Everything posted by CorollaGT
On a macpherson strut type suspenion - is there a minimum amount of thread that needs to extend past the end of a nut on the two bolts securing the shock to the hub(knuckle/carrier)? EDIT: 'Two threads clear'
mitchs 924 - tell me i made a terrible decision to buy here
CorollaGT replied to Mitch.W's topic in Project Discussion
A cousin of mine brought one of these just before he turned 21 (would've been 15 years ago) and my oldman as a bit of a joke gave him gloves and an umbrella for his 21st. Said he'd be needing both of those with how unreliable the car would be. I believe both came in quite handy as it turned out. Car looked sweet on similar mesh rims to that one in here. -
What are people using for epoxy to bond fibreglass and alloy? I have a spoiler that has no mounting hardware to allow it to be bolted to my boot. Thought is to glue an alloy plate with a some rivnuts underneath the spoiler to give a solid base to bolt to the boot. Not keen on using self tappers like what was done previously by the looks of it.
Unfortunately they will not fit a EK Civic
Thank you sir. Also tidying up a battery relocation. I had run the power cable along the sill underneath the plastic trims as it was an easy path / plastic trim has a perfect shape to it. Have made sure I keep it away from sharp edges etc - would you expect this to raise an eye brow come cert? Just need to secure it using some p-clips 300mm between each? Rivnuts to the sill so I can bolt/unbolt the clips would be sweet?
Whats the general rules around securing ABS wiring to struts? Fitted a set of Fortune Auto coilovers and the rear struts don't have the tabs to click the loom on. I ended up using a couple of cable ties to secure it for now. Would this be ok? Or will I need to make a proper bracket?
That's the one
Or just give the pedal a couple of taps mid straight to make sure this doesn't happen. Don't know if you noticed me doing that at Taupo in January when you came for a ride. Also you can get an idea of pedal firmness.
I got a weird response from the local Enzed dude when looking for -12 stuff to do breather setup. Was confused why I would want to go so big and that -6 is more than enough even for a v8
I used fuel cell foam as the media inside my catch can. Just cut a piece to the right size and gave it a thorough clean before installing. Have had the catch can apart a couple of times and the foam is holding up nicely. Also have some of this inside the valve cover in the baffles - when looking into breather setups I found this is part of what RB guys (think Mines, HiOctane Racing Australia etc) were doing so figured if its good enough for 500+hp RB's it's good enough for a little 4AGE.
Also look at the timing belt arrangement, silvertop has a spring on the tensioner - blacktop has a hydro tensioner. Oil pumps are different between the two so unless someone has gone though the effort of swapping all of that stuff it could help ID it.
That stuff is available from Repco etc. Made by ACL. Looks good Blake, will have to try and scrounge another ride when it's running again!
Man I would be happy as to see 110 degrees oil temp in January at Taupo. I saw 120 degrees (doing 10minute sessions in October) and that's with a 16 row Mocal oil cooler sitting in direct cold airflow and ducting.
How about a spacer? https://www.aeroflowperformance.com/fittings/npt-fittings/npt-male-female-extension
Engine masters on header size
Treat the 6 speed nicely by showing some mechanical sympathy and they last. A buddy has run one for years in his AE82 club car doing sealed sprints. I still have the original 160k old C160 in mine and it's done a tonne of trackdays.
For anyone elses reference - I tested the Defi sensors and they're 5v so piggybacking them will be the way to go. Also found someone had spent the time to collect data on the Defi sensors so should make calibration in the Link easy http://bbs.22b.com/forums/showthread.php?8223-Defi-Sensor-Calibration-Curves
Whoops - left out oil temp / pressure! Pretty sure the pressure sensor on Defi stuff is 5v (3pin - positive, earth and return) so I should be able to tap into that one ok. Its more the wiring of the oil temp that I'm unsure of
My car has defi gauges and a Link G4 Storm - been thinking about the possibility of incorporating the oil temp and pressure to work together so that I can do logging and maybe lower rev limit temp dependent. Ideally the plan would be to piggyback off the Defi sensor wiring and tie it into the ECU inputs. Has anyone done this before? / have any pointers? I don't really have the ability to easily add more sensors to the motor unfortunately
Yup it does that but I thought it's weird that number has changed from showing 7.5 to sometimes showing 7.8
I've noticed lately that when starting the car the LC-2 wideband gauge reads 7.8 till its heated up but it use to read 7.5. AFR's seem pretty normal though. Does this sound right and is just due to the cold weather or is it a sign I need to re-calibrate the sensor (been a good 9-12 months since last calibration).
I run a LC2 with what ever bosh sensor that comes in the kit and that turns on with ignition ON. Because of this I'm pretty careful not to leave the key on and the car not running though, if I do I'll turn it off and leave it for a bit before starting the car. Have had the same sensor in the car for about two years now.
If it still has the stock cat and you plan on keeping it then one reso plus a decent muffler should be fine. But if that's going in the scrap bin +1 to using two resos and a muffler.
Disapointed you ditched the Sektas TBH Sean.
What you meant to say is F20C. Have Kelford "rally" cams in a blacktop and find myself only really needing to rev it up to 6k most of the time. No peaky-Ness which is great for road use. These are what the 20v should have come from factory with TBH
