 Share Posted November 8, 2005 have you set the timing? or points latley? Quote Link to comment Share on other sites More sharing options...
atropine Posted November 8, 2005 Share Posted November 8, 2005 1200?Didn't realise there was a 1200 engine, 1100, 1300 1500 yes, but 1200? Don't bother man, just get the 1500 and put a 32/36 or something similar on it prexflow is 1200/1500, xflow is 1100/1300/1600.. i believe Quote Link to comment Share on other sites More sharing options...
Pushrod Posted November 8, 2005 Share Posted November 8, 2005 Yep atros right but add 997 to the pre xflows list Also you dont happen to have a spare 1200 gearbox do you Quote Link to comment Share on other sites More sharing options...
atropine Posted November 8, 2005 Share Posted November 8, 2005 Yep atros right but add 997 to the pre xflows listAlso you dont happen to have a spare 1200 gearbox do you ah true always forget that lil bugger Quote Link to comment Share on other sites More sharing options...
v3k Posted November 8, 2005 Share Posted November 8, 2005 Vacuum Tuning Quote Link to comment Share on other sites More sharing options...
HUNTD Posted November 8, 2005 Share Posted November 8, 2005 Interesting! Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted November 8, 2005 Share Posted November 8, 2005 bookmarked.... cool. Quote Link to comment Share on other sites More sharing options...
coltspeed Posted November 9, 2005 Share Posted November 9, 2005 have you got the k&n in the stock aircleaner assembly? cause if you have vacuum secondaries you will need to keep the cleaner assembly so there is a little restriction to cause vacuum to open your secondary. this happened with mine but your set up is probably different. it wont cost you anything to try if this is the case and you may be suprised. Quote Link to comment Share on other sites More sharing options...
Guest tinaboi Posted November 9, 2005 Share Posted November 9, 2005 nah the filters not in the original filter assembly, i had tryed it in there because i thought maybe it was getting to much hot air just sitting on top of the carb but it made no difference, i took it to the local carb guy he said iv tuned it right but the k&n filter was to thick for my car and not free flowing enough and that a paper filter would be better, i kind of doubted that so went n got a k&n restoring kit. it helped a tiny bit but still have the same problem. Quote Link to comment Share on other sites More sharing options...
