kyteler Posted August 15, 2005 Share Posted August 15, 2005 what are you guys on with 1 piece shafts? as far as i know not fuk all of those fords came with 1 piece shafts, only 2 piece. gotta go custom for a 1 piece 1100 Kent Mk2 4spd came with single piece driveshaft. Quote Link to comment Share on other sites More sharing options...
Pushrod Posted August 15, 2005 Share Posted August 15, 2005 So did most of the RS Escorts I thought Quote Link to comment Share on other sites More sharing options...
two_days_late Posted August 15, 2005 Share Posted August 15, 2005 yea the 1100 manuals came out with single piece, but the 1300 and 1600 came out with two piece shafts, according to mr haynes anyway. might check in the book and see what the auto ones came out with. could always get an auto two piece and take the UV joint off and swap it onto my manual one. have to get the driveshaft shortened then tho. cheers Matt Quote Link to comment Share on other sites More sharing options...
Defcon Posted August 15, 2005 Share Posted August 15, 2005 You should have brought a holden. Suckers, my box bolted straight up to the 2ltr- backwards ford rednecks, MUhahahahahah!!! Quote Link to comment Share on other sites More sharing options...
peteretep Posted August 15, 2005 Share Posted August 15, 2005 most mk1 escorts came with 1 piece driveshafts i think, my car is 1 piece Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted August 15, 2005 Share Posted August 15, 2005 You should have brought a ISUZU[/color]. Suckers, my box bolted straight up to the 2ltr- backwards ford rednecks, MUhahahahahah!!! jap on Quote Link to comment Share on other sites More sharing options...
esky boi Posted August 15, 2005 Share Posted August 15, 2005 retep 130wrote: hey, if i was just gonna use a pinto 4speed gearbox on my 1600 xflow could i just change over the clutch plate because my flywheel has already had some weight loss so i want to keep it Nah bro, the Corty clutch is a bigger daimeter, wont fit the Escort flywheel aye. Why put a Pinto 4speed in tho? Quote Link to comment Share on other sites More sharing options...
atropine Posted August 15, 2005 Share Posted August 15, 2005 i had a pinto 4spd in my sport.. didnt know of any problems a mechanic put it all together.. pretty nice seeming ratios anyways... 3.656,1.97,1.47,1.0 i think.. Quote Link to comment Share on other sites More sharing options...
RT Posted August 15, 2005 Share Posted August 15, 2005 the 1600 close ratio box from a Capri is great in an escort! Quote Link to comment Share on other sites More sharing options...
two_days_late Posted August 15, 2005 Share Posted August 15, 2005 the esky i brought off stacov had a 4 speed cortina box in it i think, it topped out at 130 but it got there pretty quick haha cheers Matt Quote Link to comment Share on other sites More sharing options...
atropine Posted August 15, 2005 Share Posted August 15, 2005 well 4th gear is the same in em all so top speed doesnt really matter when choosing between em Quote Link to comment Share on other sites More sharing options...
peteretep Posted August 16, 2005 Share Posted August 16, 2005 aww i wanna put the pinto box on but i already have a skimmed flywheel and i dont really wanna get another one skimmed Quote Link to comment Share on other sites More sharing options...
Guest escort_boy Posted August 16, 2005 Share Posted August 16, 2005 just get a 5spd one? Quote Link to comment Share on other sites More sharing options...
peteretep Posted August 16, 2005 Share Posted August 16, 2005 but i want to keep the xlfow flywheel, i dont want to use the pinto one at all, using a 5 speed seems like very hard work Quote Link to comment Share on other sites More sharing options...
Guest escort_boy Posted August 16, 2005 Share Posted August 16, 2005 not that hard if u use a sierra clutch, fly wheel etc etc Quote Link to comment Share on other sites More sharing options...
esky boi Posted August 16, 2005 Share Posted August 16, 2005 Yeah, Pinto flywheels are lighter than Xflow ones anyway.. so you wouldnt be losing out on anything Quote Link to comment Share on other sites More sharing options...
Guest kris Posted August 16, 2005 Share Posted August 16, 2005 Pinto flywheel will not go on a Xflow. Sure the bolts line up, but you then can't get a starter that will work with it - at least not that I know of. Quote Link to comment Share on other sites More sharing options...
davidian Posted August 16, 2005 Share Posted August 16, 2005 yeah i think the sierra starter turns out about 10mm short of engaging with the sierra flywheel, from memory, could be wrong tho. just use ya xflow fly and re drill it, i think only 2 or 3 threaded holes need to be put in and a couple of extra dowells to hold the pressure plate. pretty basic with the right skills yo. Quote Link to comment Share on other sites More sharing options...
two_days_late Posted August 16, 2005 Share Posted August 16, 2005 i think youll need a differnt backplate too, because the starters in a differnt place? you could just scrap the backplate but prob not a good idea. cheers Matt Quote Link to comment Share on other sites More sharing options...
Guest escort_boy Posted August 16, 2005 Share Posted August 16, 2005 Get a backplate from a Pinto powered Cortina. This will need to be modified as the rear crank seal housing is much larger on the kent engine. So simply cut out around the center until it fits your engine. This is the easiest and therefore the best solution. thats what kris's web site says Quote Link to comment Share on other sites More sharing options...
