Gaz Posted December 5, 2005 Share Posted December 5, 2005 So which escorts or cortinas had the single peice shaft? Quote Link to comment Share on other sites More sharing options...
kyteler Posted December 5, 2005 Share Posted December 5, 2005 Mk2 1100 Kents and some MK1's, probably same capacity. Quote Link to comment Share on other sites More sharing options...
atropine Posted December 5, 2005 Share Posted December 5, 2005 and rs2000s? wouldnt be surprised if a lot of the RS had singles.. Quote Link to comment Share on other sites More sharing options...
two_days_late Posted December 5, 2005 Share Posted December 5, 2005 i have a single piece drive shaft from a manual that i'll be happy to swap for a single piece from an auto if anyones keen... and about the tunnel thing, its well known that the autos have bigger tunnels so they fit 5 speeds easily, but i've driven one like this and the clutch pedel rubs on the carpet on the inside of the tunnel. just warning people who are thinking about this, coz it gets pretty annoying! cheers Matt Quote Link to comment Share on other sites More sharing options...
Guest escort_boy Posted December 5, 2005 Share Posted December 5, 2005 the clutch when converted from a auto to a manual rubs? Quote Link to comment Share on other sites More sharing options...
two_days_late Posted December 5, 2005 Share Posted December 5, 2005 yea if your using an auto body shell and put a manual gearbox in, as theres no clutch pedal with the auto, so when you put one in because the tunnels alot wider the pedal rubs on the carpet on the side of the tunnel. only a little bit but it was still annoying. Quote Link to comment Share on other sites More sharing options...
Toucan Posted December 5, 2005 Share Posted December 5, 2005 Thats when you beat the tunnel in the other direction Quote Link to comment Share on other sites More sharing options...
two_days_late Posted December 5, 2005 Share Posted December 5, 2005 muhaha. probably easier to cut the whole tunnel out and make up a new one. Quote Link to comment Share on other sites More sharing options...
Guest escort_boy Posted December 5, 2005 Share Posted December 5, 2005 just cut the clutch pedal Quote Link to comment Share on other sites More sharing options...
two_days_late Posted December 6, 2005 Share Posted December 6, 2005 or just dont bother with a clutch, if you get the revs right its not to hard to get into gear without one... im sure a v8 supercar driver used to do that coz he had a bung leg or something? Quote Link to comment Share on other sites More sharing options...
Eskorted Posted December 6, 2005 Share Posted December 6, 2005 two_days_late my esky used to be a auto 1300 and now its got a 5speed 2l in it and ive got aftermarket pedals on my pedals and i still have about 3-5cm gap between the pedal and carpet/transtunnel... Quote Link to comment Share on other sites More sharing options...
davidian Posted December 6, 2005 Share Posted December 6, 2005 the only thing my clutch pedal was rubbing on was the ancient wiper/squirter button which was mounted underneath it originally. so binned that and got a swith wired up to the dash Quote Link to comment Share on other sites More sharing options...
Guest escort_boy Posted December 6, 2005 Share Posted December 6, 2005 the only thing my clutch pedal was rubbing on was the ancient wiper/squirter button which was mounted underneath it originally. so binned that and got a swith wired up to the dash and they still dont work Quote Link to comment Share on other sites More sharing options...
Guest escort_boy Posted December 6, 2005 Share Posted December 6, 2005 two_days_late my esky used to be a auto 1300 and now its got a 5speed 2l in it and ive got aftermarket pedals on my pedals and i still have about 3-5cm gap between the pedal and carpet/transtunnel... aftermarke = repco?? yeah i didnt think my was hitting on anything, mind u i havnt sat in it for ages Quote Link to comment Share on other sites More sharing options...
two_days_late Posted December 6, 2005 Share Posted December 6, 2005 oh ok thats strange then, the one i had used to rub. wasnt put in by me, maybe it was just that one. Matt Quote Link to comment Share on other sites More sharing options...
Guest escort_boy Posted December 6, 2005 Share Posted December 6, 2005 what was the pedal box off? that mite have been the problem Quote Link to comment Share on other sites More sharing options...
davidian Posted December 6, 2005 Share Posted December 6, 2005 the only thing my clutch pedal was rubbing on was the ancient wiper/squirter button which was mounted underneath it originally. so binned that and got a swith wired up to the dash and they still dont work nigga please, who needs wipers when you can have one arm out the window with a squeege and be a cool car and a comedy act in one... should really get onto that hmm Quote Link to comment Share on other sites More sharing options...
Guest escort_boy Posted December 6, 2005 Share Posted December 6, 2005 the only thing my clutch pedal was rubbing on was the ancient wiper/squirter button which was mounted underneath it originally. so binned that and got a swith wired up to the dash and they still dont work nigga please, who needs wipers when you can have one arm out the window with a squeege and be a cool car and a comedy act in one... should really get onto that hmm maybe u should get a xmas pressie for her.... fix the window wiperrrs Quote Link to comment Share on other sites More sharing options...
Eskorted Posted December 6, 2005 Share Posted December 6, 2005 yer repco is where i got em aye. yea i rekon it might be the pedal box you used. mines sweet.. besided the hole i made for the clutch cable is to low and my clutch cable keeps snapping gotta grind the shaft off drill a new hole hire up and weld back on... any one got a welder lol and yea fix ur window wipers Quote Link to comment Share on other sites More sharing options...
Guest WESTCORT Posted December 6, 2005 Share Posted December 6, 2005 lol at ivan being the only person on earth who actually wants dudes washing windows at the lights Quote Link to comment Share on other sites More sharing options...
