drftnmaz Posted September 18, 2005 Share Posted September 18, 2005 what kind of Temp do headers on turbo get upto and waht sort of temp does the pipe coming off the turbo get upto? i've almost finished turbo'n my 4k and i got a few leaks and need to know what material i can use to make gaskets. any idea's on materials Quote Link to comment Share on other sites More sharing options...
Ned Posted September 19, 2005 Share Posted September 19, 2005 liquid gasket goo Quote Link to comment Share on other sites More sharing options...
Guest escort_boy Posted September 19, 2005 Share Posted September 19, 2005 i waws thinking that but is that what he is after? Quote Link to comment Share on other sites More sharing options...
Ned Posted September 19, 2005 Share Posted September 19, 2005 dont know... just use gasket paper that can handle the heat of an exhaust (not sure if there is such a thing... dont know how much normal gaskets can handle...) and use that... with gasket goo Quote Link to comment Share on other sites More sharing options...
Toucan Posted September 19, 2005 Share Posted September 19, 2005 If you are after a liquid type type then I reccomend Holts Firegum from Supercheap. Great stuff, sets hard as and can withstand white heat (according to the packet). Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted September 19, 2005 Share Posted September 19, 2005 get some of that proper metallic type shit, either as a factory style gasket, or get some from a rebuilders bulk roll to make one. for oil feeds/returns use proper gasket paper, you dont want little bits of rtv rockin down into the turbo Quote Link to comment Share on other sites More sharing options...
drftnmaz Posted September 19, 2005 Author Share Posted September 19, 2005 yea i need to make a actual gasket.. i already tryed that goo and it blew straight out first rev i gave it i have this expensive as sh!t at work specs are: max temp 430C max pressure 100bar (approx 1470psi) max steam temp 250C max inert liquard temp 440C i think i might give it a go but damn its expensive Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted September 19, 2005 Share Posted September 19, 2005 theft as a servant it up Quote Link to comment Share on other sites More sharing options...
RT Posted September 19, 2005 Share Posted September 19, 2005 I wouldn't use any sort of gasket goo or gasket maker on a turbo.. the shit will come off in bits and munch through the blades and fuck your turbo quickly. Temp gets red hot, i've had mine glowing cherry red on many occasions. I just use single peice gaskets off the shelf.. make sure it's metal backed on both sides and you'll be sweet. The repco paper shit will blow out under high boost. Quote Link to comment Share on other sites More sharing options...
drftnmaz Posted September 19, 2005 Author Share Posted September 19, 2005 nah i'll just charge it to my staff acc!!! i can't get a off-the shelf gasket for what i need! or i would have already done it. the flange i mainly need it for is the outlet of the turbo so no issues bout it hitting the turbine. what temp is red hot tho? 300C ??? i wouldn't have a clue and on a side note anyone know where to get decent manifold gaskets for a 4k???? i had to get those sh!t paper ones from repco Quote Link to comment Share on other sites More sharing options...
peteretep Posted September 19, 2005 Share Posted September 19, 2005 haha 100 bar thats huge Quote Link to comment Share on other sites More sharing options...
Hemi Posted September 19, 2005 Share Posted September 19, 2005 yea dont go near anything bar one piece gaskets ive had more then enough turbos come through work that are completely farked the center housing and exhaust blades because of a piece deciding to leave the manifold etc......, is it for the turbo or the headers? Quote Link to comment Share on other sites More sharing options...
Burntrubber Posted September 19, 2005 Share Posted September 19, 2005 Have you had the flange's machined flat thats important mine blew out the turbine exit a few times I knew it was warped but yeah was to lazy. Its all good now and I use repco paper but its only done a few kms so could blow out later. Quote Link to comment Share on other sites More sharing options...
drftnmaz Posted September 20, 2005 Author Share Posted September 20, 2005 yea i just file them flat normally aye. its the flange on the exit of the turbo, i have seperate wastegate and the factory gasket doesn't seperate the two so it wouldn't work. i was wondering about replaceing manfold to head gasket as well Quote Link to comment Share on other sites More sharing options...
