drftnmaz Posted June 29, 2005 Author Share Posted June 29, 2005 yea i don't think a high pressure one would b the greatest idea aye, i'll have to look and see if i have a fuel return, i don't think i do???? yea pick-a-part will b the go wen i get to that stage i jst throught someone might have done this and tryed a few pumps.. NOTHING WORSE THAN LEANING OUT ON BOOOST Quote Link to comment Share on other sites More sharing options...
zep Posted June 29, 2005 Share Posted June 29, 2005 Apparantly Geminis do have return lines, they just don't use them or something. I am having the same drama with my turbo setup. But there should be (apparantly) 3 lines, a feed, a fuel return and a vaopur return. At least that is what I have been told. This was from an Aussie tho, the Holden ones may have been different. What year is your gemini? Quote Link to comment Share on other sites More sharing options...
RT Posted June 29, 2005 Share Posted June 29, 2005 Often your tank will have two breather lines. You can use one of them as a return line with no consequence. Quote Link to comment Share on other sites More sharing options...
drftnmaz Posted June 29, 2005 Author Share Posted June 29, 2005 1980 yea i'll have to look into those lines aye. i dn't spose ne1 have left over flanges from making there turbo manifolds????????? Quote Link to comment Share on other sites More sharing options...
Burntrubber Posted June 30, 2005 Share Posted June 30, 2005 I made all my gemini turbo stuff myself gas cut flanges and 32mm weld els. I was quoted $45-60 to get the flanges profile cut which is cheap next time I do anything like this thats what I'll do seen as its a bit neater than my gas cutting. My TG 84 and TE 83 both have return and vapor lines and the TE has a standard elec fuel pump the head does'nt even have a hole for a mech pump. Makes for easy pump upgrade which I've done got a EFI pump out of a 85 Toyota Carina flows 120L per hour approx I use a holly regulator does the job nicely. Quote Link to comment Share on other sites More sharing options...
drftnmaz Posted July 3, 2005 Author Share Posted July 3, 2005 nice set-up there. thanks for the pic. jst outta interest what carbie u using and what fpr are u using? Quote Link to comment Share on other sites More sharing options...
Burntrubber Posted July 5, 2005 Share Posted July 5, 2005 Webber 32/36 and fuel reg is a holly modified for boost did a few things to the carb to help with boost all seems to works good. Han'nt driven much cars not legal yet so dont realy now how good it goes. Quote Link to comment Share on other sites More sharing options...
2FKNLO Posted July 6, 2005 Share Posted July 6, 2005 know a easy way to put my oil drain line in my pinto? Quote Link to comment Share on other sites More sharing options...
RT Posted July 6, 2005 Share Posted July 6, 2005 the 205 blocks have an oil drain built in.. otherwise you have to drill a hole in your sump and weld in a pipe. Make sure its close to the top, above the oil line. I've got a modifed sump lying around if you are interested. But its a pretty simple thing to do. Quote Link to comment Share on other sites More sharing options...
2FKNLO Posted July 11, 2005 Share Posted July 11, 2005 do u have a pic of it i dont know if i put it high enough lol Quote Link to comment Share on other sites More sharing options...
2FKNLO Posted July 19, 2005 Share Posted July 19, 2005 bah its high enough. had it going today was sounding alright. needs a bit of tuning but yeah cant wait to go for a blat! Quote Link to comment Share on other sites More sharing options...
2FKNLO Posted August 3, 2005 Share Posted August 3, 2005 does anyone know anythin about recirculating blow off valves and if i'd be able to fit one on my suck through turbo set up? Quote Link to comment Share on other sites More sharing options...
RT Posted August 3, 2005 Share Posted August 3, 2005 never hear of em.. and if they do what I imagine they'd do from the name then they are still dangerous. Think about it, you have compressed air + highly flamable liquid/gas together. You want to get that shit into your engine asap and by the shortest and safest route possible. Any sort of ridicilous re-ciculation bov sounds like a receipe for an explosion to me Quote Link to comment Share on other sites More sharing options...
TygerTung Posted August 3, 2005 Share Posted August 3, 2005 Nah no blow off valve needed, you can't use one anyway, because it won't go orf. A fuel pump off a carby cordia turbo would be a winner! Quote Link to comment Share on other sites More sharing options...
drftnmaz Posted August 4, 2005 Author Share Posted August 4, 2005 you could have a blow off valve coming out your bonnet blowing flames if your crazy but i'd imange you'd stall everytime it went off and it wouldn't b that easy to trigger either. Quote Link to comment Share on other sites More sharing options...
TygerTung Posted August 4, 2005 Share Posted August 4, 2005 You wouldn't be able to trigger it as the pressure is after the throttle. Quote Link to comment Share on other sites More sharing options...
drftnmaz Posted August 4, 2005 Author Share Posted August 4, 2005 i'm sure you could figger out a way if u were that keen, you have vacum on the inlet, and pressure on the outlet of the turbo so with a heap of one-way valves you coul do it... but why bother. Quote Link to comment Share on other sites More sharing options...
TygerTung Posted August 4, 2005 Share Posted August 4, 2005 You don't have pressure on the outlet of the turbo really or vacuum on the inlet, because the turbo is just by the inlet, as the throttle is before the turbo. Quote Link to comment Share on other sites More sharing options...
RT Posted August 4, 2005 Share Posted August 4, 2005 You don't have pressure on the outlet of the turbo really um..yes you do. Thats kinda the idea.. Quote Link to comment Share on other sites More sharing options...
