drftnmaz Posted June 27, 2005 Share Posted June 27, 2005 i was wondering what fuel pumps people use on there suck-through set-ups? do you use fuel pressure regulators and injected fuel pumps or jst low pressure pumps and expect the turbo to suck the extra fuel through? Quote Link to comment Share on other sites More sharing options...
Guest Demonmk2 Posted June 27, 2005 Share Posted June 27, 2005 yup Quote Link to comment Share on other sites More sharing options...
drftnmaz Posted June 27, 2005 Author Share Posted June 27, 2005 yup 2 wat? Quote Link to comment Share on other sites More sharing options...
RT Posted June 27, 2005 Share Posted June 27, 2005 there is no need for high pressure. You want an electric low pressure high volume pump. Holly make some good ones. Quote Link to comment Share on other sites More sharing options...
DavidTheCreator Posted June 27, 2005 Share Posted June 27, 2005 yea like rt siad low pressure high volume Quote Link to comment Share on other sites More sharing options...
R100 Posted June 27, 2005 Share Posted June 27, 2005 You can just use the factory fuel pump in most cases Quote Link to comment Share on other sites More sharing options...
drftnmaz Posted June 27, 2005 Author Share Posted June 27, 2005 You can just use the factory fuel pump in most cases as in the factory machanicial fuel pump? i was thinking about adding a 5psi electric pump as well? Quote Link to comment Share on other sites More sharing options...
Hemi Posted June 27, 2005 Share Posted June 27, 2005 if u do that then just compleletly bypass the mechanical one and like hook that up to the pcv valve that add horsepower belive it or not , im not sure wether id trust the mech pump to keep up with the fuel requirements of the turboed motor ... but i could be wrong Quote Link to comment Share on other sites More sharing options...
drftnmaz Posted June 27, 2005 Author Share Posted June 27, 2005 what pcv valve is that? Quote Link to comment Share on other sites More sharing options...
Hemi Posted June 28, 2005 Share Posted June 28, 2005 the engine re-breather* itll come out of the block or rocker cover and go into the base of the carby/air filter Quote Link to comment Share on other sites More sharing options...
R100 Posted June 28, 2005 Share Posted June 28, 2005 You can just use the factory fuel pump in most cases as in the factory machanicial fuel pump? i was thinking about adding a 5psi electric pump as well? no just use the factory mechanical pump, tell me more about your project ? Quote Link to comment Share on other sites More sharing options...
drftnmaz Posted June 28, 2005 Author Share Posted June 28, 2005 i have a few projects on the go aye but this one in-particular is jst my daily driver, isuzu gemini with a g180 motor, jst gonna run a suck-through turbo to give me a little bit of pep to overtake etc... but am also in the process of supercharging a lancia motor and that will b suck-through as well.. nethuing in particular u'd like to no? on a side-note i dont spose ne1 has a good idea on how to make the exchast manifold with-out getting pro-file cut plates? Quote Link to comment Share on other sites More sharing options...
drftnmaz Posted June 28, 2005 Author Share Posted June 28, 2005 if u do that then just compleletly bypass the mechanical one and like hook that up to the pcv valve that add horsepower belive it or not , im not sure wether id trust the mech pump to keep up with the fuel requirements of the turboed motor ... but i could be wrong so ur saying pump air out of the rocker cover?? to stop pressure building up? Quote Link to comment Share on other sites More sharing options...
esky boi Posted June 28, 2005 Share Posted June 28, 2005 Yea, then into the intake manifold. Its to release the pressure in the crankcase caused by piston blow-by n shit... Quote Link to comment Share on other sites More sharing options...
Hemi Posted June 29, 2005 Share Posted June 29, 2005 bang on eski boi , just getsn rid of the pressure in the crankcase which might be takign up horsepower , and it makes ur motor just that bit more cleaner (i think) , i wouldnt trust the mechanical pump to supply fuel but then again if the carb bowl is big enough and ur not foot to the floor all the time i guess its fine Quote Link to comment Share on other sites More sharing options...
Ned Posted June 29, 2005 Share Posted June 29, 2005 just make the carb bowl a bit bigger also, make it stick out of the bonnet so it gets awesome cooling Quote Link to comment Share on other sites More sharing options...
drftnmaz Posted June 29, 2005 Author Share Posted June 29, 2005 ur not foot to the floor all the time i guess its fine i kinda have trouble with that aye /\ so i think i might hunt a new pump out, ne1 know of a good factory electric carbie pump? only one i can think of is the twin carb honda motors (but its a honda ) cheers for your help guys. Quote Link to comment Share on other sites More sharing options...
Ned Posted June 29, 2005 Share Posted June 29, 2005 why do u want factory? just go to appco and tell them what you want... Quote Link to comment Share on other sites More sharing options...
drftnmaz Posted June 29, 2005 Author Share Posted June 29, 2005 $$$$ i'm poor and a firm believer in you can do it ur-self. so why not adapt something else thats gonna cost me $5 or so? Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted June 29, 2005 Share Posted June 29, 2005 why not use a vl commodore pump - they're inline, and high pressure - cant see why you couldnt use it a a carby pump if you have a return line alternatively - get anyhting from pick a part - off a turbo cordia or something to that effect..... either way - swing down to you rlocal wreckers, and get something that would suit, there'll be something!!! Quote Link to comment Share on other sites More sharing options...
