Everything posted by jakesae101
http://www.weberperformance.com.au/index.php?cPath=6_264_304&osCsid=ee99t83kqtovu7s09is8j2npm4
It's possible they do not have them but you can get kits with a selection for a set of twins from other places
You can also buy sets there im fairly sure that give you a good selection to play with
I used dellorto.co.uk for mine half the price i could get them here and were here in less than a week top service
I think i have a manual for one of these somewhere for when i had my 250n if i find it you can have it if you want.
- 41 replies
- Superdream Honda CB400N
- Honda
(and 3 more)
Tagged with:
touge's ae101 racecar - ‘fab it all from scratch’ project
jakesae101 replied to Rhyscar's topic in Other Projects
voldo are you making the cams for yourself these days? might hit you up at the beginning of next year for a custom rally cam for my mazda.- 234 replies
Ive used autometer ultralite for years and put then in the rally car nothing bad to say about them
isnt gt refinishers supposed to be quite good in akl?
DCC 2OI6 Gravel series & local events
jakesae101 replied to JoKer's topic in Lower North Island Region
13s are probably no go now running bigger brakes 14s just fit now i have some 14 inch tyres but dont know how good they will be now- 53 replies
still need to get me some 15 inch rims so many cheap 15 inch rally tyres 14s not so much- 53 replies
the escort has a cage doesn't it ...- 53 replies
you will need to host your photos //oldschool.co.nz/index.php?/topic/43667-hosting-project-photos-on-oldschool/
Jakesae101s 1985 mazda 323 rally car
jakesae101 replied to jakesae101's topic in Projects and Build Ups
ok so wee while between updates I blame the crap weather we have had and a busy schedule things have slowly been happening. Manu is currently modifying my aframe to work with the car so i can tow it round. I scored a bunch of bits off a guy I know that came off his old etude that he wrecked he was hording for that "one day" he gets another that that resulted in this happening much earlier than I expected they call it the vr4 conversion. Basically its 266mmx22mm vr4 mitisi rotors over mazda bfmp hubs that get machined to take the rotor over the top instead of bolted behind and then you use gtx calipers . the rotors were almost brand new but needed skimming as they looked like they had sat in the sea but came up ok , the calipers are refurbished with new seals and the hubs had been modified and had longer studs put in the only bit I needed to get was some bfmp caliper bolts that weren't that easy to track down but I got there. form this To this also scored a strut brace While I was doing the brake upgrade I poked at a scabby patch that someone had put on and found a large rust hole so I was trying to find a patch panel from another car to make it much easier. I Hadn't seen one at pick a part in some time so I was trying a few other avenues and crustywhip said there was a KA laser at pick a part so I went down and liberated it of the section I needed it put up a good fight. here's the patch ready to get cut up after i removed the spot welds here to remove the chassis rail its triple skinned here I dollied it back into shape after all the removal from the car and drilling it and cold chiseling it got a bit deformed Once that bit of rust is fixed its ready to race took it for a test drive after doing the brakes and they make a big difference will be better when they have some quality pads in them and it was my first drive since rejetting the carbs months ago man it runs way better more mid range. Have to get my o2 sensor bung fitted so I can see what the afrs are doing. -
Raizer's 92 Delica "XL SALOON" Van Lyfe of Fail & HiAce of win
jakesae101 replied to Raizer's topic in Other Projects
im just sayn but id pay extra to get my lawns done by a guy who showed up in a mk2 panno -
Anyone able to do a Zebra mission
jakesae101 replied to jakesae101's topic in Upper North Island Region
ect... -
yea a sabre saw would do it it just zip it off up by the firewall and by the front panel through the chassis rails at both ends too. -
YES!! yes that is the one i need a passengers side inner wing off -
There was one quite a while ago but i didnt see one last time i went -
the actual inner guard / front quarter mine is turns out is very very rusty would make life far far easier to repair with another panel -
So there is a KA laser listed at zebra onehunga and im trying to get a complete passengers side inner guard for a ka laser or a mazda bd and having no luck here . Will pay cash for someone to go get said inner guard and send it down to Wellington? Anyone keen?
id say that would only happen if you used really small rope id say you would want the biggest diameter that can fit in the spark plug hole and still get it to feed in
my ag100 does this if i haven't ridden it in ages pops free easy enough after a meter or 2 of riding
I was more referring to the peice steelies was lookin at cutting off turning the triangle upside down vs flipping it backwards then ending up with mdd side out.
- 27 replies
would work it you turned up upside down wouldn't it?
- 27 replies
if its this month im unlikely to make it next month however probably , Manu is currently fabbing my a frame up so i can tow the mazda places. no wof or reg but meets sch A and I need to get my license again since I let it lapse.- 53 replies
