Rotary flywheel torque settings..
RT
as described.
I want to know the correct torque settings for a 12A rotary flywheel..
anyone?
just bash that nut real hard with the biggest hammer you have ! But seriuosly give Glen at rotary power a call, 09 4435762 or Alec at Kiwi RE 09 5771047 Im sure they can give you an answer
Guest escort_boy
holy fucking jesus 362ft-lb?? the escort was only like 60, then again, it aint spinning round at 10000rpm!
u sure it weasnt 60m kg?
Just had a look at the workshop manual and the figures i stole above are correct.
Also from the manual;
"Apply Loctite..." - Good idea
"Assuming that most home mechanics will not have a torque wrench hich will read this high, you can achieve thi figure by using a length of pipe over your torque wrench. 100 pounds of torque applied 3 1/2 feet from the nut will give a torque equal to 350 pounds" - Pretty good idea too
