Everything posted by governorsam
You should see bubbles coming out of the bush if it's working...
Bearings or bushes? ( Brass looking things) if bushes, they are probably dry. Put your finger over one end of the bush, fill it with motor oil and then squeeze the oil into the bush with your other finger. Usually sintered bushes, which means they they are pourous to hold the oil. Wipe off excess oil with a rag. Reassemble and test. ( Did my trade as an auto sparkie many moons ago...)
cikey, you fellas have aged a bit..
Have reserved 2 tables out the back in the sun...
At pub already, sunny day..
there is a good chance i shall make it to this meet...
Please help - Gearbox identification
governorsam replied to Little-Macks-Villiers's topic in Tech Talk
Looks like a trials car. Bit like these guys do. http://www.sporty.co.nz/sportingtrials -
The Bronze's XE Falcon Vehicle of Utility Purpose.
governorsam replied to The Bronze's topic in Project Discussion
main loom earth point to the body is near the battery. self tapper from factory, they get loose. and check where you moved/removed lpg wiring. -
Got some time spare next week.. Whereabouts?
Had to leave, but they had the gearbox back on the motor when I left. Cheers for the whitebait patties, yum...
sunday is fine with me..
got a wee shop press i can bring for universals. will bring tools and stuff as well.
Let me have a look the Lucas alt first, might be an easy fix. And its already on the car. Parts are cheap. Cut my teeth on Lucas stuff, it's fine if set up right. Pm me your address bud..
if i get karls rusty datsun finished by then, can come and help.
Dubman59's morris minor called george
governorsam replied to governorsam's topic in Projects and Build Ups
Dubman59 now owns this. -
Side stand switch definitely. Also green is earth, black is ignition on Hondas. Used to work in a bike shop doing electrics.
Good turnout again, met some new faces. Awesome.
Looks like it has had the bash. No good. Will chew the pads off in no time. Needs a grind/ take it back. Possibly bent/cracked too. She's rooted mate.
governorsam replied to Roman's topic in Tech Talk
Clamping can fuck hoses. If you go too tight. Just enough to stop the pressure. Like having to stop mid stream while having a piss to write your name in the snow. Too much clamping will do damage. -
Soft brake hoses, can flex/expand. Grab the hose and get someone to stomp on the pedal. If you can feel it, its fucked. Happens a lot on old bikes, old cars. And shitty lines. -
Anything can be fixed, comes down to expense vs result. Any creases in the chassis/ body? Have pulled cars straight with a block and tackle before. If its just a small tweak, can be feasible. If you can see it, so can the inspector..
http://sucarb.co.uk/news/new-development-2017/
white wire on the coil + is 12v unfused ignition feed. put an in-line fuse holder from there to the pump. then earth the pump. simple, easy to do. no need for a relay in a viva. cheers.
will try and get there, depends on which way the fire goes today. some fresh air would be nice.
