I have a 4G32 engine (Mitsi) with a twin barrel Aisan carb with a vacuum secondary on it. As well as Mitsi engines, this carb was apparently in Toyota's too. (Model of carb is a C28MA, or MD-006219)
Can someone tell me where the vacuum lines / hoses from the carb should go. Please. If you have a early 80's Mitsi Lancer, L300, etc with a 4G32 it likely has this carb - I can't find a vacuum line diagram anywhere on the net or in manuals in the library.
I suspect that there should be a line going from the inlet manifold to the carb to open the power valve- both the inlet manifold vacuum pipe, and several vacuum lines on the carb have been blocked off (it's in a forklift so no brake booster or other fancy stuff - the air filter housing is not standard - possibly it had a vacuum line going there too). Possibly if there was a line going to the air filter housing this should be open, and not closed off. I also want to check that the ignition vacuum advance line is going to the correct place (ported vacuum).
The engine was fitted in a friends forklift several years ago, and has apparently never run well - will rev if you open the throttle SLOWLY, but you can't 'blip' the throttle. I have a kit for the carb coming, but rather than then randomly playing around with vacuum hoses, if you have a diagram I can't find, or can look under the bonnet of a standard vehicle and tell me where things go it will be greatly appreciated.
Thanks.
Bruce
