1600 and 5spd
Guest escort_boy
  • Replies 73
never been an issue at all aye
just give it a good clean when a clutch change takes place or whatever otherwise bobs your uncle :lol:
however, one reaccuring problem is the end of the clutch cable for some reason falls off the fork quite often. the universal solution (gods gift)-cable ties:)
yeah shure is.. u using a sierra one as well?
id rather have it too long than a too-short escort one that i used to go trough every fortnight, fukin things would always give way on the pedal end, sometimes the gearbox end. K road in peak traffic aint that much fun to loose ya clutch in, i tell ya. neither is the main road to mission bay on a sunny sunday avo with mad backlogs :(
I've never broken a clutch cable in my life - WTF are you doing to it?
BTW: Plate keeps the clutch dry and clean, that sounds like a good idea to me...
like i said above they just used to snap for no reason.. like RT said tho most prob to do with the angle...
as far as the plate goes i know very well its function, however the car has been running on and off for 4 years and its had the same secondhand clutch in it since the very start, still reliable, doesnt slip, bites well, no quams whatsoever, so im happy as. fuk the plate i say. you guys can run whatever you please
what about getting a clutch that fits a xflow flywheel etc with a 1x23 spline to fit the gearbox.
also just looking at the gearbox, i think the bellhousing is from a standard escort gearbox but if theres someone out there with a standard escort gearbox could you take a pic of it so i can see if theres any difference. Ive had a look on the burton website but its on a weird angle so i cant tell, thanks
well i just found out today that i already have a pinto clutch and pressure plate and already have a re-drilled flywheel, except that it still has a xflow spline...
the guy said it may be a clutch from a escort van as they had a heavier duty clutch to handle the extra weight so he said to bring in the clutch and he will just change the spline over
alot easier than i thought, now i just have to make sure i have the right bellhousing
