jakesae101
Everything posted by jakesae101
  1. possibly talk to cam he works at twl i think they sell twistlocks
  2. will look up in my old note book from when i worked at the airport we used a dude called tony robberts mega gc can swing a hiab like no ones business had a pink ford truck will find his number and pm you
  3. gahh brought one yesterday twas expensive too just to tap 4 holes
  4. Well i have been recently procuring go fast bits of here and on trademe KPR was nice enough to sell me his direct port water injection setup with lots of added goodies unfortunately today i realised i don't have the room to fit it as i had originally intended i had originally intended to have 5 x injectors 1 in each port and keeping the superchargers rotors cool the way i have currently set it up for is 2x small injectors are injecting just before the throttle body into the supercharger and 2x small injectors are set up just before the inlet manifold just after the intercooler bit of faffing about to get the pipe that has the cold start injector on it that sits on top of the inlet manifold off i had to undo the 4 bolts that attach the super charger to the inlet manifold and there is 20 million things in the way/ no room to work this is the 2 setup just before the inlet manifold post intercooler and these are the 2 setup on the inlet to the supercharger just before the throttle body i also mounted up the line pressure switch (if this stays on after the pump turns off i have a blocked jet) and the solenoid also mounted the tank and pump in the boot all i have left to do is setup the motor controller unit and wire the pump to that , install the pressure switch to start the whole thing and get some more nylon pipe to run between the engine bay and the pump oh and i brought a civic alloy radiator but i need to get the bottom outlet modified to clear the engine mount
  5. vicegrips? or hammer a 6 point socket on it ?
  6. i heard diesel down the bores can do the trick to un seize
  7. i have a shirt that we got given haha peter can be jewish with the moneys really. like how it always ends up costing us money because we go over the fuel allowances
  8. we have met before by the looks of things im one of the people that count you off from the line on targa
  9. just run the factory ones my biggest peice of advice is (from lots and lots of $$$$ and time) leave it stock keep racing it till you cant get it to go any faster then mess with it by then you will know how to get the most out of it and where it needs to improve
  10. so i need to borrow off someone a 1/8 NPT tap since i only need to do all of 5 holes it hardly seems worthy of buying one will pay in beers or whatever any help appreciated
  11. you may find you need the rear side panels by the rear seats for a wof
  12. used hq shocks in the back of my mk2 from memory cant remember what i used at the front
  13. nandos is good but we all know were all to jewish to pay for parking
  14. g1 v4 is computer tunable but looking to upgrade it to a v5
  15. i had one of those fibreglass lips when i had my ae85 notchy it wasnt too bad really fitment was pretty spot on
  16. just put of curiosity did they tune your link what did it sting you? also did you wire your link?
  17. they should just pop off the box the axles are just splined and click into place in the box
  18. pretty much all im wanting is to cool the charger to prolong its life and have some anti detonation going on in there before i start fettleing with the advance on the dyno have brought kpr's setup off him
  19. how much did it set you back im kinda eyeing one up at the moment
  20. timmo at octane automotive is regarded as one of the best in the business
  21. i love these things a mate of mine has 3 1 original spec like the day it rolled off the line and a project one that was mega messed up (masterton spec spray bomb metalic green and lots of rust no engine ect ) its been painted gun metal grey and is getting the blacktop 6 speed treatment oh and 1 in parts and a fxgt race car and his dad has a grandma owned spec 5 door in mint nic also oh and a guy i work with also has one i think its the same colour scheme as yours and i also co drove in a a nzgt 5 door lift back rally car used to do 220kph on gravel with a angry silvertop
  22. ive met the guy that owns it a few times its in pretty good nic really id own it 2k power ooooooo
